Quoting Pilotaydin (reply 38): i had a delta agent misprint my bag tag from daytona on to turkey.... |
You did the right thing by having them retag the bag. Otherwise there is a very good chance your bag would of been mishandled. The risk would of been more of a 80% chance rather than 50/50. Of course the daily
BA flight from Atlanta operates to
LGW rather than
LHR but this would of probably confused the situation some more. As for "Atlanta will figure it out", I can tell you they probably would but most likely after the flight is long gone.
Speedbird2155
The bag tags will print the entire itinerary in the passenger record on the bagtag, even if it is on another airline. What most likely happened was that his reservation on
DL only had the the
DAB-
ATL segment and not the other two flights. This is the case if Pilotaydin purchased two seperate tickets. In this case, the connecting flight informnation for the bagtag would be entered manually. It sounds to me that the agent made a mistake when she did this and then when the mistake was pointed out, the bags was already on the way down and she did not want to go downstairs and look for it. I have ssen many cases of this where the agent would create a manual bagtag and put PAR instead of
CDG or LON instead of
LHR/
LGW. This is why I always recommend paying attention to the tags on your luggage to make sure it is correct, especially on international flights with several legs on different carriers.
As for the discussion at hand, I always travel with a standard size rollaboard and expect that if the overhead space fills up I would need to check it. It is the tradeoff where I don't have to worry about my luggage getting lost or waiting for it at the carousel but there is always the chance that the overhead space will fill up and I need to check it anyway. If I travel with a second bag such as a backpack, I always put it in the seat in front of me unless the flight is less than full and there is plenty of space in the overhead. The truth is that most people do not travel smart and U.S. airlines in particular tend to be more lax on the enforcement of carry-on rules.
DAirbus
"I love mankind. It's people I can't stand." - Charles Shultz
