cessnalady
Would Boeing Use Used Parts In New Planes? (photo)
Tue Jan 03, 2006 6:16 am
Re: a photo of a B773 in the assembly line that appeared today as "Top of past 24 hours"...
Photo © Royal S King
Looking closely, you will notice the rudder shows the red, green, white and black array typical of Etihad's livery...
Photo © Paul Jongeneelen
Can this mean Boeing is installing in this new B773 a rudder part previously used on another aircraft? (Seems unlikely they would paint that part beforehand hoping that it matches the final paint job...) Would this be OK?
I know brand new cars can only be assembled using new parts (they can be new parts made of recycled raw materials) - but in this case it is like seeing a '2006 Corvette using the door sheets of a '2005 model of another color... I wouldn't take it if knowing in advance... What do you fellow a.nutters think?
Marie
gigneil
RE: Would Boeing Use Used Parts In New Planes? (photo)
Tue Jan 03, 2006 6:17 am
Um, you can see clearly the banner that says "5th Boeing 777 for Etihad" on the plane.
Many pieces are pre-painted.
N
A319XFW
Tue Jan 03, 2006 6:19 am
Not sure about that 777 but it happens that parts are "robbed" from other aircraft further down the line if it fails during testing or something (say a computer) and a spare isn't immediately available due to the 'just-in-time' delivery of some parts.
atmx2000
Tue Jan 03, 2006 6:22 am
How the hell do you implement a moving assembly line in the middle of that mess?
gigneil
Tue Jan 03, 2006 6:23 am
The 777 is not built on a moving line.
N
B742
Tue Jan 03, 2006 6:24 am
The rudder is always pre-painted... (well mostly)
This photo gives another example, you can clearly see the ANA and Delta colours on the rudder:
Photo © David Lednicer
Rob!  wave
RichardPrice
Quoting Atmx2000 (Reply 3):
Not all Boeings production lines are moving, the 747 one is but there are several that arent.
wedgetail737
Tue Jan 03, 2006 6:25 am
Boeing has always pre-painted the rudders of all of the new commercial aircraft. There have been some exceptions with BBJ's or some VIP aircraft. It's one of the ways people can tell which airplane is their's before leaving the line.
RedDragon
The rudder is generally painted in advance, supposedly so it can be balanced properly before the rest of the aircraft is painted.
Quoting CessnaLady (Thread starter):
Why would there be any uncertainty that a pre-painted component would match the rest of the paintjob? It's not as if each aircraft is painted freehand...
Rich
APFPilot1985
Rudders are pre-painted due to the fact that the weight of the paint can effect the balance, which is very important on the rudder.
Stand Up and Be Counted Visit Site Related to Voice your opinion
grantcv
Tue Jan 03, 2006 6:27 am
The rudder is pre-painted as it allows it to be more accurately balanced duing assembly. Boeing have been doing that for years.
A319XFW
Tue Jan 03, 2006 6:28 am
Quoting APFPilot1985 (Reply 9):
I thought the VTP is pre-painted because it's easier and quicker to paint them (as they are more detailed) when they aren't on the aircraft. Some take longer to paint than the actual aircraft.
Pre-painting the rudder isn't done on some VIP or other aircraft as stated above.
APFPilot1985
Tue Jan 03, 2006 6:33 am
Quoting A319XFW (Reply 11):
I've always been told that minutia in the amount of paint applied to each side of the rudder can effect the balance.
ual747den
Tue Jan 03, 2006 6:34 am
got a laugh out of that one. You sound like my wife!
Wife: " How the hell do you get anything done working in that messy office"
Frontier Airlines - Low Fares Done Right
cessnalady
Tue Jan 03, 2006 6:37 am
Thanks for the comments. So they are, indeed, pre-painted.
Marie
APFPilot1985
Tue Jan 03, 2006 6:39 am
Quoting CessnaLady (Reply 14):
Marie
but not re-used
AerospaceFan
Tue Jan 03, 2006 6:42 am
Now that the mystery has been solved, I have a question: Who can spot the teeny tiny people around the airplane?  Smile I can see only one so far -- the guy in the background in front of one of the two doors on the mezzanine to the left of the vertical stabilizer.
What's fair is fair.
A319XFW
Tue Jan 03, 2006 6:46 am
Quoting APFPilot1985 (Reply 12):
You might be right in this respect
Boeing -
Airbus -
Photo © French Frogs AirSlides
But this Qantas tailplane will be red, but isn't here yet. But does seem to have some kind of primer already?
Edit: Added pics in.
