WkndWanderer wrote:
They do quite a bit of online ads, I see their ads on IG all of the time.
enterusername wrote:Breeze likes to call themselves a "Tech Company that runs an airline", which is why their social media presence is the majority of their ads. The problem is a large chunk of the country doesnt do social media much.
nkops wrote:I noticed the MCO-SNA flight has been making stops in TUL enroute a lot lately. Is this due to an A220 being out of service, or is this more of a crew issue? Todays flight is 5 hours late with a TUL stop added.
flightsimer wrote:nkops wrote:I noticed the MCO-SNA flight has been making stops in TUL enroute a lot lately. Is this due to an A220 being out of service, or is this more of a crew issue? Todays flight is 5 hours late with a TUL stop added.
It’s been flown by an E190 on Odd dates westbound, which does not have the range for MCO-SNA. I believe but I’m not 100% sure it’s an aircraft availability issue.
TexasAirCorp wrote:The yet-to-commence ISP-RDU route has already been removed from sale after September 3rd, unclear whether it’s been permanently axed or just converted to summer seasonal (if the latter is the case, it would be an unusually early end however).
Seems odd they wouldn’t give winter service a go seeing as Frontier only operates the route seasonally.
TexasAirCorp wrote:enterusername wrote:Breeze likes to call themselves a "Tech Company that runs an airline", which is why their social media presence is the majority of their ads. The problem is a large chunk of the country doesnt do social media much.
If they'd launched in San Francisco, a 'tech company' airline might pull in a few punters, however most of Breeze's key cities have older populations that couldn't give a toss about an airline being 'techy'. Sounds an awful lot like WeWork...
Plus, I'd expect a 'tech company' airline to have a much better website/app, or to at least have WiFi on their entire fleet.
LAXintl wrote:The Airline Observer has a story on Breeze with an interview with president Tom Doxey.
In it he mentions how Breeze is aggressive in trying out and exiting markets that under perform and won't sit or nurse them for extended periods.
"We are not just going to let things go on and on and on, because we don't have the luxury of doing that," Doxey said. "But there's no defined time. It's not like there's a three month check-in point with a hurdle, and if it doesn't hit it, then it’s gone. It is much more nuanced."
"If every single market that you go into is a success, you're probably not being as creative as you should be,” he said.
The interview also covers how they are testing "Breeze-Thru" one-stop flights and offering connections.
"We're dipping a toe in to see: will this be beneficial enough that it is worth the added complexity?" Doxey said. "It's not an easy thing to do. You think, 'Oh, people get off, they get on, and you connect the bag.’ No. What happens when you misconnect? There are these things that, until you get into it, you don't realize how complex it is.”
Link (paywall)
https://www.theairlineobserver.com/p/br ... surprising
Seems Breeze is very much in the learning stages and trying to define its model and place and in market.
WkndWanderer wrote:
VX/AS also couldn't make SFO-RDU work, I know it was tried both as a day flight and redeye eastbound.
It worked for VX, just not for AS after the acquisition. Doesn't make much sense in the AS network. Also when UA started flying it 2x as they were pre-covid, it likely made it too thin for another carrier with no hub on either end.
mesasurf wrote:Does anyone know what’s going on with Breeze in SNA? Are PIT, CMH, CVG, gone? Also I hear the only reason they’ve added PVU-SNA 2x daily only a few times a week is that they are in danger of losing slots. Can anyone confirm this?
ifIHadWings wrote:nkops wrote:I noticed the MCO-SNA flight has been making stops in TUL enroute a lot lately. Is this due to an A220 being out of service, or is this more of a crew issue? Todays flight is 5 hours late with a TUL stop added.
I was on a Breeze flight May 19 out of MCO, and while there, a set of pilots arrived to fly a BC3 to MLB for repairs due to a ramp rash type accident the day before which damaged the plane. (The gate agent said something about either the plane hitting a set of stairs or a set of stairs being driven into the plane.)
