jetblueatjfk
Planes On Approach On Google Maps
Fri Jul 08, 2005 11:45 am
First off I didn't know what forum to put this in so I put it here, fell free to move it though.
Well I was browsing Google Maps and then I decided to look for planes on Approach to airports.
Then I came across this really cool shot of a plane an approach to BOS. Really amazing picture (just look at it and notice how the sun goes off the plane and the shadow right there)
BOS&ll=42.348626,-70.984243&spn=0.003313,0.005025&t=k&hl=en" target=_blank>http://maps.google.ca/maps?q=BOS&ll=...43&spn=0.003313,0.005025&t=k&hl=en
Are there any other planes that you can spot one approach to Airports?
Here is another shot of a plane on approach to SAN from before on the forums.
 airplane jetBlueAtJFK airplane
EZEIZA
RE: Planes On Approach On Google Maps
Fri Jul 08, 2005 12:11 pm
Hi jetblue,
check out for Buenos Aires. There is a 737 on very short final at AEP
Carp aunque ganes o pierdas ...
STARalliance24
Fri Jul 08, 2005 12:25 pm
Look at Dallas Forth-Worth, if I'm not mistaken you should see airplanes that had just taken off. You'll see their shadows on the ground. PRETTY COOL!!!  Cool
DfwRevolution
Fri Jul 08, 2005 12:36 pm
Correct...
Switch to Satelite view and zoom in on the north west end of the airport, there's an aircraft ascending (still within airport property) taking off from runway 13L/36R
STARalliance24
Fri Jul 08, 2005 12:41 pm
Quoting DfwRevolution (Reply 3):
Thanx DfwRevolution, I wasn't sure which runway it was.
STARalliance24
Fri Jul 08, 2005 12:54 pm
I pretty sure there's another airport, but you can only see the shadows and not the airplanes.(I don't know why so don't ask). I think its in LAX but you would have to check?
flyf15
Fri Jul 08, 2005 1:01 pm
At Denver Intl, if I remember correctly, you can find 5 planes lined up in a row for 35L.
GQfluffy
Fri Jul 08, 2005 2:11 pm
Thats one strange runway...  boggled
fluffy
This isn't where I parked my car...
AA 777
Fri Jul 08, 2005 2:39 pm
Looks like a plane got to experience the arrestor bed at JFK's 4R....pretty cool
-Matt
CRJ-700 FO
jetblueatjfk
Sat Jul 09, 2005 3:57 am
Quoting AA 777 (Reply 8):
Yea and the left wing look messed up, looks like something wrong with the photo though.
Thanks for all the replies, I am putting together pictures of the planes landing and taking off, etc.
Also the FL plane taking off at MCO is pretty cool, because it shows up 2 times on the runway and a shadow after the runway ends.
Kempa
Sat Jul 09, 2005 5:10 am
Quoting STARalliance24 (Reply 5):
The urban area photos are made in satellite "passes". Think about a lot of photos, and a mosaic is made of the photos. Sometimes the shadow of a plane shows up on one photo, but the plane would show up on the next frame, especially if it is flying higher. When the satellite takes the photo on the next pass, where the plane was, the plane is not there anymore.
timz
Sat Jul 09, 2005 6:25 am
"The urban area photos are made in satellite "passes"."
I'm guessing not. I think the satellites have a "pushbroom" camera-- and maybe that means it scans a continuous strip. But I'll bet the next strip would have to be a day or two later, so no reason for a plane's shadow to get shifted.
bistro1200
Sat Jul 09, 2005 9:12 am
Here is a cool pic of a long contrail near TVC. I am guessing it is a European arrival into ORD. Unfortunately it is low resolution so you can't zoom in on it.
http://maps.google.com/maps?ll=44.81...45&spn=0.115623,0.155414&t=k&hl=en
Also, most of the images on Google maps are the same ones at http://www.terraserver-usa.com Terraserver also puts the date that the sat pic was taken.
Measure to the millimeter, mark with a crayon, cut with an axe.
STARalliance24
Sat Jul 09, 2005 10:44 am
Quoting Bistro1200 (Reply 12):
Where exactly is it on the map? NW, NE, SW, SE etc...
jetblueatjfk
Sat Jul 09, 2005 11:04 am
Quoting STARalliance24 (Reply 13):
It is right in the center on the water. It is closer to the right of the water in the center. Big long white line.
