77west wrote:What's actually the holdup right now?
frmrCapCadet wrote:Is there any chance that the 'learning the process' for certification lessons from finishing the MAX 7 and 10 could speed up the process for the 777X? Both Boeing and the FAA have some learning to do.
757Boii wrote:Spoke to a Boeing employee I saw at the store yesterday. I asked about the 777x program, they said this year will be a big year for the 777-9. N779XW will continue testing (resumed today), N779XX will start back up this month, N779XY will start back up in April, and N779XZ will start back up in July. All four planes will be actively flying this summer as TIA approaches.
Rhal97 wrote:
TIA is expected middle of the year
Rhal97 wrote:TIA is expected middle of the year
FrenchPotatoEye wrote:That is do be determined. It good aspirations but all depend on faa. We shalls see.
We shalls see.
Stitch wrote:Rhal97 wrote:TIA is expected middle of the yearFrenchPotatoEye wrote:That is do be determined. It good aspirations but all depend on faa. We shalls see.
Indeed, but if Boeing is putting the 777X test fleet back into regular circulation, it could be a sign that they and the FAA have settled on what needs to be done prior to the FAA granting TIA and Boeing has reactivated the fleet to both complete those tasks and to have the full fleet available for work once TIA had been granted,.
Rhal97 wrote:757Boii wrote:Spoke to a Boeing employee I saw at the store yesterday. I asked about the 777x program, they said this year will be a big year for the 777-9. N779XW will continue testing (resumed today), N779XX will start back up this month, N779XY will start back up in April, and N779XZ will start back up in July. All four planes will be actively flying this summer as TIA approaches.
He’s right. N779XX starts January 13th: source Matt Cawby
http://kpae.blogspot.com/2023/01/paine- ... 5.html?m=1
It seems like they’ve basically started the flight test program again, following Boeings changes. So now just doing flight control regression etc etc
wesk wrote:Almost 5 months to the day since it’s last flight, it’s good to see n799xx up in the air.
Ellofiend wrote:How is production being handled? As I understand it, there are ~27 aircraft sitting in various states of construction, how many do they plan to produce before certification?
Stitch wrote:Ellofiend wrote:How is production being handled? As I understand it, there are ~27 aircraft sitting in various states of construction, how many do they plan to produce before certification?
Boeing has paused 777X production through the end of 2023: https://www.seattletimes.com/business/b ... ure-costs/
JerseyFlyer wrote:EASA and Boeing "closer" to agreement about flight control matters:
"Europe's chief aviation regulator pointed on Tuesday to a narrowing gap in talks with Boeing (BA.N) over cockpit design requirements for the future 777X airliner.
"European regulators have been seen at odds with Boeing for more than a year over changes they want in flight controls of the latest version of the 777 - a stand-off that has contributed to a cumulative five-year delay, according to industry sources.
"EASA has set out an approach that could prompt Boeing to add an extra fallback to guarantee that a single invisible failure within the cockpit's electronics cannot trigger simultaneous outages - a design precaution known as "dissimilarity"."
https://www.reuters.com/business/aerosp ... 023-01-24/
The Primary Flight Computer (PFC) is the central computation element of the FBW system. The triple modular redundancy (TMR) concept also applies to the PFC architectural design. Further, the N-version dissimilarity issue is integrated to the TMR concept. The PFCs consist of three similar channels (of the same part number), and each channel contains three dissimilar computation lanes.
Avatar2go wrote:It seems the dispute on "dissimilarity" is due to the extension of the concept of Triple Modular Redundancy (TMR), to hardware & software vendors, as is done in Airbus FBW systems.
Boeing has taken a different approach with the 777 FBW, using TMR but with the same hardware in the redundant channels, and engineering dissimilarity into the computational paths instead, to trap common mode errors.The Primary Flight Computer (PFC) is the central computation element of the FBW system. The triple modular redundancy (TMR) concept also applies to the PFC architectural design. Further, the N-version dissimilarity issue is integrated to the TMR concept. The PFCs consist of three similar channels (of the same part number), and each channel contains three dissimilar computation lanes.
The Boeing position is that they have established the same statistical and experiential level of safety, without the need to rely on differential hardware.
The EASA position is that differential hardware eliminates the possibility of common mode errors entirely. Which creates a better solution than monitoring and trapping them.
This is all somewhat academic and esoteric, as neither platform has suffered from common mode failures. But it goes to design philosophy. EASA would prefer to see the differential hardware solution more widely adopted.
The FAA is essentially neutral, I suspect they don't see an inherent superiority in either solution. But nor are they averse to improvements in safety.
My guess is that Boeing and EASA are negotiating on how those improvements can be made within the 777x TMR implementation.
morrisond wrote:
Great - make things more complex. That usually works out well. The current design works well - no need to change it.
Agree. Easa and the faa seem hell bent on the punishment for Boeing on 777x.
And there no improvement to suggests that safety is upped.
enzo011 wrote:
Need to drop the victim mentality. Boeing is a corporation that does not have feelings. It does seem like the contention here is that EASA is out to make things difficult for Boeing and not to improve safety. That is what we are saying here now?
Airlinerdude wrote:Has anything additional on the GE9X issue been made public yet?
Avatar2go wrote:There's no suggestion in any of this that EASA has any hostile intent. It's just a matter of deciding the best approach to implement dissimilarity within triple redundancy. The discussion is ongoing and Boeing has not objected to any of it.
enzo011 wrote:
Take it up with the posters I replied to. They seem to suggest that EASA is only making things more complicated and not safer and that the FAA and EASA is out to punish Boeing. Would be nice to call out them directly instead of replying to me to sort of defend them.
enzo011 wrote:Avatar2go wrote:There's no suggestion in any of this that EASA has any hostile intent. It's just a matter of deciding the best approach to implement dissimilarity within triple redundancy. The discussion is ongoing and Boeing has not objected to any of it.
Type Inspection Authorization (TIA): The TIA is an internal FAA document that authorizes the ACO employees to begin the test program, usually the flight test portion. It is the FAA “kickoff” document, and is fully described in Order 8110.4B. When the TIA is issued, Boeing people will celebrate because it means; “Let’s do it”.
tootallsd wrote:Does a design, firm enough to build airframes, even exist for the -8 or -8F?
