If there were I might even be convinced that it's a good looking aircraft
Chris
Quoting FlyMIA (Reply 6): 787! Yes! |
Quoting BlueSky1976 (Reply 7): I hope AA changes their livery before they order the bird... Polished metal looks good only on vintage airliners, unfortunately... it's sooooo 1950s... |
Quoting Airlinerfreak (Reply 8): AAdvice #1-AA dont change your livery |
Quote: A380 In A AA Livery |
Quoting Byrdluvs747 (Reply 9): You seemed to miss Lemurs point that the 787 will have to be painted gray since the skin has no metal. Do you want AA flying brand new 787's in drab and boring gray paint? |
Quoting Lemurs (Reply 10): They could make it something splashy for just the "flagship", |
Quoting Lemurs (Reply 10): splashy for just the "flagship", and you would always know that you were looking at a 787 |
Quoting AAFLT1871 (Reply 12): Now if AA should order the 787 down the line, I would hope they would not change the classic look on their other aircraft to match the 787. |
Quoting BlueSky1976 (Reply 7): I hope AA changes their livery before they order the bird... Polished metal looks good only on vintage airliners, unfortunately... it's sooooo 1950s... AA could learn a thing or two from Virgin or Northwest... |
Quoting BUFjets (Reply 17): AA's livery does not have to die with the composite airframes. WN's "Silver One" and NW's new livery is silver paint. |
Quoting Byrdluvs747 (Reply 11): I don't know if there's enough width to install the FS suites on 787's. |
Quoting Lemurs (Reply 22): AA777jr you miss the point. |
Quoting Lemurs (Reply 18): Either way, when you see the bird in person, you'd never call it silver. |
Quoting AAgent (Reply 20): I'm not sure, but I don't believe a 2-2 configuration would work since each of the American Airlines Flagship Suites requires immediate aisle access. In a 2-2 configuration, two of the four FS Suites would be "trapped" between the window and the adjoining suite located along the aisle of the aircraft. Perhaps a 1-1-1 configuration would solve the problem. |
Quoting Airlinerfreak (Reply 8): AAdvice #1-AA dont change your livery AAdvice #2-Buy the 787. |
Quoting AAgent (Reply 20): Perhaps a 1-1-1 configuration would solve the problem. |
Quoting Aloha717200 (Reply 33): That said it is a shame that the 787 doesn't look like the concept anymore. That would have been absolutely stunning. I'm afraid I have to say the 787's new lines are ugly! |
