B717fan wrote:Unconfirmed reports that he was sucked into one of the engines. A very horrifying accident. RIP to the worker.
Scoots71 wrote:
FlyingElvii wrote:B717fan wrote:Unconfirmed reports that he was sucked into one of the engines. A very horrifying accident. RIP to the worker.
Ugh….
Cannot imagine….
Was only a few hundred feet away from the Airlink incident at Memphis many years ago. It is why I am so hard on the newbies about ramp safety.
Ugh….
Cannot imagine….
Scoots71 wrote:FlyingElvii wrote:B717fan wrote:Unconfirmed reports that he was sucked into one of the engines. A very horrifying accident. RIP to the worker.
Ugh….
Cannot imagine….
Speaking of training at MGM, the E175 would be the largest aircraft they see at that airport. Typically it only sees CRJs or E145s. There probably was not adequate training (or at least routine exposure to ended training) for the ground crew with that aircraft. Also considering it was a Piedmont ground crew working and Envoy flight.
Ugh….
Cannot imagine….
Ugh….
Cannot imagine….
Vio wrote:Did they have to start one of the engines at the gate?
*edit: Disregard. Seem like the plane was arriving at the gate, not departing.
n797mx wrote:Vio wrote:Did they have to start one of the engines at the gate?
Where do you see they were arriving?
The idle thrust of the -175 is only about 800lbs thrust per engine which is basically nothing. If they were doing an air start (APU was inop) it would make more sense since you've got to get the bleeds up to 40 PSI to start. Their huffer cart is placed in the videos/pictures available too.
YQGflyer wrote:RIP, absolutely horrific. I remember during training for a ramp job they showed us pictures of the aftermath of a Continental AME going through a 737 engine and, while it was quite gruesome, it was a stark reminder of how dangerous of a working environment it can be. Not that it is much consolation, but it was likely quick and painless.
pugman211 wrote:Why would anyone want to open a baggage hold unless they verified both engines were off?
Rip to the person involved.
CALTECH wrote:Have seen folks on the ramp drive/walk behind running engines. All their equipment blows off, one guy went skidding across the ramp.
https://www.youtube.com/watch?v=TMY-GHpSmX4
Another possibility is the APU was Inop, engines running till ground power hooked up. Saw it a lot with Yellow Airplanes, engines running and people moving towards the airplane. It became better in the past few years, until grd power was hooked up, no one approached the plane. May the worker RIP. Horrific way to go....
Ugh….
Cannot imagine….
Fixinthe757 wrote:Scoots71 wrote:FlyingElvii wrote:
Ugh….
Cannot imagine….
A plane is a plane no matter what paint job it has or who operates it. What difference does it make?!
Ugh….
Cannot imagine….
CALTECH wrote:YQGflyer wrote:RIP, absolutely horrific. I remember during training for a ramp job they showed us pictures of the aftermath of a Continental AME going through a 737 engine and, while it was quite gruesome, it was a stark reminder of how dangerous of a working environment it can be. Not that it is much consolation, but it was likely quick and painless.
https://aviation-safety.net/wikibase/165878
It wasn't a Continental AME, he was a contractor, close to retirement. El Paso, Flight 1515, 737-500 Fleet Number #626. Engine run for a oil leak, engine was taken up in power. His baseball cap came off and he went to grab it towards the inlet. The after photos are horrific.
May he RIP, poor soul...
jetmatt777 wrote:pugman211 wrote:Why would anyone want to open a baggage hold unless they verified both engines were off?
Airline management speaks out of both sides of their mouth. They want these arrival baggage scanning metrics to show baggage scans within 2 minutes of arrival. These contractor companies get dinged financial penalties for not hitting these metrics. They preach safety but monetarily penalize safe actions.
Airline management penalizes APU usage if ground power is available, so pilots often leave engines running at the gate for long durations of time until ground power can be connected (usually after the jetway is attached).
It’s customary for E175 operators to shut down that side’s engine as they are turning into the gate so it is usually completely spooled down by the time they set the brake. Always look twice.
Caspian27 wrote:My guess is that they were trying to put the caution cone in front of the engine. I very nearly had a similar incident at my pervious airline in a 175 without an APU. Ramper in training was approaching the running left engine to put the caution cone in front of it but we were waiting for the jetbridge to be pulled up so we could get ground power before shutting the engine down. Ended up quickly shutting down the engine as the ramper approached the engine while opening the window and yelling at them to get back.
There was also a video on YouTube of an American E175 where this exact thing happened but only the cone got sucked into the engine.
Prayers for the family.
BB78710 wrote:. But this unfortunate accident should serve as a wake up call to all carriers that they need to make sure with so many new hire their employees understand just how dangerous and deadly the ramp can be. All it takes is one mistake, one distraction and you're not going home, working on the ramp can cost you your life if you are not paying 100% attention 100% of the time.
F9Animal wrote:pugman211 wrote:Why would anyone want to open a baggage hold unless they verified both engines were off?
That is a "no no" on any ramp operation. I have had last minute bags show up after the engines have started or the push has began. 99.9% of the time, that plane is going without those bags. I have had some very rare occasions where I asked the Captain for permission to load some last minute bags, and they turned off #2 so we could load them. I can count on one hand how many times that has happened in my 20 years as a ramper.
I am under the impression this may have been an air start. Sadly, these are not a common procedure, and we all get a little brain fart sometimes when they do happen. Especially if you work a ton of different aircraft types, you tend to get fuzzy when it comes to placement of the air start cart. I do hope more details come out on how this happened, as most of us on here work around planes. It's a valuable learning experience to prevent something like this from happening again. My condolences to the rampers loved ones.
Silver1SWA wrote:Someone please correct me if I’m wrong but one thing I’ve observed while driving around service roads at multiple airports is that unlike my airline, no one else seems to have a signal from their marshaller that tells the rest of the ramp crew that the engines are cut and it’s safe to enter the safety zone. At my airline the captain gives a deliberate signal to the marshaller once the engines are shut down and the marshaller gives a clear signal to everyone that says engines cut, safe to enter. No one is to enter the zone until that signal is given. But when driving behind other airlines as they pull in to the gate I have to rely on the sound of the engines shutting down because nobody signals to each other or me that it’s safe to proceed.
I always thought that was odd.
alasizon wrote:Silver1SWA wrote:Someone please correct me if I’m wrong but one thing I’ve observed while driving around service roads at multiple airports is that unlike my airline, no one else seems to have a signal from their marshaller that tells the rest of the ramp crew that the engines are cut and it’s safe to enter the safety zone. At my airline the captain gives a deliberate signal to the marshaller once the engines are shut down and the marshaller gives a clear signal to everyone that says engines cut, safe to enter. No one is to enter the zone until that signal is given. But when driving behind other airlines as they pull in to the gate I have to rely on the sound of the engines shutting down because nobody signals to each other or me that it’s safe to proceed.
Not sure who you work for but almost every carrier doesn't do that. That is the whole point of the beacon. Beacon on = don't approach.
