cessnalady
Shopping For B744's In The Desert
Thu Feb 23, 2006 3:35 pm
Looking closely at this photo, you'll find several B747's that IMHO look like 400's megatops (towards the far end and at least 1 in the left).
Photo © Sam Chui
Why is it that while someone is parking and letting languish a relatively new frame, someone else is ordering and purchasing new ones? I'm particularly intrigued by those ordering new F versions while there are so many frames to choose from and convert into F's?  Confused
Marie
kiwiandrew
RE: Shopping For B744's In The Desert
Thu Feb 23, 2006 3:41 pm
Interesting question
I can think of 4 factors that need to be balanced when comparing a new conversion to a new-build 744F are
1/ the conversion will be carrying a lot of unnecessary weight - the upper
deck extension
2/ the upper deck also limits some container/pallet positions on the main deck
(IIRC)
3/ the cost of getting the conversion done
4/ lack of nose door for straight-in loading
I am not sure but there may be other built-in differences such as floor strength
N1120A
Thu Feb 23, 2006 4:06 pm
Actually, those aircraft look like 743s
na
Thu Feb 23, 2006 5:46 pm
Indeed the 747s with stretched upperdeck in the picture above are ex-Swissair 747-300s, the oldest 743s built in 1983, which are in the process of scrapping. There is not SIA Megatop in that photo. At the moment there are only a few, less than 20, 744s parked worldwide, and most of them are just in the waiting-line to become freighters.
Candid76
Thu Feb 23, 2006 7:37 pm
As far as I know the only 744s not spoken for in one way or another are the remaining four ex. United ones (probably at Victorville). Anyone know of any others? Incidentally were those ex. Swissair ones Combis, in which case they should have been good candidates for frieghter conversion, given how old some cargo 747s are. They may be 23 years old now, but they were only 18 when they were parked.
na
Thu Feb 23, 2006 7:49 pm
I agree the 743s of Swissair haven´t clocked that many hours when they were retired to be cut up, but not all were Combis as you suggest. SRs youngest 743 Combi is flying for TAAG Angola now.
Two of the ex Swissair 743s were bought by Northwest for parts, and I guess that are the ones you can see in the photo.
Btw two of the still parked UA 744s will go to Corsair this year after refitting.
ehho
Thu Feb 23, 2006 8:50 pm
Quoting Candid76 (Reply 4):
Are those ex-UA birds 744 retrofits of 743?
na
Thu Feb 23, 2006 9:32 pm
Quoting EHHO (Reply 6):
There is no such thing as a 743-744 retrofit. The differences are to many that a 743 could be converte.
cessnalady
Thu Feb 23, 2006 11:04 pm
Thanks for the responses. It is indeed starting to make sense.
NA, N1120A: How can you tell the difference between a 744 and a 743 at a glance (as you apparently just did)? What's the "identi-kit"?
Thanks again!
Marie
A342
Thu Feb 23, 2006 11:15 pm
Quoting CessnaLady (Reply 8):
The 744 has winglets, and the engines look different.
Shenzhen
Thu Feb 23, 2006 11:17 pm
For me, the wings and wing to body fairing (engines, but not in this case).
na
Thu Feb 23, 2006 11:27 pm
By just looking at the picture you posted its almost impossible to tell. I just saw other recent pictures from Marana (all shot by busy Sam Chui) where the scene above is more in close-up.
Otherwise the easiest thing to tell a 744 apart from a 743 are the winglets. The 744 has differently looking engines of a newer generation (although a few late-built 743s from Thai and Varig got the 744-type GE-engines). Another distinction is the wing-root which is more aerodynamic on the 744 (again, a few late-built 743s, namely from Egyptair and Sabena, have that feature, too). A fourth point is the antenna in the middle on the back of the fuselage which only the older 747s (741, 742, 743 and SP) have. To make it difficult again, some of the newest 744s, built after 2000, again have an antenna blade in a similar position.
