Runway765 wrote:Happy New Year!
It’s gonna be an interesting year for BNA. The Terminal Lobby/IAB and the Satellite will open, bring much needed additional gates and a proper FIS facility.
What new service do you expect?
SimpleMan wrote:Runway765 wrote:Happy New Year!
Not to be a "Wish Pig" but CVG, PDX and continuation of IND, CUN and SJU.
Bluegrass60 wrote:"Unless WN picks up CVG and IND(connecting traffic via BNA)...not going to happen until short haul flying point-to-point make$ sen$e again. Curious if anyone thinks recent WN meltdown has any impact on WN operations/plans for BNA in 2023/2024? Any chance that WN takes gates in the satellite? Seems that would make sense for WN to use for those flights that are more connection oriented (vs O&D oriented).?
TYSflyer wrote:Runway765 wrote:Happy New Year!
I am impressed with how quickly the satellite terminal has taken shape. I saw a picture of it this morning. Is there an anticipated opening date yet?
jplatts wrote:Bluegrass60 wrote:"Unless WN picks up CVG and IND(connecting traffic via BNA)...not going to happen until short haul flying point-to-point make$ sen$e again. Curious if anyone thinks recent WN meltdown has any impact on WN operations/plans for BNA in 2023/2024? Any chance that WN takes gates in the satellite? Seems that would make sense for WN to use for those flights that are more connection oriented (vs O&D oriented).?
The O&D PDEW of BNA-CVG has never exceeded 20 passengers/day in the last 15 years, and the O&D PDEW of BNA-IND has never exceeded 12 passengers/day in the last 15 years.
BNA-ATL is the only route shorter than BNA-CVG that has WN nonstop service out of BNA, but BNA-ATL has significantly more O&D demand than BNA-CVG does. BNA-ATL is also a hub-to-hub nonstop route for WN. The O&D PDEW of BNA-ATL on WN was 72 passengers/day in Q2 2022, and the total O&D PDEW of BNA-ATL was 234 passengers/day in Q2 2022.
BNA-STL is the 2nd shortest route out of BNA that is served nonstop by WN, and the O&D PDEW of BNA-STL was 100 passengers/day in Q2 2022. BNA-STL is longer than BNA-CVG/IND, and WN is also connecting some passengers to destinations such as DSM/OKC/OMA/TUL/ICT from BNA through STL.
BNA-CLT is the 3rd shortest route out of BNA that is served nonstop by WN, but BNA-CLT has significantly more O&D demand than BNA-CVG does. The O&D PDEW of BNA-CLT on WN was 66 passengers/day in Q2 2022, and the total O&D PDEW of BNA-CLT was 323 passengers/day in Q2 2022. The great circle distance of BNA-CLT is 328 miles, but BNA-CLT O&D demand is stronger due to the longer driving distance between Nashville and Charlotte. The driving distance to Downtown Charlotte is 410 miles from Downtown Nashville, and Downtown Charlotte is approximately a 6 1/2 hour drive from Downtown Nashville.
There are a few WN nonstop routes such as ATL-GSP, MDW-GRR, COS-DEN, and RSW-MCO that have very little O&D traffic and are operated primarily for connections. The WN routes out of BNA that currently have daily nonstop service have more O&D traffic than routes such as ATL-GSP, MDW-GRR, COS-DEN, and RSW-MCO.
There are also bigger holes at BNA than the lack of BNA-CVG/IND nonstop service.
SimpleMan wrote:Thank you for your data and analysis. I was just assuming that the daily PDEW between the two (2) cities, IND & CVG would be larger if just for the size of the cities and VFR.
FlyingElvii wrote:And yet, CVG-BNA was one of Comair’s top 10 most profitable runs pre-CRJ, supporting 6-10 EMB-120’s a day at times, and before BNA’s economy took off…
UALFAson wrote:SimpleMan wrote:Thank you for your data and analysis. I was just assuming that the daily PDEW between the two (2) cities, IND & CVG would be larger if just for the size of the cities and VFR.
Indianapolis and Cincinnati aren't really that large of cities and, more importantly, don't have a ton of business ties to Nashville. Unlike Atlanta, which serves as a regional finance and consulting hub and generates much more business travel, including day trips.
VFR aren't going to pay hundreds of dollars to fly from BNA just to IND or CVG; they're going to make the relatively easy 4ish-hour drive instead. The economics of these super-short air routes don't work anymore and I highly doubt WN or anyone is going to start service to either destination anytime soon.FlyingElvii wrote:And yet, CVG-BNA was one of Comair’s top 10 most profitable runs pre-CRJ, supporting 6-10 EMB-120’s a day at times, and before BNA’s economy took off…
And yet, how much of that profit derived from BNA customers making connections in CVG on flights and to cities that DL no longer serves? As DL continues to grow ATL into a megahub, they have seemingly decided that it makes more financial sense to route connections through there on 737-900s every 90 minutes or so than to also be routing connections through CVG just up the road, relatively speaking.
UALFAson wrote:FlyingElvii wrote:And yet, CVG-BNA was one of Comair’s top 10 most profitable runs pre-CRJ, supporting 6-10 EMB-120’s a day at times, and before BNA’s economy took off…
N292UX wrote:Nashville to Cincy is about a 4 hour drive according to Google Maps. If you were to be flying from Nashville to Cincinnati, you'd maybe save 1-1.5 hours of total travel time when all is said and done. So really not worth it without connections on one end or the other.
DL ran CVG-BNA but till 2018 (I believe) and eventually cut it because of the above reasons.
N292UX wrote:DL ran CVG-BNA but till 2018 (I believe) and eventually cut it because of the above reasons.