STARalliance24
Sat Jul 09, 2005 11:36 am
There are three lakes. In which one of them? (I must be blind)  Sad
aircanada333
Sat Jul 09, 2005 11:38 am
Quoting STARalliance24 (Reply 15):
Ya Bryan your blind lol.
P.S. Bryan go on the live chat.
De-icing RULZ!!!
aircanada333
Sat Jul 09, 2005 11:49 am
Quoting Kempa (Reply 10):
Ok thanks for the information.
 bigthumbsup
De-icing RULZ!!!
md80fanatic
Sat Jul 09, 2005 1:35 pm
These are from Google Earth, but I think they use a common database with GMaps.
What plane is this BTW (United ???) 11.2 miles from a 14R arrival at ORD?
http://www.topflightaustin.com/other/enlarge.jpg
Can anyone give a good estimate of altitude, considering both ground level and "eye" level listed on the shot?
A context shot....
http://www.topflightaustin.com/other/big.jpg
zotan
Sat Jul 09, 2005 2:25 pm
Quoting Md80fanatic (Reply 18):
Look at this chart: http://204.108.4.16/d-tpp/0507/00166I14R.PDF
He is probably around 5000 feet.
md80fanatic
Sat Jul 09, 2005 10:50 pm
Yeah, that was about my guess according to the glidepath.
According to the photo, the ground level is at around 700ft and the camera altitude is around 2200ft. I guess the algorithms for apparent camera altitude (inside Google Earth) are not very accurate, unless this aircraft was cruising neighborhoods at 1700ft prior to landing.
jetblueatjfk
Sun Jul 10, 2005 1:24 am
The big one in the middle of the shot.
jeffry747
Sun Jul 10, 2005 2:10 am
http://maps.google.com/maps?q=Hamilt...84&spn=0.003537,0.004943&t=k&hl=en
United Airlines bird over runway 12 threshold at the airport in Bermuda
C'mon Big B, FLY!
jeffry747
Sun Jul 10, 2005 2:12 am
Correction: I think it's an AA 757
C'mon Big B, FLY!
STARalliance24
Sun Jul 10, 2005 2:14 am
Quoting JetBlueAtJFK (Reply 21):
OK!!!! Now I see it thanks for being patient and helping me.  Wink
STARalliance24
Tue Jul 12, 2005 9:38 pm
There is also rwy 35L/17R
EGTESkyGod
Tue Jul 12, 2005 9:51 pm
There appears to be a jet taking off from CDG on R08L.
Now I'm not a sick wierdo, but can someone point out to me the Concorde crash site and the site of the Tu144 crash?
I came, I saw, I Concorde! www.gofundme.com/lineupandwait
STARalliance24
Tue Jul 12, 2005 11:06 pm
OMG I didn't know we could see europe now!!!
STARalliance24
Tue Jul 12, 2005 11:11 pm
Quoting EGTESkyGod (Reply 26):
I think its an MD-11. Maybe from Varig.
EGTESkyGod
Tue Jul 12, 2005 11:28 pm
Yeah, we can see Europe. Manchester Airport is clearly visible too, but the pic was obviously taken before 2004 as there is no Concorde in the AVP.
STARalliance24
Tue Jul 12, 2005 11:33 pm
Look at Toulouse Blagnac, we can see the Airbus being manufactured and parked. The only ones I can difference is 2 A330 from Gulf air, 1 A330 from Emirates. The rest I can't tell.
ssides
Tue Jul 12, 2005 11:40 pm
In the Dallas-Ft. Worth area, you can see a plane at 32 degrees 46'01.08" N and 96 degrees 55'43.63" W. (For those of you familiar with the area, the plane is just north of I-30, just west of the Loop 12 interchange)
If I had to guess, I'd say it's a CoEx RJ heading from DAL to IAH. But it could be an AAEagle RJ circling for approach, or a private jet.
[Edited 2005-07-12 16:44:41]
"Lose" is not spelled with two o's!!!!
ARGinLON
Wed Jul 13, 2005 1:23 am
Do you guys know how often are the images get updated? or are they always the same?
BrunoSBGR
Wed Jul 13, 2005 2:39 am
Quoting STARalliance24 (Reply 28):
Yeah, it could be. But it's not taking off, it's landing. Actually, you can see it's starting to turn off runway 08L.
As you can see, 8R is being used for takeoffs, as there appears to be a 767-300 just off the ground and an Airbus (A300 or A310) lined up for departure.
Private pilot. Frequent flyer. Aviation geek. Proud of all 3.
