Quote: WHILE BASELER WAS BULLISH about the prospects for the 747 Advanced, he was more reserved about the 787-10, the as-yet-unlaunched long-haul version of the 787 that could carry more than 300 passengers. While he concedes that discussions have taken place with potential customers, he indicates the company isn't looking to launch the product at the moment. Emirates, already a big 777 customer, has been at the center of 787-10 discussions since the airline has indicated the current 787-8 and 787-9 don't quite suit its needs. |
Quoting A350 (Reply 2): I've the impression there are major issues with the 787-10(X) since it's a much heavier derivate of the 788/789. It will come, but will probably significantly different to the "classic" 787s and expensive to develop. |
Quoting 1337Delta764 (Reply 5): The 767-400 is not a failure, it was strictly intended as a niche aircraft for Delta and Continental. |
Quoting NorCal (Reply 12): So how will the A350-900 have the required thrust if the similarly sized 787-10 can't? The coposite hull should make the 787-10 lighter than the A350-900, thus requiring less thrust. |
Quoting Amy (Reply 4): I'm not sure about the 787-10, it could turn out as another 767-400 and I don't think that would help Boeing much. |
Quoting NorCal (Reply 12): So how will the A350-900 have the required thrust if the similarly sized 787-10 can't? |
Quoting Aloha717200 (Reply 16): But my question is...if there isn't an engine suitable for the -10, then just what the heck is Airbus using on the 350-900? Similar size aircraft, and supposedly as efficient as a 787 (their claim, not mine), so what are they using and why can't Boeing use their engine? |
Quoting GARPD (Reply 14): PM, Scorpio. Believe what you want. It's quite expected that you will take the "negative" view of the 764, due to your well known anti Boeing feelings/postings. |
Quoting GARPD (Reply 14): Fact is, the 764 was an easily developed derivative designed and built to meet the needs of two large Boeing customers, namely Delta and Continental. Both of whom subsequently ordered it. The 764 comprises of technology that was already available to Boeing. Namely 777 flightdeck, windows and software with the 767 fuselage and wing. |
Quoting 1337Delta764 (Reply 13): The cold hard fact is that Boeing never expected the 767-400 to be a huge seller. |
Quoting 1337Delta764 (Reply 20): NO MONEY WAS LOST FROM THE 767-400 PROJECT. |
Quoting Scorpio (Reply 22): All we said was that it was not the success Boeing intended it to be. |
Quoting Widebodyphotog (Reply 15): The A350-900 will have slower V2, climb, and cruise speeds, all requiring less thrust in total than the enlarged 787. |
Quoting Aloha717200 (Reply 16): It really depends on whethr GE and RR are willing to move up development of a more powerful nextgen engine for this airframe. |
Quoting Astuteman (Reply 25): Both A + B will be pushing RR + GE INCREDIBLY hard for uprates - both frames are well capable of higher MTOWs..... |
Quoting Widebodyphotog (Reply 15): The A350-900 will have slower V2, climb, and cruise speeds, all requiring less thrust in total than the enlarged 787. While 75Klbt takeoff thrust may be adequate for the A350-900 it will not meet the performance demand of the highly loaded wing and faster speeds of a theoretical 787-10. |
Quoting Aloha717200 (Reply 16): Nevertheless, Boeing will likely need to have a competitor to the 359, if leahy's comments prove to be true about it being a 772ER killer. And if the 787-10 isnt the replacement, then a composite 777 will be. |
Quoting Wiggidy (Reply 28): I also believe they are adopting a similar strategy with the ADV. They don't want to jump the gun just to respond to A's moves. |
Quoting 1337Delta764 (Reply 32): RedFlyer, that is only a mere advertisment just in case to get more orders. BOEING NEVER EXPECTED HUGE ORDERS FOR THE 767-400! END OF STORY! |
Quoting TinkerBelle (Reply 30): The 787-10 probably would kill Boeing's 772ER but hey, better that than letting the A350-9 do it. |
Quoting Keesje (Reply 26): I'm getting a bit tired of the endlessly repeated matras how the B777 wiped out the A340 |
Quoting Newagebird (Reply 37): I was wondering if anyone had any views about this kind of engine |
Quoting Newagebird (Reply 37): hey everyone Regarding the powerplant problems...has anyone heard of Pratt and Whitneys next generation engines. They use ADP technology or advanced ducted prop, basically they use a gear system to to reduce fan speed relative to drive turbine speed...this might sound like all complicated to some of u cuz even im trying to figure it out...i read it last night!. anyway this engine gives out more thrust and less noise . It propulsive efficiency is much greater thant that of current engines. It also produces a much better specific fuel consumption rate. These engines have been in testing at NASAs wind tunnels for over 15 years now. I was wondering if anyone had any views about this kind of engine |
Quoting Scorpio (Reply 36): Just for you, I decided to make use of the wonderful archives of Flight International, and I came up with some rather interesting results. |