My flight was delayed 20 hours (and switched from a BC3 to an E190) after an issue where the tug driver drove the tow bar into the nose gear (creating quite a thud) after push back. There wasn't an approved inspection procedure to return the plane to service that night (although the same plane was flown MCO to SNA the next afternoon, so I guess something was developed.) So that day, Breeze had two BC3s with unexpected maintenance issues, although one of those was back in service in a day. That seemed be a likely cause of the swap of an E190 flying SNA-TUL-MCO for a while instead of a BC3 flying SNA-MCO. By the way, it looks like they hired Swissport at MCO to perform ground handling.
Oh, and because of the 20 hour delay, they e-mailed the contact person for each booked passenger, suggested that people who needed a hotel for the night should book their own and submit the bill electronically to Breeze for a refund of up to $125 for two people sharing the room. (With a warning to not expect the refund for about 4 weeks.) They don't have staff (locally or remotely) to book hotel rooms in such cases. They also offered $125 in Breeze points to each passenger (but you have to set up a frequent flier account with them to get that). Due to the swap of aircraft type, they reassigned many seats but did not refund the optional seat selection fee unless you asked and then only if you were downgraded to a lower class of service (like wider seat to standard, or extra legroom to standard). If you didn't like your automatic re-seat, they were charging a second fee to select a different seat.
flightsimer wrote:mesasurf wrote:Does anyone know what’s going on with Breeze in SNA? Are PIT, CMH, CVG, gone? Also I hear the only reason they’ve added PVU-SNA 2x daily only a few times a week is that they are in danger of losing slots. Can anyone confirm this?
Breeze only has 3 slots, CVG/CMH/PIT all occupy a daily slot between the three, PVU occupy’s a daily slot as does MCO.
On SUN/MON/THUR/FRI, PVU is scheduled for a second daily flight, my guess using a fourth slot off of another carrier as there is no reduction in any other Breeze market to allow that from their own slots.
nkops wrote:flightsimer wrote:mesasurf wrote:Does anyone know what’s going on with Breeze in SNA? Are PIT, CMH, CVG, gone? Also I hear the only reason they’ve added PVU-SNA 2x daily only a few times a week is that they are in danger of losing slots. Can anyone confirm this?
Looks all 3 are considered seasonal as they all end beginning of September.. not sure what MXY is doing with the slot after that
CobaltScar wrote:This airline is not long for this world. Slow A220 deliveries and a work force that is connected to social media and demands living wages will see to that.
diverdave wrote:CobaltScar wrote:This airline is not long for this world. Slow A220 deliveries and a work force that is connected to social media and demands living wages will see to that.
Yet despite all of the contempt shown in this thread, Breeze has been operating now for two years.
David
Manderson12 wrote:The word is losing. Most airlines do lose money as a start-up. But the fact is, it's not your money or mine, so whoever is investing must have some belief that they will be profitable in time. You doomsayers keep announcing their demise, but they keep announcing new routes with airports continuing to clamor for their services.
Manderson12 wrote:It all depends on where they fly from Charleston. MCO, I believe will be successful flying from Charleston WV, Spirit flew that route for years until they became a target to be bought out by JetBlue. I don't' really know the Charleston WV market that well, so other markets I can't speak on. I will say with Breeze making it through two years and still growing, that rumors of it's demise is greatly exaggerated.
ty97 wrote:Apologies if this is already well understood here, but I'm not clear on Breeze's fleet plan. I know they planned to be a 220-300 airline but then leased some used E190/E195 to start service before their 220s arrive. What's the medium term plan for the E190/E195? Will they go away as more 220s arrive or is Breeze planning to keep the E190/E195s until end of life?
TexasAirCorp wrote:ty97 wrote:Apologies if this is already well understood here, but I'm not clear on Breeze's fleet plan. I know they planned to be a 220-300 airline but then leased some used E190/E195 to start service before their 220s arrive. What's the medium term plan for the E190/E195? Will they go away as more 220s arrive or is Breeze planning to keep the E190/E195s until end of life?