[Edited 2006-01-02 22:50:45]
jeb94
Any flight control surface that gets painted has to be balanced on almost all aircraft. The balance of these controls are critical and paint can add a significant amount of weight. There are several layers of paint as well, adding to the weight.
dan2002
Tue Jan 03, 2006 6:47 am
Quoting AerospaceFan (Reply 16):
Now that the mystery has been solved, I have a question: Who can spot the teeny tiny people around the airplane? I can see only one so far -- the guy in the background in front of one of the two doors on the mezzanine to the left of the vertical stabilizer.
Theres one walking by the nose as well.
Dan
A guy asks 'What's Punk?'. I kick over a trash can and its punk. He knocks over a trash can and its trendy.
atmx2000
Tue Jan 03, 2006 6:49 am
Quoting Gigneil (Reply 4):
It is in the process of shifting to a moving line. I don't know if it has been completed yet.
http://seattlepi.nwsource.com/busine...s/252270_boeing16.html?source=mypi
Over the past year, Boeing has been implementing a more efficient and leaner production system for the 777 at the Everett plant, switching from a conventional assembly line to a moving production line that is now used on the 737 program in Renton.
Production of the 777 is also being shifted in phases to an adjacent bay in the plant to make room for the 787, which will enter production in 2007. Final assembly of that plane is expected to require 800 to 1,000 workers.
APFPilot1985
Tue Jan 03, 2006 6:50 am
Quoting A319XFW (Reply 17):
I honestly couldn't tell you as I am no where near as familiar with airbuses assembly process as I am with Boeings.
AerospaceFan
Tue Jan 03, 2006 6:53 am
Quoting Dan2002 (Reply 19):
Oh yeah! I don't know how I could have missed him. He's much larger, since he's in the foreground.
On second inspection, I think that the one guy I pointed out might be next to a second, smaller person in a light-blue shirt, although that second "person" could equally be part of a tool box or something. [EDIT: On third inspection, it's clear that it's not a person in a blue shirt. Had to use the "Fit Screen" function to see that.]
Anyway, the whole process of assembling even just one aircraft must be elaborate and a monster to keep track of.
The American flag on the wall is a nice touch.
You truly can see more and more in the picture the more you look at it.
[Edited 2006-01-02 22:57:52]
A319XFW
Tue Jan 03, 2006 6:55 am
Here's one in XFW - rudder still in primer.
Photo © Björn Lange
But perhaps it's not as critical for small aircraft as it is for large?
Pure speculation on my behalf as I know nothing about paint (well apart from watching it dry is boring  Big grin and on Airbus' a/c most are completely pre-painted because of the time and complexity that is) so I'll shut up now!
gigneil
Tue Jan 03, 2006 7:12 am
The Virgin America rudder seems to be covered in a protective sticker.
N
3DoorsDown
Tue Jan 03, 2006 7:29 am
The others on this site that said we paint the rudders beforehand due to wieght and balance issues are correct. Be it a small 737 or a large 777. As for Airbi, I would not even want to guess why they do what they do.  biggrin
3DD
474218
Tue Jan 03, 2006 7:46 am
All the primary flight control surfaces must be balanced. If the primary control surface is not balanced it will flutter when and if hydraulic pressure is lost or in the case of a small light airplane a control cable brakes. Rudders are painted prior to installation because to balance them they must be laid flat and the rudder, when installed is mounted vertically. For those rudders that only have a coat of primer their weight and balance will be determined by calculating the weight of the paint used when the final livery is applied. When aircraft are repainted the SRM contains a chart that can be used to determine how much and where weight must be added to keep the runner balanced. Additionally there is a maximum weight a primary control surface can be and if it get too many coats of paint (or repairs) it must be completely stripped and repainted.
lincoln
Tue Jan 03, 2006 8:12 am
So, stupid followup question time, when an airline changes their livery (or simply repaints after the 5-10 years that a paintjob lasrs) is the rudder taken off to be repainted? Is it rebalanced, or is that only done for the initial paint job?
Lincoln
Dougloid
Tue Jan 03, 2006 8:19 am
Quoting Wedgetail737 (Reply 7):
Douglas used to prepaint them when the rudder was balanced.
aileron11
Tue Jan 03, 2006 8:28 am
I always thought the rudders are painted for identification purpose on the line SO everyone knows what a/c is being built for which airline never knew about the balancing learn something new every day.  Smile
Jersey Lou
greasespot
Tue Jan 03, 2006 8:35 am
They have to be pre-painted as the weight of the paint is more than the alowable weight change. If the change is more than a prescribe change they have to balance the rudder. By doing it before saves time because they do not have to remove it and re-balance it when it is painted. If for some reason the airplane is not delivererd to the original customer they have to take the rudder off and re-balance it if it is re-painted.
