wpmike
Finding Aircraft Type For Upcomming Flight
Thu Oct 09, 2003 1:26 pm
I am new at this so bear with. I know Soutwest uses 737 equipment on it's flights. Is there a way to tell or is there a place that indicates the series of aircraft used on particular flight numbers with them? I will be going on a short trip from PDX to and from SMF aboard flight numbers 439 and then on flight 2910. Years ago I used to check the entire route of flights using the old printed OAG's that I got from Travel offices. Used to be kind of fun to see where exactly a plane was going. No big deal just interested. Thanks for any help.
Mike
OPNLguy
RE: Finding Aircraft Type For Upcomming Flight
Fri Oct 10, 2003 5:09 am
Depending upon what site or other resource one uses, the aircraft type may be listed, but it's only the -scheduled- aircraft type. Initial aircraft assigments are made 3-5 days out, but they can (and -do-) change often, sometime right up until the last minute. The biggest variable to the assignments are what (if any) other aircraft are out-of-service in the route system, and reacting to that is what largely drives the changes in aircraft assignments.
All that said, the two flights you mentioned are on scheduled -300 lines, which is what they should be, unless.....
