Quoting Budyboy (Reply 4): Thanks NZ1! I always look for your posts, can't wait to come to New Zealand on Air NZ, and explore your beautiful country. This Yank appreciates the information you make available. Cheers. |
Quoting VirginFlyer (Reply 15): Paulcaz, it has been in the Air NZ fleet since 1995, on lease from ILFC, having previously flown with Varig. The reason everyone is so interested is because it is the first aircraft to be fitted with the new long haul cabins... |
Quoting NZ1 (Reply 17): **** Gary Toomey for CEO **** |
Quoting 6thfreedom (Reply 18): NZ1... just noticed your signature.... Quoting NZ1 (Reply 17): **** Gary Toomey for CEO **** You're not being serious, are you?? |
Quoting V2fix (Reply 27): I wonder if NZ1 can say anything (withoy being shot by UberGrupenFurher Smallmind) about the mood lighting issue ? I undersatnd from previous posts that supply problems made it impossible to install it on the first 2 (?) 74Rs - and they are going to be retrofitted. I always though that rewiring was was a bit of a large job (C Check ?) as it involved removing seats, bins and skins ? Is this right or has a clever way of doing the upgrade quickly being devised ? |
Quoting NZ107 (Reply 34): Have any of you f/a's for Air NZ gone to that training for the 74R? What is actually required to learn that makes it different to serving the older 744's (well apart that they are different seats etc..)? |
Quoting TR (Reply 41): Are there any pictures released anywhere? Unfortunately I didn´t get to see the 'famous' ones NZ1 posted and had to delete.... |
Quoting B744Heavy (Reply 43): Back to SUI, was there a problem on the upper deck during the refit, when the upper deck doors were being closed. They would not close due to the new storage bins being in the way. Apparently the bins had to be moved. Just a rumor I heard, would love to hear it from the horses mouth so to speak, though. |