GS
Sometimes all you can do is look them in the eye and ask " how much did your mom drink when she was pregnant with you?"
prebennorholm
Tue Jan 03, 2006 8:38 am
The 777 rudder is made of carbon fibre composites while the fixed fin is a metal structure.
Often when building not too large composite structures, then you start with paint in the mould and apply the carbon fibre when the paint has cured in the mould.
The A300-600 for instance has an all composite fin and rudder. Here is an unpainted A300-600:
Photo © Christopher Hammarborg
I don't know if Airbus and Boeing uses the "paint first in the mould" method, but I wouldn't wonder if that's the reason.
3DoorsDown
Tue Jan 03, 2006 8:45 am
Quoting Aileron11 (Reply 29):
It never hurts to have a rudders paint job to tell you which airline it is, but that isn't the primary reason to do it. There are a few positions in the Final Assy building that the vertical isn't installed yet. If you are working in final you know which customers airplane you are working on with or without the vertical.
3DD
L-188
Tue Jan 03, 2006 8:48 am
Quoting RedDragon (Reply 8):
Quoting Jeb94 (Reply 18):
Pretty much all right.
Quoting Prebennorholm (Reply 31):
Applies to any composite, fiberglass or carbon fiber.
DfwRevolution
Tue Jan 03, 2006 9:09 am
Quoting RichardPrice (Reply 6):
- The 747 began moving production in 2001.
- At the moment, the 737NG and 717 are both moving lines. When the 717 line closes in May, this will leave the 737NG. The 757 was converted to a moving line in 2002 before closure.
- The 777 is in the process of converting to a moving line. As the above post indicate, this will open in 2007. Once the 777 is converted to moving assembly, only the 767 will be manufactured in bays.
- The A320 is also undergoing a transformation to the moving assembly process. Anyone have a completion date?
- The 787 will debut as a moving line.
nhgrafx
Tue Jan 03, 2006 9:24 am
I just think its a beautiful sight to see such a magnificent bird coming together like that.
Is it weird I have a RemoveBeforeFlight pitot cover on my car rear view mirror?
Alessandro
Tue Jan 03, 2006 9:25 am
Well, the new B744-Beluga is built on base of used B744, but those aren´t for sale.
474218
Tue Jan 03, 2006 9:33 am
Could someone please explain what is meant by a moving production line? Or better yet describe how it works?
atmx2000
Quoting Alessandro (Reply 36):
Boeing isn't doing the work on that though.
Silver1SWA
Tue Jan 03, 2006 9:38 am
Which picture are you talking about??? In the 777 pic in the opening post at least 5 people became visible upon a quick first glance.
antoniemey
Tue Jan 03, 2006 9:57 am
Quoting 474218 (Reply 37):
I don't know the specifics, but the basic concept dates back to Henry Ford and building cars on an assembly line... rather than having several workers at each assembly station, he could have one person trained to put on one part as the car rolled by on the line, and thus, make more cars faster in the same amount of space. The process would have to be scaled up for aircraft, though.
Make something Idiot-proof, and the Universe will make a more inept idiot.
APFPilot1985
Tue Jan 03, 2006 9:59 am
this may clear things up a bit about moving assembly lines
http://en.wikipedia.org/wiki/Assembly_line
474218
Tue Jan 03, 2006 10:05 am
Antoniemey,
Thank you, but are you saying that the line keeps moving, like an automobile production line. Are the planes on a conveyor belt like cars. I have worked six (6) different production lines and I am having a hard time picturing a moving production line for aircraft. Someone please help.
atmx2000
Tue Jan 03, 2006 10:22 am
Quoting 474218 (Reply 42):
The line moves at a very, very slow rate of 2 inches per minute (for the 737), on supports moving on a track of sorts. Here is more from Boeing:
Moving Final Assembly Line Production
Moving line picture for 717:
trex8
Tue Jan 03, 2006 10:49 am
sl OT but NG has deliverd "new" E2C Hawkeyes which actually have salvaged parts from older stored/scrapped planes. these are always parts which are not fatigue life critical eg landing gear doors etc. dunno if commercial manufacturers do the same.
474218
Tue Jan 03, 2006 10:54 am
Atmx2000,
Thanks that really helps but now I have a lot more questions. I will start a new topic when I get them all down.
Carl
