US A333 PIT
Nearest Airport To BDA
Tue Jun 28, 2005 4:48 am
What is the nearest airport to Bermuda International (TXKF)? I think Ocean City Maryland (KOXB) is in contention at 624nm away. Any airports with a runway 2500 ft or longer qualifies (doesn't have to be hard surfaced). I know in terms of big airports Norfolk is probably closest but I'm talking overall. Just curious.
ERJ170
RE: Nearest Airport To BDA
Tue Jun 28, 2005 5:02 am
New Bern (EWN) is close at 637 nm.. with a 6700' runway..
Aiming High and going far..
hiflyer
Tue Jun 28, 2005 5:26 am
I have seen KILM as alternate in a lot of releases...674nm.
kmh1956
Tue Jun 28, 2005 7:42 am
The closest point of land to Bermuda is Cape Hatteras, North Carolina but I haven't the remotest idea if there's an airport there.
'Somebody tell me why I'm on my own if there's a soulmate for everyone' :Natasha Bedingfield
ERJ170
Tue Jun 28, 2005 7:43 am
Dare county regional airport MQI is nearest to Cape Hatteras..
kmh1956
Tue Jun 28, 2005 7:47 am
Quoting ERJ170 (Reply 4):
There ya go, then!!
(Unless, of course, you're talking major airports with flights to Bermuda...in which case you're probably talking BOS...less than 2 hurs flight time,usually)
ERJ170
Tue Jun 28, 2005 7:50 am
RDU or ORF would be the next major airport
timz
Tue Jun 28, 2005 8:03 am
HSE is a 3000-ft asphalt runway-- 573 nm says the GC mapper. That will be hard to beat.
ERJ170
Tue Jun 28, 2005 8:14 am
where is HSV.. as far as I can tell/read, there should be nothing closer than North Carolina...
PVD757
Tue Jun 28, 2005 8:15 am
PVD might be closer than BOS...
ERJ170
Tue Jun 28, 2005 8:16 am
Ooops.. make HSV into HSE..
Web
Tue Jun 28, 2005 9:51 am
W95 (2,998 ft paved runway), KFFA (3,000 ft paved runway) and KMQI (several paved runways over 2,500 ft) are 588, 588, and 589 nm, respectively, coming in tied second and third below HSE.
kmh1956
Tue Jun 28, 2005 10:01 am
I am not as savvy as most of you with aiport abreviations, but if PVD is a major airport and I'm GUESSING..Providence, RI??...we have no commercial flights coming here from Providence. That's not to say that the private jets don't fly here from there, or even charters...
Womack17
Wed Jun 29, 2005 3:32 pm
Just curious do you need a US Passport to fly to Bermuda from an US airport?
Oh how I miss Midway Airlines. A class act right to then end.
PVD757
Wed Jun 29, 2005 10:01 pm
Does anyone have a website that you can look up the distance without having LAT/LONG values???
PVD757
Wed Jun 29, 2005 10:30 pm
All right, this is what I've been able to get...
I only used airports with commercial service.
Statute Miles:
ORF 726
ACY 739
PVD 745
ISP 746
PHF 748
JFK 762
BOS 772
LGA 773
BDL 794
RIC 800
BWI 820
DCA 826
RDU 843
IAD 849
CHS 896
1MillionFlyer
Wed Jun 29, 2005 10:41 pm
Quoting Womack17 (Reply 13):
absolutely yes you do, It's a British Island
Golf Foxtrot you are cleared for departure
ERJ170
Quoting PVD757 (Reply 15):
You forgot EWN, ILM, PGV, MYR.. which are all closer than ORF..
RDU can't be father away than ISP, LGA, ACY, or BDL.. it has to be much closer than that.. BDA is directly off the Carolina coast..
PVD757
Thu Jun 30, 2005 12:57 am
Quoting ERJ170 (Reply 17):
OK, let me re-quantify my choices. I used airports that have more than a couple token flights to the nearest hub(s).
MYR wasn't included after I saw how far CHS was.
The numbers are right out of the OAG/Skyguide magazine and/or Sabre. I didn't just make them up!
It may be off the Carolina coast, but don't forget how the curvature of the earth effects straight line distances...
PVD757
Thu Jun 30, 2005 1:04 am
Forgot PHL at 783 statute miles...
MYR is 833!
[Edited 2005-06-29 18:04:30]
columbia107
Thu Jun 30, 2005 1:40 am
Quoting 1MillionFlyer (Reply 16):
That is correct but upon departure you most likely be able to get US Customs Clearance in Bermuda as there are US Customs Officers on the island. This allows you to avoid any delays upon your return to the USA.
By the way, please let me know when you are arriving as I would love to talk a photo of your aircraft as you come into land on runway 12 or 30.
In God we trust
ERJ170
Thu Jun 30, 2005 2:09 am
http://www.airportcitycodes.com/aaa/T&DCFrame.html
This is the website I like to use... and upon checking Tom's values.. he right! My bad buddy.. you got your props.. who would have thunked?
Tornado82
Thu Jun 30, 2005 2:23 am
Quoting PVD757 (Reply 14):
Airnav.com
timz
Thu Jun 30, 2005 8:45 am
"Does anyone have a website that you can look up the distance without having LAT/LONG values?"
You haven't used http://gc.kls2.com? As long as you don't need the distance more precise than the nearest kilometer, they're as good as any.
stlgph
Thu Jun 30, 2005 8:47 am
since when?
a bunch of us went for spring break a few years ago and only i had a passport. the rest used birth certificate, social security card, driver's licenses, etc. ec.
worked just fine.
if assumptions could fly, airliners.net would be the world's busiest airport
Womack17
Thu Jun 30, 2005 9:07 am
Quoting STLGph (Reply 24):
since when?
worked just fine.
Exactly - That's what I thought. I thought your birth certificate and Social Security card were sufficient. When did this change?
I didn't think a US citizen needed a passport to fly to the British Virgin Islands, Aruba, Bonaire, etc...
