Quoting PH-TVH (Thread starter): It started with a really refreshing, almost organic tail. |
Quoting AeroPiggot (Reply 2): So we see Boeing and Airbus (787/A350) going back to the classic conical close out of the aft fuselage. |
Quoting Ikramerica (Reply 3): I was wondering why Boeing gave up on that MD style tail cone like the 777 and went back to the 767 shaped butt. |
Quoting AeroPiggot (Reply 2): The bladed tail, has shown improved aerodynamics, as seen on the 777, and to some extent the A380. However APU placement has been a problem for the 777. The exhaust impingment on the aft fuselage/tail, has cause some maintenance problems. So we see Boeing and Airbus (787/A350) going back to the classic conical close out of the aft fuselage. |
Quoting LTU932 (Reply 5): Check out reply 2 for that: |
Quoting LTU932 (Reply 5): You mean the screwdriver shaped tail? Check out reply 2 for that: |
Quoting OyKIE (Reply 6): Since he quoted reply two when saying that, I am pretty sure he had checked it out. |
Quoting WhiteHatter (Reply 8): The airlines couldn't care less if it looked like a dog's butt as long as it is fuel efficient and lightweight. |
Quoting DistantHorizon (Reply 9): But a nice design helped to fill the front pages off magazines and newspapers. The real design is very conventional and, in my opinion, rather uninteresting. DH |
Quoting CHRISBA777ER (Reply 11): Could it be that the concept drawings were deliberately made to look more different and innovative than was actually the case, to give the impression that the 787 was more innovative, different, and new than say, a more conventional-looking competitor? Adding credibility to some bold-performance claims? Product differentiation = setting your product apart from competitors through clever use of marketing techniques. |
Quoting WhiteHatter (Reply 8): A lot of testing was done at Farnborough in the UK, where the wind tunnel work showed the shark tail produced substantially more drag than a clean blade type of fin. The current one is a tradeoff, as are most things in aviation design. |
Quoting Crosswind (Reply 14): Another area where the original design was changed due to economic reality were the flightdeck windows which were changed to a much more conventional design. |
Quoting AeroPiggot (Reply 2): The bladed tail, has shown improved aerodynamics, as seen on the 777, and to some extent the A380. However APU placement has been a problem for the 777. The exhaust impingment on the aft fuselage/tail, has cause some maintenance problems. |
Quoting Sinlock (Reply 15): he contour of the nose area was changed for drag and wing noise issues but not the window layout itself. |
Quote: AeroWeanie: I was told by the 787 Chief Engineer that the 777 screwdriver tail caused a lot of ramp noise when the APU was operating. The flat surface around the exhaust acts as a good reverb board. The 787 went back to a 757/767 type tail cone, despite a 1% drag penalty. |
Quoting AeroWeanie (Reply 16): I was told by the 787 Chief Engineer that the 777 screwdriver tail caused a lot of ramp noise when the APU was operating. The flat surface around the exhaust acts as a good reverb board. The 787 went back to a 757/767 type tail cone, despite a 1% drag penalty. |
Quoting FlyingHippo (Reply 18): If I am an airline, would I want to give up the 1% on drag penalty for a quiet APU exhaust?? hm.. |
Quoting Crosswind (Reply 14): The original 787 "look" was devised by industrial designers for a distinctive feel, the final design is the result of serious aerodynamic engineering work - I believe this is the first time Boeing have deliberately tried to make an aircraft look different for no reason other than marketing. |
Quoting AeroWeanie (Reply 16): There was an AIAA paper published by someone at Boeing last year showing that the nose was contoured to reduce noise in the cockpit and in the crew rest area, which is above and behind the cockpit. |
Quoting Lehpron (Reply 23): Aerodynamically speaking, any shape of any object experiences 3 types of drag: 1) parasite (skin friction also known as shear) and 2) pressure (dynamic, induced, etc) 3)wave drag which is a result of shockwaves. (Since we are talking about a subsonic airplane, I will skip this part) Pressure drag is based on motion, i.e. it is dynamic. Skin friction is static, also refered to as zero velocity drag, it is the resultant drag after subtracting the effects of motion. Every object has a constant no matter how it is scaled. For example, a sharp object will produce little pressure drag but more skin friction. On a graph, based on velocity, the drag starts out high and slowly goes up. If an object were blunt, it may have a low skin friction (due to lack of surface area) but a higher pressure drag. This object will start out with low drag but increase dramtically with speed. Parachutes are an extreme example. In engineering any machine, there are balances between the benefits and disadvantages to produce the *perfect* product for whatever technology is available at that time period that a company can afford. My guesses are that Boeing may have discovered a slight decrease in drag with the classic profile and doing so has another benefit: cost. The 'shark fin', as it was called here, I'd say had 10-15% more surface area than the classical fin shape. This results in more material to buy and cut and deal with. Of course less area on the vertical fin means less yaw force to turn. I'd suppose to maintain the moment (and thus stability), the fin had to have been moved forward somewhat, which will slightly vary the center of gravity. As you can see, to engineer something is a big deal. I hope I helped you and anyone else out. |
Quoting 787engineer (Reply 24): how does a sharp leading edge vertical fin have more skin friction than a blunt one? AFAIK, skin friction is dependent on the surface area |
Quoting 787engineer (Reply 24): As far as the fin is concerned there's also interference drag; drag as a result of the fin-fuselage intersection. |
Quoting 787engineer (Reply 24): Many of the features and gadgets in the concept car just aren't feasible for mass production. |
Quoting Fuffla (Reply 25): What is not to like about this! Perfect design in my opinion. |
