DIRECTFLT
Passenger Opens door before landing Asiana A321
Fri May 26, 2023 7:03 am
https://www.cnn.com/2023/05/26/asia/sou ... index.html
An airline official said a man in his 30s who was sitting at the emergency seat seemed to have opened the door when the aircraft was about 700 feet (213 meters) above the ground and about two to three minutes from landing in the city 150 miles (240 kilometers) south of Seoul.
The aircraft was identified on the Flightradar 24 tracking website as an Airbus 321.
The jet was on a flight from Jeju island, off South Korea’s southern coast, to Daegu.
readytotaxi
Re: Passenger Opens door before landing Asiana A321
Fri May 26, 2023 9:43 am
Picture of the open door once landed here.
https://www.bbc.co.uk/news/world-asia-65705276
SuseJ772
Fri May 26, 2023 11:00 am
DIRECTFLT wrote:
https://www.cnn.com/2023/05/26/asia/south-korea-plane-door-opens-midair-intl-hnk/index.html
Something’s not quite right in that math. 700 feet above the ground would only be about a minute before landing. Not 2-3 minutes, no?
Other than that, the rest of the facts seem plausible.
ReverseFlow
Fri May 26, 2023 11:10 am
https://youtu.be/EeNc2dMn80g
Here's a video from inside.
mjgbtv
Fri May 26, 2023 11:16 am
Those figures seem rather approximate. Maybe 'about 700 feet' was actually 1000 and 'about two to three minutes' was actually 90 seconds which I guess would seem more plausible?
Ziyulu
Fri May 26, 2023 11:33 am
Or it might be 700 meters?
LabQuest
Fri May 26, 2023 12:38 pm
Well I guess this puts to rest of oft asked question about the possibility!
Babyshark
Fri May 26, 2023 1:16 pm
Welp. I guess i am going to eat my crow with zaxbys sauce. It’ll be fun.
trueblew
Fri May 26, 2023 1:27 pm
It certainly is fortunate the door remained attached to the aircraft. Dreadful if it were to become detached and strike the tail assembly.
Revo1059
Fri May 26, 2023 1:46 pm
When the cabin is pressurized at higher altitudes then it's a different story.
smi0006
Fri May 26, 2023 1:55 pm
Why didn’t the slide deploy? Surely the Pax didn’t disarm the door before opening it?
bhxdtw
Fri May 26, 2023 1:59 pm
Man, those people in the vicinity of the door got a good blast of fresh air. Terrifying. I wonder if the airline will compensate passengers somehow. Imagine if there were ultranervous flyers a row away lol... my mom would never set foot on a plane again. Thankfully it ended well for everyone
Ionosphere
Fri May 26, 2023 2:00 pm
The slide deployed but it was ripped off by the wind
zuckie13
From the photo in the link in the 2nd post - looks like it probably did deploy - and was probably ripped off. Obviously not designed for deployment with the plane moving at flight speed.
cathay747
Fri May 26, 2023 2:05 pm
This belies the belief that these "translating" type of doors can't be opened in flight. I've always thought it was bull. If it opens by first moving outward, it can be opened inflight, unless I'm way off. Please correct me if I am, but...give me an "old-style" Boeing or Douglas plug door any time and twice on Sunday's. Seems they are much less complicated as well. I'll never understand why Boeing moved away from them.
Fri May 26, 2023 2:11 pm
In flight people would normally refer to up much higher. This is plug door, it needs to be unplugged to translate. And can only do so when very close to the ground where the pressure differential is close to zero.
WayexTDI
Fri May 26, 2023 2:18 pm
You can remove the "probably": the photo clearly shows the slide compartment open and remnants of the slide. The door and the slide are gone.
lostsound
Fri May 26, 2023 3:03 pm
The door is still attached according to outside photos.
Edit: oh I see you must mean the slide door.
WayexTDI
Fri May 26, 2023 3:44 pm
Slide compartment door; we were talking about the slide.
rj777
Fri May 26, 2023 3:46 pm
Will the plane be able to fly again? How much repair work will need to be done?
CrewBunk
Fri May 26, 2023 4:03 pm
Also, the operation of these exits is similar to the main cabin doors, in that if opened when armed, they are “powered” open by a pneumatic cylinder which will push the door open to the stop, then lock there.
