TWAL1011:
A little deviation from the schedule you posted. The B747-200 did operate to
ORD in mid-june as it will operate between 01JUL04 - 14JUL04. It will then go back to the A340-300. As of right now there is no scheduled plan to take the 340-600 to
ORD. As you may recall with all the articles that came out when
IB was planning to take the 340-600 to
ORD....many said it was not possible....even polititians got involved saying the airport was not ready for it..etc. To avoid any problems, I dont think you will be seeing it there any time soon.
IB had enough problems bringing it into
JFK as to get from the
AA terminal to the runways you have to cross one of two bridges(over the
JFK Expressway). They had to re-enforce one of the bridges to support the weight of the 340-600...something having to do with the fact that all the wieght of the aircraft would be on the bridge at the same time(both nosewheel and base wheels). Currently they keep inspecting the bridge to make sure there is no fatigue when the 340-600 comes in.
