Quoting ERJ145LR (Thread starter): Why do you think UA chose to not use the Ge90's? |
Quoting Ciccone (Reply 1): I know that BA uses the Ge90's. |
Quoting StevenUhl777 (Reply 2): Someone told me what is used on the A319 and A320, but I'll be damned if I can remember. |
Quoting DLKAPA (Reply 3): Only on a few of them, used for shorter ranged routes such as LGA-BOS. |
Quoting JpetekYXMD80 (Reply 4): Quoting DLKAPA (Reply 3): Only on a few of them, used for shorter ranged routes such as LGA-BOS. Huh? |
Quoting Ciccone (Reply 1): I believe that they are P&W. Looking at N213UA, it uses P&W PT6A-66 SER. |
Quoting StevenUhl777 (Reply 2): Yes...UA uses P&W on the T7, as well as the 744 and 763, and I think the 737s as well. Someone told me what is used on the A319 and A320, but I'll be damned if I can remember. |
Quoting DLKAPA (Reply 3): Either CFM or Rolls Royce, and I'm thinking CFM. |
Quoting Starlionblue (Reply 7): I bet he meant LGW-BOS |
Quoting DLKAPA (Reply 3): Quoting Ciccone (Reply 1): I know that BA uses the Ge90's. Only on a few of them, used for shorter ranged routes such as LGA-BOS. Most of them have the Rollers. |
Quoting UAL777 (Reply 11): 747-400 - P&W 4062 |
Quoting UAL777 (Reply 11): 777-200 - P&W PW4092? |
Quoting UAL777 (Reply 11): 757-200 - P&W PW2000 |
Quoting United_Fan (Reply 13): UAL777, 767-200 engines are JT9D's I thought ? |
Quoting N1120A (Reply 14): They use the PW4090, as they pulled out of their 4098 contract because of PW's f'up on fuel burn, and they have to take a 5 ton MTOW reduction because of it. On the 772A they use the PW4077. |
Quoting JetBlue (Reply 18): What are the advantages/disadvantages of the RR/GE/PW engines on the 777s? Are some more efficient than others? |
Quoting JetBlue (Reply 18): I've read here before that the GE was a brand new design, while the others were derivatives. How does one outperform the other in terms of fuel burn, range, payload, etc? |
Quoting N1120A (Reply 19): PW4090 powered birds (such as UA's planes) are restricted to an MTOW of 646K |
Quoting DLKAPA (Reply 22): So I posted wrong once |
Quoting ConcordeBoy (Reply 23): cough* sh'yeah, right *cough cough* |