Likely, that is how it was able to open so far, then stay open against the airflow.
At that point in the approach, the cabin is all but unpressurized.
cathay747
Fri May 26, 2023 4:21 pm
Not understanding your first sentence, but...it may be a "type" of a plug door, but not in the traditional sense in my mind, like doors on DC-jets and all Boeing's prior to the 777, where the door must first move inward before in is able to rotate outwards. And close-to-zero pressure diff clearly is now not good enough, there needs to be a fail-safe lockout to prevent inflight opening, such as a wheels-on-ground switch like for the spoilers...in these days of lunatics on planes!
strfyr51
Fri May 26, 2023 4:51 pm
thev inspection on that door and the door latches will be extensive. once they have it inspected and the door closed then the internal door structrure might have to be repaired if the door is tweaked and out of contour.
stewartg
Fri May 26, 2023 4:54 pm
I've seen that the FA has to turn off some RED light, indicating to the ground personnel that the door is safe to open without popping his eye out due to pressure.
Pontiac
Fri May 26, 2023 4:59 pm
"It is particularly dangerous during landing and takeoff, so someone from the flight staff should have stopped that passenger," said Sohn Myong-hwan, a professor at South Korea's Sehan University's aviation maintenance department.
You go right ahead, Sohn. I will be here belted in and not falling out of the plane.
Polot
Fri May 26, 2023 5:11 pm
That’s about disarming the door, so ground personnel can open it without the slide activating.
Theseus
Fri May 26, 2023 5:29 pm
I see what you mean, but I believe what you suggest is a big, big, big no.
That would mean that, in case of something like a crash landing where sensors may be destroyed / fail, passengers might be trapped inside the plane when they should evacuate. Or maybe some doors would fail to open due to the "safety" system that you suggest. Having a switch controlled by the crew would mean that it would not work if the crew is incapacitated. All in all, I do not see a "simple" way to make this work, without creating even much greater problems.
From a safety standpoint, what you ask for would seem very hard to specify and certify.
F9Animal
Fri May 26, 2023 5:41 pm
Wow, this has to be causing some scrambling in airline security departments. Not only that, but this gives creeps more reason to attempt it. I wonder what this jerks hopes were? I hope he is going through some hard interrogation right now.
I have been under the belief it was impossible to open an emergency exit while the aircraft was in the air. Is it true when the plane is higher and pressurized that it is impossible? I also find it crazy the door was able to open against the wind like that! Talk about some solid built machinery right there!
stewartg
Fri May 26, 2023 6:02 pm
Amazing it hasnt happened before. Thousands of flights a day with the risk of a mentally challenged person sitting in a seat next to an exit door or window. We know that sometimes even teenagers do stupid things without regard to risk.
N14AZ
Fri May 26, 2023 6:26 pm
That’s exactly what I’m asking myself since I heard about this story. We had cases where people tried to open emergency exits on the ground when they thought it would be too hot in the cabin. But I guess this is wasn’t the case in this incident. I guess mental health issues… :-/
FlyingHonu001
Fri May 26, 2023 6:55 pm
Most doors have a powered assist mechanism that speeds up the outward swing to aid in rapid evacuation. Most likely this was triggered because the door was in armed mode. The lock is a so-called built-in 'gustlock' to prevent the door from moving during windy conditions when fully open with the plane stationary on the ground.
Its definitely not designed for high velocity 'air speed winds', the door seems to be unhinged judging from the after photos
CrewBunk
Fri May 26, 2023 7:07 pm
Ya think? ;)
The main cabin doors have a wind limit speed of 65 knots. I would assume the cabin emergency exit doors are similar. It’s not in my AOM as I’m guessing opening it is a maintenance function, unless in an emergency where external wind speeds are irrelevant.
questions
Fri May 26, 2023 7:13 pm
At what point, ie, zero to _____ feet, is the cabin typically unpressurized enough that the doors and emergency window exits can be opened?
TWA772LR
Fri May 26, 2023 7:19 pm
Bro let the intrusive thoughts win.
Interesting that the door was still able to slide noseward while still inflight and hang on. Usually a run away jetbridge can rip it right off.
