Quoting AkjetBlue (Reply 3): The MD-80 as far as I know isn't a well liked aircraft by the frequent traveler. No IFE, and they are increasing in age |
Quoting AkjetBlue (Reply 3): The MD-80 as far as I know isn't a well liked aircraft by the frequent traveler |
Quoting American 767 (Reply 2): Does that mean Delta totally phases out the 737-300 aircraft? |
Quoting American 767 (Reply 2): Of those will be transfered back to the mainline fleet? |
Quoting Jlp12345 (Reply 9): I wonder if this move could be in advance of jetBlue beginning service with their 190's on the JFK-BOS/IAD routes? |
Quoting Phollingsworth (Reply 5): Since shuttle flights are relatively short, the lack of IFE is less important. As for age, the only real problem here is availability of a/c, which increases and then decreases with age. IF DL uses a/c with the new interiors (especially those that are completed and not just seat covers). The inside of the aircraft looks substantially newer and the LED lights are quite nice |
Quoting TinPusher007 (Reply 14): I think that aritcle is mistaken. I think they are talking about the MD-90's...read this again "The MD-88 planes have been in use on routes from Delta's hub in Salt Lake City and its former hub in Dallas. Delta dismantled its Dallas hub this year." It was the -90's that were mainly in SLC and DFW, the 88's are used all over DL's system. It would make more sense to use the -90's anyway since just about all of them could be dedicated to the shuttle. I could be wrong, but I think it might be the -90's. |
Quoting JZ (Reply 18): But I read before the CO's shuttle service used to use MD-80, but the long fuselage meant it took too long for the passengers to get on and off the plane, and consequently more turn around time. Wonder how DL is going to deal with it. |
Quoting American 767 (Reply 2): Next to the MD-80 will be the A319/320 aircraft seen the most at LGA, if US Airways Shuttle continues to fly the Airbus. |
Quoting Pbiflyer (Reply 12): According to the press release on Delta.com, the MD-88's will allow rear of plane exit for passengers, helping those in back to get to ground transportation faster. |
Quoting Milesrich (Reply 23): These planes were parked after 9/11 and will be returned to the lessors, either because their leases are expiring or pursuant to 11 USC 347, the latter being the Bankruptcy Code Section that allows a petitioner to reject leases and executory contracts. |
Quoting BUFjets (Reply 7): I would guess the fuel costs are less on the MD-88 than the 733 for LGA-BOS, LGA-DCA, and LGA-PHL. M |
Quoting Gigneil (Reply 27): I would not be surprised if this causes DL to lose their earliest departure. When they retired the 727, they were allowed an earlier departure due to the very low noise budget of the 738 |
Quoting Wjcandee (Reply 20): What I AM curious about is whether the Shuttle still runs on a different certificate than Mainline. If so, then all those pilots will need to be retrained to fly the Mad Dog. That could be very expensive, raising the question as to what's really up here. |
Quoting Airzim (Reply 29): DL has been allowing rear-door exit via stairs on the Shuttle on the 733's when I've flown in recently. In fact it is better to exit the rear since you go directly into baggage claim and into the taxi stand in 2 minutes in both BOS and LGA. Don't know about DCA. If you leave through the front door you still have to navigate the terminal and then go down to baggage. The only time they didn't allow it was during bad weather. |
Quoting Dutchjet (Reply 25): DL ends up with a streamlined and rather modern mainline fleet: MD88/90, 738, 757, 763/763ER and 772ER. |
Quoting A330323X (Reply 22): US hasn't operated the A320 on the Shuttle in a long time, about since when DL pulled the B737-800. US operates all A319s now on LGA-DCA, LGA-BOS, BOS-DCA. |
Quoting Navairjax (Reply 38): How long has US used 319s on the BOS-DCA run? |
Quoting Phollingsworth (Reply 5): Since shuttle flights are relatively short, the lack of IFE is less important. As for age, the only real problem here is availability of a/c, which increases and then decreases with age. IF DL uses a/c with the new interiors (especially those that are completed and not just seat covers). The inside of the aircraft looks substantially newer and the LED lights are quite nice. |
Quoting Gigneil (Reply 27): I would not be surprised if this causes DL to lose their earliest departure. When they retired the 727, they were allowed an earlier departure due to the very low noise budget of the 738. |
Quoting DAL767400ER (Reply 1): Using the former DLS 738s, or perhaps the already small fleet of MD-90s would probably have made more sense. |
Quoting Padcrasher (Reply 44): The extra sections will be operated by RJs believe it or not. No longer will mainline aircraft be used. |
Quoting RJpieces (Reply 43): More info on this, the MD-88's will be in an all 2-2 config. Source? |
Quoting Positiverate (Reply 37): More info on this, the MD-88's will be in an all 2-2 config. |
