Spacepope wrote:FedEx has sent N575FE to the desert. Originally delivered to Garuda Indonesia, this GE powered airframe had 93856 hours and 21701 cycles on it as of this month.
DL757NYC wrote:Isn’t the MD-11’s cargo load by weight significantly greater than the 767. UPS AND Fed Ex still use the MD-11 on long haul missions to Asia and Europe. I was under the impression the MD-11 is able to fly further with heavier loads. It fell between the 767 and 747. How can they use the 767 for a 1:1 replacement?
wjcandee wrote:There's cargo and there's express. FedEx wants to fly express, because it generates a higher rate than cargo. Express usually bulks out before it weights out. So the weight-lifting ability of the MD11 is less important, other than its ability to lift a lot of fuel which it will then burn if it has to fly far. It ability to carry lots of containers, however, is still a good thing.
I think the proper comparison, which I haven't seen done yet with real world load types and volumes, is volume inside the containers that FedEx (or UPS) uses on each.
If you wanted to fly textiles and other dense stuff to and from the Caribbean and South America or further, then weight-carrying ability matters more. Buddy of mine whose airline usually flies express stuff did a cargo turn to South America and came back with a load pretty-close to MTOW. Said it was fun to see what the 763 could do when heavy, something he didn't normally even come close to experiencing.
HPRamper wrote:767 in FX configuration - 22xAAD, 1xSAA, 1xAYY, 15xAQF plus aft bulk compartment is 16000.5cf.
MD11 - 20xAMJ, 3xAAD, 2xSAA, 1xAYY, 32xAKE plus bulk is 20064.5cf.
So an almost exact 4/5 volume ratio between 767 and MD11.
AMJ volume is 603.6cf, AAD is 507 so a fairly clean 5/6 ratio there for the primary containers. "Average" weights bear out the volume disparity....if the average weight of a full AMJ is 4500lb, a full AAD will be about 3700lb.
jetblueguy22 wrote:DL757NYC wrote:Isn’t the MD-11’s cargo load by weight significantly greater than the 767. UPS AND Fed Ex still use the MD-11 on long haul missions to Asia and Europe. I was under the impression the MD-11 is able to fly further with heavier loads. It fell between the 767 and 747. How can they use the 767 for a 1:1 replacement?
It’s not a 1:1 replacement, but you also don’t exactly need a 1:1 replacement.
Your highest volume is going to be coming out of the major hubs (SDF, MEM). The returns back are, on average for most stations, quite a bit lighter. At least in the 5X market, most of the stations that get an MD-11, also have another flight that feeds the station. So off the day sort you get an MD-11 + something smaller. Usually one of those flights has positions available. So yeah, you can’t lift as much, but you don’t need to.
Then you have the added benefit of removing essentially an orphan fleet type. At 5X the Airbuses + 757/767 can go pretty much to any gateway. The MD-11 is fairly more restrictive. Now your problem child is limited to the 747, but you’re not going to drop that into many places that don’t already accept them anyways. You have more 767s that can do that job now.
mark1484 wrote:AirBridgeCargo reported to be restarting with IL96-400T. The first aircraft’s, RA-96103 has already been painted.
stretch8 wrote:N287CM CAM B763 scheduled ILN-SNN tonite, then TLV for BDSF conversion. cheers!
TheZ wrote:I was tracking another flight and saw N619FE is on its way to VCV today. Is it being sent for scrapping as well?
747classic wrote:TheZ wrote:I was tracking another flight and saw N619FE is on its way to VCV today. Is it being sent for scrapping as well?
Surprisingly, this is one of the factory built FedEx MD11 freighters, powered by CF6-80C2D1F engines.
Perhaps these engines can be re-used for new to be delivered 767-300F aircraft (modifying a CF6-80C2D1F to -B6F standard is possible during engine overhaul )
stretch8 wrote:N287CM CAM B763 is enroute ILN-SNN. cheers!
Spacepope wrote:747classic wrote:TheZ wrote:I was tracking another flight and saw N619FE is on its way to VCV today. Is it being sent for scrapping as well?
Based on SDRs, her last heavy check was exactly 2 years ago. I'd wager she's getting parked in lieu of the heavy check, and will be brought back in the future.
As of Feb 2023 she only had about 82,000 hours and 20,000 cycles.
20,000 cycles are not that few. The default limit of validity for the MD-11 is 20,000 cycles, but there seems to be an extension to 40,000 cycles. I wonder how expensive it is to operate an MD-11 beyond 20,000 cycles, for example due to additional maintenance tasks required.
Iemand91 wrote:TUI Netherlands' 767-300ER PH-OYI has been flown AMS-DGX last Monday prior freighter conversion.
Last passenger flight was the day before; FUE to AMS.
wjcandee wrote:Iemand91 wrote:TUI Netherlands' 767-300ER PH-OYI has been flown AMS-DGX last Monday prior freighter conversion.
Good conversion candidate, 20 years old, FADEC engines. Guess it's just waiting for a slot. DGX is a boneyard, but it's also a place to store aircraft. Not a great place (like Lourdes isn't a great place and yet a lot of the early Atlas conversions spent time there), but a place it is.
A380MSN004 wrote:What happened to the Atlas converted that were stored in Lourdes?
zkojq wrote:Turkmenistan Airlines' first A330-200P2F has been painted:
9H-AJN Airbus A330-200 @ Shannon, Feb 2023 by Warren Leak, on Flickr
Robert16627 wrote:Kalitta Charters II has retired N724CK with it being the first retired in the KII fleet, It was officially withdrawn from service Sept of 2022. It's already being used to keep the other 3 remaining 727's around and with that being said, 729CK is being retired by the end of this summer (2023) and 726CK will be the last 727 retired from their fleet in November of 2024. 725CK has an unannounced retirement date as of now.
wjcandee wrote:Just for the uninitiated, N725CK is the famous "Air Horse One", used by Tex Sutton horse transporter. Other of the 727s fill in when that frame is down or in maintenance, but 725CK is the one painted in the Tex Sutton livery and used most often on the horse runs.
Newark727 wrote:wjcandee wrote:Just for the uninitiated, N725CK is the famous "Air Horse One", used by Tex Sutton horse transporter. Other of the 727s fill in when that frame is down or in maintenance, but 725CK is the one painted in the Tex Sutton livery and used most often on the horse runs.
Was. Is now painted all-white, I believe.
LH982 wrote:9H-AJQ 332F has now arrived at Shannon from Dresden after conversion, for painting in Turkmenistan colours
stretch8 wrote:N230CM CAM B763 enroute ILN-HNL-GUM-QPG for BCF conversion. cheers!
The extended MD11 LOV is 40.000 cycles.
Compared to other aircraft built in the same era, the MD11 (derived from the "overbuilt" DC10, with an LOV of 60.000cycles) has relative few Widespread Fatigue Damage issues.
Consequently, the number of additional "aging aircraft inspections" during HMV is relative low