To be honest, I don’t think anyone on here really understands it either.
As far as I’m aware, the Embraers will now remain in the fleet at least in the medium term, operating alongside the A220s. As much as the latter are great, they’re very expensive to operate on short routes, which I think MX may have initially overlooked and have only just realised, hence the plan seems to be to have the Embraers focus on shorter routes and leave the A220s to operate transcons and a few slightly longer regional services.
JoseSalazar wrote:They were always part of the long term plan for shorter segments; and why their management believed (believes?) WiFi/entertainment and charging wasn’t necessary for such short segments, but the a220s would have power and eventually WiFi and wifi based BYOD IFE. They were supposedly exploring trying to get every used 195 they could get their hands on and growing that fleet to 100+.
E190s were never part of the original plan because their casm just doesn’t work with that business model. But the lease they got during covid made them reassess that and the numbers worked with that lease agreement. But from what I’m hearing from friends there, the 190s don’t seem to do much other than charters these days, and I question how long they’ll keep those around. But like everything, business plans are constantly changing reacting to changes in the landscape. Just like jetblue has gone back and forth with the 190s from getting rid of them, to keeping 30 indefinitely, back to getting rid of them asap, I could see breeze doing the same and changing plans as the landscape changes.
mooseofspruce wrote:N145BZ
Noahjk wrote:I was at JAX today and counted 5 Breeze E190s. Not at gates but at hard stands. I don’t think JAX has this many sports charters going on. Is there an Embraer maintenance facility at JAX? Or what is the reason?
cactus13 wrote:Noahjk wrote:I was at JAX today and counted 5 Breeze E190s. Not at gates but at hard stands. I don’t think JAX has this many sports charters going on. Is there an Embraer maintenance facility at JAX? Or what is the reason?
They are operating a temporary "summer" base from JAX. 5 planes and crews TDY from other bases.
TexasAirCorp wrote:Another round of moronic route additions from Breeze:
RDU-LAS (3x weekly)
RDU-TPA (3x weekly)
PWM-MCO (2x weekly - winter seasonal)
Breeze will be the fourth airline flying to LAS and the fifth airline to TPA from RDU, and will compete with Frontier on PWM-MCO.
The strategy of 'unserved routes' seems to now be well and truly lost. I fail to see any reason as to why there's sufficient lack of supply in any of those markets to warrant a profitable Breeze entry. Even Avelo isn't doing overly well on RDU-TPA. Breeze is in essence now a regional airline that flies completely random routes, essentially Elite Airways but with fancier marketing.
TexasAirCorp wrote:Frontier flies PWM-MCO Saturday only. Breeze will be four weekly, two non-stops and 2 same plane thru flights.Another round of moronic route additions from Breeze:
RDU-LAS (3x weekly)
RDU-TPA (3x weekly)
flightsimer wrote:I am happy you rebutted the previous forumers who have no clue about MX strategy. Common sense would tell someone that if you are going to operate 80 A-220 aircraft, at some point you are going to go to have to go head to head with other airlines. If the choice is between legacies and MX many fliers are choosing MX due to price and quality of their aircraft if the schedules fit. I am sure that is what Breeze have discovered.TexasAirCorp wrote:Frontier flies PWM-MCO Saturday only. Breeze will be four weekly, two non-stops and 2 same plane thru flights.Another round of moronic route additions from Breeze:
RDU-LAS (3x weekly)
RDU-TPA (3x weekly)
Additionally, the RDU adds are not individual routes. It’s TPA-RDU-LAS, which will bring the TPA-LAS service up to 10 weekly.
RDU-LAS (3x weekly)
RDU-TPA (3x weekly)
FLYKTPA wrote:TexasAirCorp wrote:Another round of moronic route additions from Breeze:
RDU-LAS (3x weekly)
RDU-TPA (3x weekly)
Northeast to Florida in the winter is the opposite of moronic…
TPA-RDU keeps aircraft flowing throughout the network and helps with crew scheduling. It’s also an easy fill. Same with LAS-RDU.