United_fan
Thu Feb 23, 2006 11:44 pm
Doesn't NW own the SR 743's for the parts and engines ?
whitehatter
Thu Feb 23, 2006 11:52 pm
Quoting CessnaLady (Thread starter):
as well as the reasons given, there are other issues.
The aircraft may be parked awaiting disposal by a lessor, sometimes as lease rejects before the lease has expired. They are then subject to court proceedings and have to wait until that liability has been discharged before they can be reoffered elsewhere. Especially if there is no agreement by both sides to allow the equipment to be re-let pending settlement.
The other main reason is tax. Sometimes it can be tax efficient to park a frame rather than allow it to go elsewhere.
Finally there is maintenance. If the pax version is high cycles then a D check and conversion can be more expensive than buying new and amortising the new build over 25 or more years. Servicing and converting could offer an unacceptably low number of remaining hours and cycles, making it uneconomical to do the work.
Tod
Fri Feb 24, 2006 12:27 am
Quoting Kiwiandrew (Reply 1):
deck extension
Most of the upperdeck interior and related secondary structure aft of the u/d door can be removed.
(IIRC)
Same as item one. The u/d floor beams aft of the u/d door can be removed and replaced with lighter ones positioned higher in the fuselage.
Correct and the money spent making payments on an aircraft that is not in service.
Yes, especially if it impacts fleet commonality and related ground service issues.
Except for over the wingbox, to get the same floor loading the floor structure would require modification.
Tod
md90fan
Fri Feb 24, 2006 4:17 am
I know Cathay Pacific Cargo, MP Cargo, UPS and World are all buying/receiving 744F.
AADC10
Fri Feb 24, 2006 4:41 am
There is a backlog on 744 cargo conversions of at least a couple of years. Lessors are probably waiting to see if airlines will take them back since they cannot be converted to cargo anytime soon.
Tiger119
Fri Feb 24, 2006 7:48 am
Quoting NA (Reply 7):
- What differences?
Tod
Fri Feb 24, 2006 8:29 am
Quoting Tiger119 (Reply 17):
- What differences?
My 743 profesional experience is limited to mechanical systems related to interiors. From that limited standpoint, the lav system switched from individual blue juice tanks under the lavs to a centralized vacuum waste system at the back of the plane. The potable water and drain routings are different. The potable water themral protection is a bit different. There are more water tanks on most 744. There are improvements to the conditioned air system. The lav/galley vent system is much improved with bigger fans and ducting. Lots of other little stuff too.
Someone else will have to fill in the structural, electrical, avoinics and cabin improvements.
Tod
whitehatter
Fri Feb 24, 2006 8:47 am
Quoting AADC10 (Reply 16):
That's not true. There are other conversion shops which can do them.
FedEx used to fly their DC10 fleet into Venice to have them done, and there is an excellent facility at TLV. That's just two who can do the 747. Taking a 744 in wouldn't be hard for them as they have widebody experience.
However if you want it done by Boeing or one of their outsourced shops then there may be a backlog, but there are other places besides Kansas and China where it can be done.
Shenzhen
Fri Feb 24, 2006 11:38 am
Quoting WhiteHatter (Reply 19):
There are only two companies offering 747-4 freighter mods, IAI and Boeing (In China). All positions at both are sold out for several years.
Boeing shut down the modification center in Kansas before they sold it.
Carpethead
Fri Feb 24, 2006 12:33 pm
Quoting MD90fan (Reply 15):
JL & KE to add. I know I am missing some more operators.
NH 744s were to go to NCA but not any more. NCA has opted for 744F new builds and 748F.
INTENSS
Fri Feb 24, 2006 1:22 pm
Of those, World is picking up 3 ex-United 744's.
-Rich
cessnalady
Fri Feb 24, 2006 4:16 pm
Quoting NA (Reply 11):
Thanks NA!! You're going to my RUL!!!
Marie
Tod
Sat Feb 25, 2006 12:05 am
Quoting Shenzhen (Reply 20):
If you don't need the side door installed, the rest of the work can be elsewhere.
Tod
