Quoting Irishpower (Thread starter): Possible sites include where they are, the desert abotut 100 miles east |
Quoting Irishpower (Reply 2): I hear you. Why would they even consider something so far. I think Miramar MCAS has a pretty good chance!! |
Quoting HPLASOps (Reply 5): Here's something the website didn't mention: Would a new airport mean the closing down of the current airport or a supplement to the existing one? |
Quoting Wedgetail737 (Reply 7): MCAS Miramar is out there quite a bit, but there's a lot more available land out there. Would it necessarily take the airport out of the residential areas? It's been a while since I've been there...back when MCAS Miramar was NAS Miramar. |
Quoting Silver1SWA (Reply 1): Hmm...that would be one heck of a commute to work for me. |
Quoting Irishpower (Reply 2): I hear you. Why would they even consider something so far. |
Quoting Irev210 (Reply 10): haha what a joke, camp pendleton hahahahaa |
Quoting HZ747300 (Reply 11): I'd think it's time to follow the Japanese lead on this. A two runway airport made on an artificial island built at sea. The terminal could be shaped like a wing and a mile long and it could become a destination in itself... |
Quoting RedFlyer (Reply 13): San Diego will never get a new airport. |
Quoting RedFlyer (Reply 13): San Diego had its chance to expand the airport and make it at least usable by standard norms with the addition of either a 2nd runway or, at a minimum, extension of the existing one when the Navy moved its training base from the north end of the airport back in the early 90's. What did the city do? They turned that huge piece of real estate into (IIRC) a police training camp. Really smart move. |
Quoting Boeing7E7 (Reply 14): Want to place a wager on that? |
Quoting Boeing7E7 (Reply 14): A runway extension into terrain does nothing for you to create additional capacity. |
Quoting RedFlyer (Reply 16): A runway extension "into terrain" would be better than nothing at all since, at a minimum, it would allow take-offs at capacity when the winds required use of Runway 9. |
Quoting Dc10s4ever (Reply 9): Whats the difference, Southwest would refuse to move anyway. Just like they did at DAL, and that was only 8 miles. |
Quoting Irev210 (Reply 10): yah right, like the marines would even think of shutting down camp pendleton, or giving up any space. |
Quoting Matt D (Reply 18): The only way SD can ever hope to get a new airport in a reasonable time frame (12 years or less) would be to take dictatorial action (backed by police and military force if necessary) and use ED for a 50 square mile area somewhere in North County, level the whole area and build the damn thing, and cramming down the throat of the county. |
Quoting Boeing7E7 (Reply 12): the F-18's at Miramar will move to Yuma or Twenty Nine Palms as planned to make room for the V-22 Ospry tilt-rotor. |
Quoting Boeing7E7 (Reply 21): You (and Red) really have no concept of the issue at hand. There is no expectation it would open for at least 20 years, 15-17 before ground is even broken. That is the standard time frame for litigation, environmental mitigation and construction. |
Quoting STT757 (Reply 22): I've mentioned this idea in other threads, I think the City should swap SAN with the Marines for Miramar. |
Quoting RedFlyer (Reply 23): I like to think I do have some concept of the issue at hand, primarily because I lived there for almost decade and took an active interest in the issue. Almost a decade since I left the area the issue has still not advanced one bit. Therefore, for the almost 20 years I've been following the matter there has been little or no progress on securing a suitable replacement for SAN. |
Quoting RedFlyer (Reply 23): If the Marines decide to go through the trouble of relocating they will NOT make such a short-sighted move to the downtown of a major metropolitan area. Can you imagine the raucus that would occur the first time one of their aircraft goes down into a densely populated area on short final or immediately after departure? |
Quoting RedFlyer (Reply 23): But that's assuming they select a site RIGHT NOW. However, you're assumption is wrong because you ASSUME that the litigation will be won by the proponents of whatever site is finally chosen. The plaintiffs (enviromentalists, NIMBYs, etc.) could in fact prevail, which would push the entire project back to where it is now. |
Quoting Boeing7E7 (Reply 24): A study such as this has never been properly done on the issue. |
Quoting Boeing7E7 (Reply 24): The work being done to sort out potential sites even eclipses that of the work done on IAD, DEN and DFW. |
Quoting Boeing7E7 (Reply 24): I don't care how long you lived there, your claim that the issue hasn't moved shows your ignorance on the matter at hand. |
