Avianca
Former SAS Long-Haul Flights (Destinations)?
Fri Sep 16, 2005 7:30 am
It would be intresting to know what long haul destinations served SAS in the past...
I know for example, MVD, GRU, GIG ....
Could we complete the list together?
thanks
regards
Avianca
AirScoot
Fri Sep 16, 2005 7:39 am
They used to do JFK-BGO-GEN (mid 80's at least) - I took that a couple of times.
Avianca
RE: Former SAS Long-Haul Flights (Destinations)?
Fri Sep 16, 2005 7:49 am
Quoting AirScoot (Reply 1):
GEN
what airport is this?
LAXintl
Fri Sep 16, 2005 8:12 am
Just off the top of my head.
LAX
KHI
DAR
CCU
JED
JNB
NBO
SCL
HKG
KIX
Quoting Avianca (Reply 2):
Oslo -Gardemoen
Avianca
Fri Sep 16, 2005 8:15 am
JFK (not only to BGO-GEN) ...
regards
Avianca
pwm2txlhopper
Fri Sep 16, 2005 3:02 pm
Is this an error, or am I missing something because to my knowledge I thought Oslo Gardermoen-OSL, did not open as a commercial airport until the fall of 1998, replacing Oslo Fornebu-FBU as the cities commercial airport?
transswede
Fri Sep 16, 2005 3:05 pm
Gardemoen was around for a long time before that, as Oslo's secondary airport sort of - It took care of traffic that could not land at the smaller Fornebu.
Fornebu could only handle up to 767 size - SAS' DC-10's and 747 had to use Gardemoen.
[Edited 2005-09-16 08:06:07]
pwm2txlhopper
Fri Sep 16, 2005 3:11 pm
Quoting TransSwede (Reply 6):
Thank you! I was unaware of that information, as I had always been under the impression OSL Gardermoen had been a Norwegian Air Force base up until shortly before FBU was closed. I knew it was open to corporate traffic and cargo before 1998, but never realized there were any commercial flights prior to 1998.
LAXintl
Fri Sep 16, 2005 3:18 pm
GEN was the intercontinental airport for Oslo, while FBU was the domestic/regional airport.
During the days of the SAS DC-8/DC-10/B747 they operated from GEN.
Back in the early 80s Northwest also operated B747s to GEN, and then Tower Air even operated MIA-GEN charters in the late 80s.
Matt27
Fri Sep 16, 2005 5:04 pm
You can find a lot of info on SAS' history on SASflightops just click on history and then milestones. There you'll find info about the previous fleets and routes.
//Mattias
Man ska inte dricka rödvin i en vit hall.
RedChili
Fri Sep 16, 2005 5:14 pm
Fornebu actually received 747s a few times, but the runway was so short so they could not take off with a full load. I have a book about Fornebu with a picture of a Tower Air and Northwest 747 at Fornebu at the same time.
Gardermoen was mainly the charter airport. No charter flights used Fornebu.
Quoting PWM2TXLHopper (Reply 7):
There's still an air force base there.
Top 10 airplanes: B737, T154, B747, IL96, T134, IL62, A320, MD80, B757, DC10
odafz
Fri Sep 16, 2005 5:23 pm
You could also add the following destinations :
LAGOS (LOS)
MONROVIA (ROB)
PORT OF SPAIN (POS)
and
GEORGETOWN (BGI)
and I do not know if THR and ABD (Abadan) would qualify for long-haul destinations
hz747300
Fri Sep 16, 2005 5:30 pm
When I was a wee one, they used to bring a DC-8 into Jeddah and it continued onto Addis Ababah(sp). It was one of those long DC-8's too. Pretty neat.
Keep on truckin'...
BOAC911
Sat Sep 17, 2005 12:14 am
SAS for a while made a technical stop in Tashkent with DC-8s on it's CPH-BKK route. I believe it was only technical in nature and thus may not qualify. A short haul destination, nevertheless worth noting, is that East Berlin (Schönefeld) was served 3 times a week during the 70's and 80's from CPH.
panamandy
Sat Sep 17, 2005 12:30 am
THEY DID FLY ALSO TO
MNL
YMQ
ANC
AirScoot
Sat Sep 17, 2005 12:33 am
Quoting PWM2TXLHopper (Reply 5):
Sorry about the confusion with that. I probably should have mentioned the name change.
Am I mistaken or did that JFK-BGO-GEN/OSL flight continue on to GOT?
mats
Sat Sep 17, 2005 1:47 am
SAS used to serve Tel Aviv. I think that it was the longest scheduled MD-80 flight.
There also used to be an ORD-CPH-VIE flight, operated by Austrian Airlines.
A999
Sat Sep 17, 2005 1:59 am
When GEN was closed during runway resurfaceing FBU accepted a lot of big metal like Tower Air 747s from/to JFK and charters like TransAmerica DC8-63s.
SAS DC10-30 were also seen as were TWA L-1011s which were regulars at FBU.
SAS JFK flights served CPH(747) and GEN-ARN/GOT with 74Ms.
AirScoot
Sat Sep 17, 2005 2:06 am
Quoting A999 (Reply 17):
The flights I took were DC10 service - but I don't know if they were regular on the route. I was in highschool - student exchange - at the time.
