Quoting Bennett123 (Reply 10): How do you know that he lost both parents in the crash. |
Quoting Bennett123 (Reply 12): I really must learn to read ALL the words rather than skimming. |
Quoting AirWillie6475 (Reply 17): It's not stupid at all since that was a major reason why the flight crashed. There is no reason why a pilot of a heavy jet should be using heavy rudder unless landing at a safe speed |
Quoting Birdwatching (Thread starter): It states that flight 587 that crashed at JFK because the pilots used the rudders too much. How stupid is that. |
Quoting AirWillie6475 (Reply 17): It's not stupid at all since that was a major reason why the flight crashed. There is no reason why a pilot of a heavy jet should be using heavy rudder unless landing at a safe speed. |
Quoting Gdjet16 (Reply 9): It seems a bit unfair to claim that there is a problem with the AA training program |
Quoting FlyMIA (Reply 18): I was both pilot error and mechanical fault on the A300 rudder design. |
Quoting VC-10 (Reply 23): The loads just built up until the Vert Stab failed at load in EXCESS of its designed fail load and FAA regs. |
Quoting Birdwatching (Thread starter): I found a pretty stupid article on the web. It states that flight 587 that crashed at JFK because the pilots used the rudders too much. How stupid is that. |
Quoting ZOTAN (Reply 21): Unless you are actually a "pilot of a heavy jet" or a structural engineer I doubt you should be making this statement. Like Chris just said, everything the pilots were taught is that they can make full and abrupt control movement under Va, which they were. |
Quoting Patrickj (Reply 31): Fourth: It was not the titanium that failed but the composite that the titanium attached to. It is the same attachment fitting Airbus uses on the A300, 330 and 340. American's inspection and maintenance procedures were flawed, as were their procedures on the DC-10 in ORD in 79. |
Quoting Birdwatching (Thread starter): I found a pretty stupid article on the web. It states that flight 587 that crashed at JFK because the pilots used the rudders too much. How stupid is that. http://aa587.blogspot.com/ |
Quoting Patrickj (Reply 31): If the flight had not taken off too close to a departing B747, and if the vertical fin had received the proper inspection and maintenance, and if the F/O had not used the rudder this may have been avoided. Crashes are a series of errors (human usually) that string together. |
Quoting Steve6666 (Reply 1): Have you any idea the can of worms you have just opened? |
Quoting LuckyEddie (Reply 36): |
Quoting LuckyEddie (Reply 36): As far as use of rudder in a large aircraft is concerned, to me it is just common sense to be gentle with inputs at high speeds regardless of the exact value of Va. I do not regard 250 Kts when Va is 270 to be "significantly below" Va, in fact I would say it is far too close to test pilot territory for me to be fooling around with. I think the concept of Va has been taken too literally by many people reading this report. |
Quoting Patrickj (Reply 31): American's inspection and maintenance procedures were flawed, as were their procedures on the DC-10 in ORD in 79. |
Quoting Patrickj (Reply 33): Even in a fly-by-wire aircraft if the auto flight system is not engaged through the mode control panel the pilot is in direct law and must control the aircraft him/her self. |
Quoting Patrickj (Reply 33): Even in a fly-by-wire aircraft if the auto flight system is not engaged through the mode control panel the pilot is in direct law and must control the aircraft him/her self. In this mode flight envelope protection is provided but only so the aircraft does not exceed pitch and or roll limits as well as "g" load limits. |
Quoting N766UA (Reply 8): Nobody at American realizes this? Not one person? And how in the heck does this guy know what American Airlines believes? Seems slanted to me. |
Quoting Patrickj (Reply 33): On the A330 and the A340 the rudder is the only flight control with a direct connection from the control surface to the flight deck. |
Quoting ThePinnacleKid (Reply 45): its a violent affair and the pilots were engaging in an equally violent maneuver in order to get out of the emerency situation they were in |
Quoting NAV20 (Reply 47): I hope also that the case of the Air Transat aeroplane that lost its rudder last month while cruising on autopilot at 35,000 feet (presumably with the rudder not in use at all except by the 'yaw damper') will cause a re-examination of how far Sten Molin (the First Officer of AA 587 Heavy) may actually have been to blame. |
Quoting VC-10 (Reply 23): The problem was that the PF used 5 full rudder deflections L/R/L etc. This did not allow the stress induced into the structure with each deflection to dissipate. The loads just built up until the Vert Stab failed at load in EXCESS of its designed fail load and FAA regs. |
Quoting LY4XELD (Reply 34): All this and yet isn't it strangely coincidental that there was an Air Transat A300 that lost its rudder completely in the middle of March? |
Quoting LY4XELD (Reply 34): Then the FAA mandated that the rudders be checked? If it was pilot error, why would they suddenly focus attention on the rudders and not the flight crew? |