Cubsrule wrote:N292UX wrote:DL ran CVG-BNA but till 2018 (I believe) and eventually cut it because of the above reasons.
At the end, it was running pretty much exclusively to get OO aircraft in and out of maintenance at BNA. BNA's market strength saved it in the sense that BNA didn't have a lot of other OO DL Connection service.
Bluegrass60 wrote:Speaking of connecting traffic...WN connects 32.9% of its traffic at BNA. Without that connecting flow....WN flights would operate with LF of 54.6%.
Here is the source of that info: https://www.aviationplanning.com/monday-january-2-2023/
HeyHey wrote:BNA had a total of 20,045,685 passengers fly in or out during calendar year 2022. BNA flew 15,516,601 passengers in 2021. That represents a 29% relative increase and an absolute increase of 4,529,084 passengers.
bnabnabna wrote:More photos of the lobby courtesy of the Business Journal here: https://www.bizjournals.com/nashville/news/2023/01/20/nashville-international-airport-grand-lobby-photos.html
I can’t wait to see in person in just over a week! The hanging art installation, live murals, and electronic screens all look incredible.
"We have 95 nonstops," said Kreulen. "Our new goal is 135. In September when we open our new international arrivals facility, we'll go from one international gate to six. So we're really hoping to get a second nonstop service to Europe, probably somewhere in Central Europe, and then eventually into Asia."
dfdubflyer wrote:"We have 95 nonstops," said Kreulen. "Our new goal is 135. In September when we open our new international arrivals facility, we'll go from one international gate to six. So we're really hoping to get a second nonstop service to Europe, probably somewhere in Central Europe, and then eventually into Asia."
So that sounds like Frankfurt on Eurowings Discover if he's to be taken at face value? Amsterdam certainly isn't central Europe.
pdt2f wrote:I’m fascinated about what 40 destinations could be added to get to 135, without us becoming a hub. It would take quite the WN expansion to get to that point.
gsg013 wrote:pdt2f wrote:I’m fascinated about what 40 destinations could be added to get to 135, without us becoming a hub. It would take quite the WN expansion to get to that point.
Think of what dots on the map are missing… A couple off the top of my head are Palm Beach and Westchester County. Interested to hear what other 38 dots on the map they want to add.
1. PBI (southwest would likely be all over this one)
2. HPN
Runway765 wrote:pdt2f wrote:I’m fascinated about what 40 destinations could be added to get to 135, without us becoming a hub. It would take quite the WN expansion to get to that point.
WN already has a hub in all but name only here. They will be picking up 4 additional gates when the satellite and IAB opens in the fall, bringing them to 20. I could see them getting to 165-175 flights by summer 2024.
pdt2f wrote:Runway765 wrote:pdt2f wrote:I’m fascinated about what 40 destinations could be added to get to 135, without us becoming a hub. It would take quite the WN expansion to get to that point.
Oh I could totally see them ramping up flight numbers like that or higher, my question was more regarding where all these desired locations are. I can think of maybe 10-12 domestic locations WN could realistically pick up if they have the gates and aircraft, but that still leaves a lot. Hopefully they add a bunch of Caribbean and Central American destinations eventually. We’re geographically placed to be a good connecting point sending northeastern and midwestern travelers to Florida, the Caribbean, and Central America if WN so desired to use BNA that way.
reednavy wrote:pdt2f wrote:I’m fascinated about what 40 destinations could be added to get to 135, without us becoming a hub. It would take quite the WN expansion to get to that point.
Shhh, the secret is AA pulling an AUS situation.
2. HPN
GSP psgr wrote:gsg013 wrote:pdt2f wrote:I’m fascinated about what 40 destinations could be added to get to 135, without us becoming a hub. It would take quite the WN expansion to get to that point.
2. HPN
1) BZN: BNA makes sense as a flow point for traffic from the Southeast and Mid-Atlantic to get up to Yellowstone.
2) GSP: I still don't entirely get why WN keeps ATL-GSP going, unless they think the traffic flows to Florida really are that much better. I think they'd pick up more O&D at the cost of a marginally longer stage length (offset by a much less congested BNA).
3) PVD: For Northeast-Southeast flow traffic as an alternative to BWI. WN doesn't fly PVD-ATL.
4) BUF: Ditto. ROC/ALB/SYR would also make sense in that vein, but BUF's the biggest and closest to BNA. WN doesn't fly BUF-ATL.
5) TUL: Makes sense as a spoke. Notable that WN doesn't have any TUL-Southeast (non-Texas) flights at all, even Florida.
6) GRR: GRR-BNA would make sense as a year round flow point for Southeast traffic. Not served from Atlanta.
7) DSM: Ditto GRR.
As far as a sort of out of the box international route not on WN: Copa to PTY? BNA's kind of a similar market to MSY and they fly that.
DakotaFlyer wrote:I would not be surprised to see some Mexican/Latin carrier set up shop at BNA. Nashville-Metro has a 10% Latin Population and certainly plenty in the outside cities. Additionally, lot of business connections between Mexico/Nashville.
pdt2f wrote:We’re geographically placed to be a good connecting point sending northeastern and midwestern travelers to Florida, the Caribbean, and Central America if WN so desired to use BNA that way.
southwest1675 wrote:reednavy wrote:pdt2f wrote:I’m fascinated about what 40 destinations could be added to get to 135, without us becoming a hub. It would take quite the WN expansion to get to that point.
It's likely hearsay, but AA employees I know at BNA says an AUS esque operation is coming. How likely will it happen? Maybe just as much as UA's planned southeast BNA megahubI know it's been metioned numerous times on the BNA thread, but I think this airport could use a little expansion from a legacy carrier. Not everyone wants to fly WN.