A999
Sat Sep 17, 2005 2:08 am
Well, the DC10s were retained after the 747s were sold off.
Brasuca
Sat Sep 17, 2005 2:18 am
I just found it in the database:
Photo © Carlos A. Morillo Doria
Varig, Varig, Varig
yago
Sat Sep 17, 2005 2:31 am
I flew CPH-DEL with them, my best flight ever.
mainMAN
Sat Sep 17, 2005 3:43 am
Quoting ODAFZ (Reply 11):
LAGOS (LOS)
I have a vague idea that this operated via DUS
caribb
Sat Sep 17, 2005 5:15 am
Both YUL and then YMX were served for a long time before they withdrew.
USADreamliner
Sat Sep 17, 2005 2:07 pm
Well I remember SAS flying to Buenos Aires on and off.
The last time was in the late 80's I think, with a DC-10-30,with stops in Rio and Sao Paulo and Lisboa(only on the southbound flight).
Regards.
AirAmericaC46
Sat Sep 17, 2005 8:40 pm
One of SK's multistop flights was a DC863 in 1977 CPH-ZRH-ATH-THR-KHI-CCU-BKK-MNL-TYO
airbear
Sat Sep 17, 2005 9:10 pm
Hi AirAmericaC46 ... wow! That SK southern milkrun to TYO even beats the SN DC-10 trip I took back in '79. That was only BRU-ATH-DXB-BKK-MNL-NRT.
B727230
Fri Sep 30, 2005 10:33 am
Quoting Mats (Reply 16):
Not really. SAS operated a few MD-83s from 1987-88 to replace the DC-8-62 on routes to Saudi Arabia. Prior to that though, there were instances of DC-9-41s operating routes to Riyadh and Jeddah when the DC-8s did not.
As the Saudi Arabian destinations were shut down, only Tel Aviv (and briefly Cairo) were left and two of the MD-83s were transferred to Scanair. As Tel Aviv was shut down a few years ago the remaining MD-83s were sold to Allegiant Air in the USA.
Wieder in die Sonne fliegen
B727230
Fri Sep 30, 2005 10:53 am
...and here is the list of destinations outside Europe I have in my files:
North America
New York-La Guardia (1946 - 50s)
New York-JFK (1950s-1989)
Newark (1989-)
Anchorage (-1991)
Bridgetown (1969 - late 70s)
Chicago (since late 40s/early 50s)
Gander (- mid 60s)
Los Angeles (1946-1994)
Montreal ( - early 80s)
Port of Spain (1969 - late 70s)
Seattle (since late 40s)
Washington DC (since early 2000s)
Winnipeg (50s - 60s)
South America
Buenos Aires (late 40s - mid 80s)
Montevideo (1946 - early 80s)
Rio de Janiero (1946-1992)
Santiago de Chile (- mid 80s)
Sao Paulo (until early 90s)
Africa
Abidjan (until late 60s/early 70s)
Addis Abeba (until 60s)
Cairo (until early 90s, reopened through Snowflake 2003)
Dakar (until 60s)
Dar-es-Salaam (until mid 80s)
Entebbe/Kampala (until late 70s)
Johannesburg (until 1985)
Khartoum (until 60s)
Lagos (until early 80s)
Monrovia (until 70s)
Nairobi (until 1985)
Tunis (until 70s)
Middle East
Abadan (until late 60s)
Aden (until late 50s/early 60s)
Amman (until early 80s)
Baghdad (until early 80s)
Beirut (until early 80s, reopened through Snowflake 2003)
Damascus (until early 80s, reopened through Snowflake 2003)
Jeddah (until late 80s)
Kuwait City (until early 80s)
Riyadh (until late 80s)
Tehran (until 1979, reopened through Snowflake 2003)
Tel Aviv (until 2001)
Asia
Bangkok (since 1948)
Beijing (since early 90s)
Calcutta (late 40s - mid 80s)
Dacca (until 70s)
Delhi (until 80s, reopened late 90s-2001)
Hong Kong (1992-1998)
Jakarta (until 70s)
Karachi (until 80s)
Kuala Lumpur (until 70s)
Manila (until early 80s)
Osaka (early 90s-late 90s)
Singapore (since when?)
Tashkent (60s-80s)
Tokyo (since late 40s)
Polar
Besides several landing strips used by DC-6s and DC-7Cs, SAS has operated scheduled flights to Søndre Strømfjord (60s - 2002) and Thule (90s).
A number of the destinations in Africa were technical stops en route to South America, but tickets were sold to these destinations as well. During the 60s-early 80s, most intercontinental routes to Africa, South America, Middle East and in some cases Asia, went through either Düsseldorf, Zürich/Geneva and/or Athens before leaving Europe. Most services originated in Copenhagen and all flights routed through ZRH/GVA were operated in pool with Swissair, SAS' best friend at the time.
[Edited 2005-09-30 03:55:32]
flybynight
Fri Sep 30, 2005 12:23 pm
Quoting RedChili (Reply 10):
It used to be when you landed at OSL back in the 80's instead of Fornebu you weren't allowed to take picture since it was a military base. F16's and C130's were common sight.
Of course, I took pictures anyway. Russian paid millions for those C130 pictures!!  devil
Heia Norge!
