A little bit to add to what
[email protected] said about
ORD. With
SFO being announced yesterday,
ORD is the largest airport in the country that does not (or will) have AirTran flights. With United's future (and American's as well) still a little shaky, some of their ops @
ORD could get reduced, allowing a new entrant to come in. Midway is home to the LCCs because of the juggernaut over @
ORD. Southwest really started the current wave when they moved into
MDW within weeks of Midway Airlines Mk.1 folding.
MDW works for some LCCs because they avoid congested airports as part of their business plan, and others because they don't want to pay the higher prices over @
ORD. If AirTran were to start service @
ORD,
MDW would not suffer as a result. Look at the Washington D.C./Baltimore area, AirTran will serve all three metro area airports in October. And
IAD and
BWI probably won't see a large drop in pax as a result either. It's all about location and convience. AirTran serves
MIA,
FLL, and
PBI, all three airports are really not all that far apart geographically; they also serve
EWR and
LGA, who knows, they might add
JFK one of these days.
AirTran will have to eventually decide whether to go ahead and open up a hub somewhere in the Midwest or Rocky Mountain region, or just wait another 5+ years for the expansion @
ATL to allow them more gate space. Originally, AirTran was supposed to have gotten the old TWA gates on D, but they ended up going to Delta Connection. AirTran could probably add flights out of the City-owned gates on D (where the JetConnect flights operate out of), but it would be some tight scheduling coordination with the other airlines that operate out of those gates as well. Eventually, without additional gate space @
ATL, AirTran will have to speed up turnaround times so they add more flights @
ATL. But here's a solution I think could work. They take out the jetways @ 1A and 4, and make the entire area (including "The Hole") the JetConnect ramp. Mainline flights that would have gone out of those gates move over to the D gates JetConnect operates out of right now. Using the 1A/4 area is not an old idea, as it was where the old Eastern Metro Express operated out of (in fact someone scrawled Eastern Metro Express in the concrete when it was poured back when the area was built), and there is access to the ramp level from the gate level (the escalators have been blocked off, but you can still look down and see the old Eastern Metro Express waiting area.
