Quoting MD80fanatic (Reply 4): Depends on the loadout and CG position, wind strength and direction, and runway length. Any plane can takeoff with zero flaps if there is enough space to do so. |
Quoting MD80fanatic (Reply 4): Any plane can takeoff with zero flaps if there is enough space to do so. |
Quoting Qantas744ER (Reply 14): It is not possible for a 747-400 or 777,767,757,737,717,727 to takeoff withought plaps, the flaps on this aircraft should of been extendet at atleast 10 or 20 degrees. |
Quoting Qantas744ER (Reply 14): a MH 744 landing at EWR a couple of years ago forgot to extend its geras |
Quoting Socalfive (Reply 11): Don't anyone forget the NW MD80 that crashed in Detroit in August of '87. That's exactly why, flaps/slats not set before takeoff and a stall. |
Quoting Miamiair (Reply 15): And where do you get your information from? |
Quoting Miamiair (Reply 18): Take off settings 10 or 20 degrees for the -400. |
Quoting Qantas744ER (Reply 14): The only aircraft i know that can do this is the fokker 100 it only needs its slats extended |
Quoting MD80fanatic (Reply 17): I'm sure if they were going to try to takeoff clean then they would have extended the takeoff roll a little bit more. |
Quoting Dogfighter2111 (Reply 21): What is the open door underneath the L5 door? |
Quoting Qantas744ER (Reply 14): It is not possible for a 747-400 or 777,767,757,737,717,727 to takeoff withought plaps, the flaps on this aircraft should of been extendet at atleast 10 or 20 degrees. The only aircraft i know that can do this is the fokker 100 it only needs its slats extended. I think if they didn`t abort the Takeoff it would of ended in a major Didaster. |
Quote: The only aircraft i know that can do this is the fokker 100 it only needs its slats extended. I think if they didn`t abort the Takeoff it would of ended in a major Didaster. |
![]() Photo © Harm Rutten | ![]() Photo © Harm Rutten |
Quoting Patallen (Reply 33): who do philipine airlines lease their aircraft from? with the us registrations? if you dont mind me asking? |
Quoting Qantas744ER (Reply 14): saddly it happens more and more now adays because after long years of flying pilot feel so sure about the checklist and do not use it |
Quoting CosmicCruiser (Reply 39): Actually the caption under this picture said they aborted the t/o and configured and took off. No discussion necessary. |
Quote: CX flyboy and I noticed something unusual about this 747. The pilots obviously did not!! They aborted the takeoff and corrected the problem before trying again. |
Quoting Drinkstrolley (Reply 31): Quoting Drinkstrolley (Reply 30): asymmetry My granny is buried in one of them........ |
Quoting Electech6299 (Reply 41): Aborted the takeoff and corrected the problem. No mention of "reconfigured". |
Quoting MD80fanatic (Reply 42): am sure many thought a 707 could not accomplish a loop, until one did. |
Quoting TheSonntag (Reply 44): A LH 747-400 crashed in 1974 because its slats were not deployed. The cause was never completely clarified, therefore the crew (which survived) was not found guilty as a failure could not be proven. http://www.airdisaster.com/cgi-bin/v...hansa |
Quoting MD80fanatic (Reply 46): A roll is hardly even newsworthy. |