Tristarsteve
Fri May 26, 2023 7:23 pm
The RED light that you can see through the porthole in the door is cabin pressure. If the cabin is pressurised the red light is on. It tells you not to open the door. It cannot be turned on or off by the crew.
One morning in ARN a flight crew arrived at the A320 down the jetway. The aircraft was in ground service mode electrically, and all the doors were closed. A cabin heater was connected and running. The Captain went to open the cabin door, but the red light came on when he moved the handle. Must be a false warning, he said, the aircraft is not powered. He pulled the handle hard, and the F/O caught him as he was thrown across the jetway by the opening door, powered by the tiny amount of pressure from the cabin heater. The door was disarmed, it was not the air bottle opening the door, but the residual pressure in the cabin.
After that, the ground crew always cracked open a cargo door before connecting the heater.
flyingclrs727
Fri May 26, 2023 8:39 pm
In the US, no one under the age of 18 is allowed to sit in an exit row. Also everyone sitting in an exit row has to be physically able to help an evacuation in an an emergency.
The door does move inwards and up by a small amount, the door handle is about 60cm long to provide the leverage to move the door.
The door needs to be opened in all emergency situations, it cannot be hooked up to external sensors due to the requirement to operate even in catastrophic situations.
It is a plug door because the pressure forces push the door closed against the fuselage, in cruise you could not open the door due to this pressure force. The operating handle could not overcome that force.
A non plug style door would rely on on some form of lock to keep the door closed, in cruise if you operated the lock, the door would open.
WkndWanderer
Fri May 26, 2023 8:48 pm
You only have to be 15 to sit in an exit row in the U.S.
https://www.law.cornell.edu/cfr/text/14/121.585
zkncj
Fri May 26, 2023 8:51 pm
Airbus doors are design, so if they are opened from the outside they automatically dis-arm.
The slides on Airbus doors, are only activated by opening the doors from in the inside. It’s a additional safety feature added in to protect ground crews.
Fri May 26, 2023 9:31 pm
Not quite. I thought the doors/exits would lock automatically after take off - AFAIK this is standard on the B737 at least, isn't it?!
CrewBunk
Fri May 26, 2023 9:34 pm
Only on the NG and later, as those aren’t plug type doors.
T54A
Fri May 26, 2023 9:36 pm
OEB: Aircraft to be pressurised to >2psi upon touchdown. Further depressurisation will take place on taxi in.
vtdl
Sat May 27, 2023 12:38 am
Now need to be mentally fitted to sit on the exit row.
bhill
Sat May 27, 2023 1:12 am
"Stand up, hook up shuffle to the doooor......jump right out anda' count to four...." good thing folks were buckled up for landing.
bhill
Sat May 27, 2023 1:15 am
Compensate them for what??? A mentally ill person did a bad thing? Perhaps they should have have Shrinks in the jetway to interview folks??? Yeah....that will stop em...or perhaps this person was drunk...
bhill
Sat May 27, 2023 1:20 am
Well, if pressure is equal AND no motion....this could be done...mind you..the overwing windows are still available
crownvic
Sat May 27, 2023 4:10 am
I have two comments on this:
1) Is it possible that there is enough disturbed air just off the back of the wing where this door was located, that airflow can actually wrap around and travel forward?
2) Why did they keep these passengers sitting right where the open door was? Shouldn't they have been moved away immediately to risk any further injury? Even if the aircraft was full, I think the pax should have immediately been moved to the aft galley, even if they had to sit on the floor or crew jump seats. Even an insect entering that cabin at nearly 200 mph could be deadly on somebody's face.
chiad
Sat May 27, 2023 5:09 am
I wonder why the passenger chose to open the door.
Maybe just to see if he/her could?
CXH
Sat May 27, 2023 5:20 am
As per the posts above, they were at 700 feet, about two minutes or less to touchdown. FAs would have been seated. Having all pax keeping their seat belts on is the safest course of action.
F9Animal
Sat May 27, 2023 4:30 pm
I do think the airline could offer miles perhaps in this situation. I can guarantee the passengers who got some of that wind were terrified. I honestly would need to have disposed of my underwear, as there would be no way those things would be worth cleaning.
The latest version of this story is, the passenger said he felt the need to get off the plane right away. Apparently that is what he told police. Regardless, I hope he is prosecuted for this big time.