Quoting Boeing7E7 (Reply 24): The vote is in November and the recomendation becomes a ballot measure in 5 months. |
Quoting Boeing7E7 (Reply 24): It's already an active fixed wing fighter facility with substantially greater noise levels than a commerical airport would ever produce, or did you miss that part? |
Quoting RedFlyer (Reply 26): However, those airports were also built long before enviromentalist and NIMBY legal tactics, as well as environmental laws, matured to where they are now. |
Quoting Boeing7E7 (Reply 24): The vote is in November and the recomendation becomes a ballot measure in 5 months. The substantiation of the need for the new facility, coupled with the work being done right now only leaves behind environmental litigation and East Miramar avoids NIMBY suits. |
Quoting Boeing7E7 (Reply 28): Nice backtrack on the rest of it. |
Quoting Boeing7E7 (Reply 28): Which is precisely why SAN has retained the services of the finest attorneys and consultants in the field. |
Quoting Coronado990 (Reply 29): Last I heard, the mayor of Santee would vehemently oppose an East Miramar location. |
Quoting RedFlyer (Reply 27): By the way, I seem to recall there was also a ballot measure/initiative put to the voters on the airport issue back in the early - mid-90's. So I don't consider any kind of "vote" to reflect anything of substantive movement. |
Quoting RedFlyer (Reply 30): Uh-huh. And I'm sure for that reason the Sierra Club, among others, is just going to roll over and let the city/county have its way. |
Quoting Boeing7E7 (Reply 32): The Sierra Club favors the airport moving away from the water and to a location with less environmental impact such as Miramar. |
Quoting RedFlyer (Reply 33): Really? Now that is news to me (I'm not being facetious). Is the Sierra Club really in favor of Miramar or were you very deliberate in your choice of words by saying "such as Miramar"? |
Quoting Boeing7E7 (Reply 32): Do you really want to try and continue the debate with someone involved in the issue by spouting your opinion based on the past? |
Quoting Zippyjet (Reply 35): A hundred miles out in the desert is way too far unless, Lindburgh stays open. |
Quoting RedFlyer (Reply 36): You know, if you're involved in the issue then I really don't think we'll see the airport built in our lifetime. With an insulting disposition such as yours, you're going to piss-off so many people they will really put the matter out to pasture. You should really act in a more civil manner, especially when all someone has done is provide an alternative viewpoint. And unlike you, without the gratuitious insults. |
Quoting RedFlyer (Reply 26): Very valid point you make. And I would expect such work to eclipse IAD, DEN and DFW since those airports were built far outside of populated areas (when they were originally built). However, those airports were also built long before enviromentalist and NIMBY legal tactics, as well as environmental laws, matured to where they are now. |
Quoting Halls120 (Reply 39): I have to wonder what the study group was smoking to have even considered a site in Mexico. |
Quoting Halls120 (Reply 39): Even if you could get the Navy to leave (doubtful), the Coronado residents would litigate the hell out of that plan. |
Quoting Boeing7E7 (Reply 40): Because it was studied before. All sites that were previously evaluated have been re-evaluated and discarded as appropriate. |
Quoting Boeing7E7 (Reply 38): rather than just tossing out an insulting "you can't get it done because you haven't before" |
Quoting Boeing7E7 (Reply 38): uneducated opinion on the matter would certainly improve the probability of a more cordial response from myself |
Quoting Boeing7E7 (Reply 34): You'd be surprised the Sierra Clubs opinions on the matter. |
Quoting Radelow (Reply 44): When the Navy left NTC (Naval Training Facility) they did not turn it into a police training camp. |
Quoting Radelow (Reply 44): It's a 250 acre master redevelopment that my company is in control of. To date we have built 340+ new homes, 380,000 square feet of new office, 750+ new military housing units, 300,000+ square feet of community arts & culture facilities. On top of that we are building a 48 acre park, additional 400,000 square feet of retail and more. |
Quoting Radelow (Reply 44): Read about it and get yourself educated before professing to "know what you are talking about" |
Quoting HZ747300 (Reply 11): I'd think it's time to follow the Japanese lead on this. A two runway airport made on an artificial island built at sea. The terminal could be shaped like a wing and a mile long and it could become a destination in itself... Smile |
Quoting San2snow76 (Reply 46): There is still 25 acres of the former NTC that is used as a Public Safety Institute where fire departments and other public safety groups do training. |
