vs773er
'Powerbacks' DC9s Only?
Sat Mar 04, 2006 8:19 pm
Hi,
Saw this video on fl350 and wondered if it's just dc9s/md8x's that are allowed to do it? If so I presume it's to do with the reverse thrust which would smash the terminal windows from larger ac!? Also, is this practice just allowed at KDTW?
http://www.flightlevel350.com/viewer.php?id=5600
Dan
[Edited 2006-03-04 12:22:17]
Communicating. Keeping up foreign relations...
EMBQA
RE: 'Powerbacks' DC9s Only?
Sat Mar 04, 2006 8:23 pm
Any tail mounted engined aircraft can do it..... Boeing 727 comes to mind.
No, I've done powerbacks all over the US with many different airlines.
[Edited 2006-03-04 12:26:32]
Sat Mar 04, 2006 8:24 pm
Quoting VS773ER (Thread starter):
Saw this vid on fl350 and wondered if it's jusy dc9s/md8's that are allowed to do it? If so I pressume it's to do with the reverse thrust which would smash the terminal windows from larger ac!?
You underestimate the terminal windows. Besides in reverse thrust doesn't really go straight forward. It's because underwing engines on low wing aircraft have too high a risk of ingesting junk.
The C-17 also powerbacks btw.
jorge1812
Sat Mar 04, 2006 9:05 pm
Have seen it on ATR-42/72 at TFN too.
Georg
srbmod
Sat Mar 04, 2006 9:08 pm
Quoting EMBQA (Reply 1):
Any jetliner could do it, it is more common with a/c that have tail mounted engines due to the risk of FOD ingestion. Eastern Airlines even used to powerback 757s at one point. I'm not sure if they ever tried to powerback a TriStar. Even Frontier Airlines back when they operated 732s had powerback proceedures in their ramp manuals.
Powerbacks are allowed at many airports, it's just that the practice is beginning to die down due to costs (fuel, wear and tear on engines). AirTran used to do them @ ATL, but in the last few years went and bought more pushback units and now will only do a powerback @ ATL if they absolutely have no choice.
DFW13L
Sat Mar 04, 2006 9:24 pm
In the fall of 1997, I was aboard a USAir 737-200 at DFW bound for PIT and we powered back from what is now gate B20 at DFW. I was astounded! Being from DFW, I had always been used to AA powering back with MD80s and 727s, but had never even heard of a 737 doing it.
Just FYI, I work for American Eagle, and we do not powerback, though we do power out. Powering out means taxing away from the gate using forward throttle, without being pushed back. Powering back means using reverse thrust to get away from a gate.
See, I knew American Eagle was first class all along!
TheSorcerer
Sat Mar 04, 2006 11:11 pm
All tail mounted A/C with R/T, the ERJ 135/145 can't powerback. Eastern Airways powers back some of their Jetsream 31 in ABZ.
Dominic
ALITALIA,All Landings In Torino, All Luggage In Athens ;)
sunking737
Sat Mar 04, 2006 11:13 pm
We used to power back all our planes at Republic mk 1, the 757 was the only one we did not.
But we did try one time, but the senior Capt. was just too chicken, as we had the plane for only a week.
The CV-580 was the plane that was the most fun because we had a very large ramp area to use, it was so large that we could park 5 or 6 planes. usually only one plane had to be pushed back by MX, the first plane in as it was too close to the terminal and had to worry about FOD.
"Don't believe it unless its parked on the ramp, or printed in the schedule...SUBJECT TO CHANGE"
Retired MSP Ramper
jhooper
Sat Mar 04, 2006 11:22 pm
Even the C-5 Galaxy is capable of it, although it certainly isn't a normal procedure.
Last year 1,944 New Yorkers saw something and said something.
BestWestern
Sat Mar 04, 2006 11:25 pm
The ATP can do it also.
Do delta do powerbacks on their 738 shuttle fleet at BOS?
Greetings from Hong Kong.... a subsidiary of China Inc.
srbmod
Sat Mar 04, 2006 11:34 pm
Quoting BestWestern (Reply 9):
Powerbacks are not S.O.P. at Delta period. Some of the DL Connection carriers do power outs, but that's not the same thing.
9KBOS
Sat Mar 04, 2006 11:39 pm
The NW DC-9 I was on in DTW did a powerback....it was great, we backed right out and started forward, we hardly stopped. It was obviously a little noise but it was faster than using a tug. (burns more fuel?)
9kbos
jsposaune
Sat Mar 04, 2006 11:52 pm
Quoting TheSorcerer (Reply 6):
Actually, it can. We did it on a couple E-145's last winter, when our push-back tugs couldn't get traction due to ice on the ramp. It was quite a sight!
We'll also powerback SF-340's once in a while...good times!
There are no stupid questions....only stupid people!!!
J41
Sun Mar 05, 2006 12:41 am
The E-135/145's can only do it if they have reverse thrust, it is an option on the engines, some have it some don't.
J41
longhauler
Sun Mar 05, 2006 12:58 am
Canadi>n did powerbacks with B737-200s as well. It was quite common when operating with a gravel kit equipped aircraft, as the towbar was different, and some stations did not have the proper towbar. It was noisy ... but effective.
jsposaune
Sun Mar 05, 2006 1:05 am
Quoting J41 (Reply 13):
Ah...didn't realize that. Thanks.
J41
Sun Mar 05, 2006 1:14 am
You can see here:
This one has reverse thrust
https://www.airliners.net/open.file?i...hoto_nr=1&prev_id=&next_id=0749510
This one doesn't:
https://www.airliners.net/open.file?i...23&prev_id=1009616&next_id=1009505
Sorry I'm not sure how to make the link short.
JBo
Sun Mar 05, 2006 5:18 am
Quoting J41 (Reply 16):
Copy and paste the link that appears above the photo:
https://www.airliners.net/open.file/1003128/M/
https://www.airliners.net/open.file/1009515/M/
I'd take the awe of understanding over the awe of ignorance any day.
EMBQA
Sun Mar 05, 2006 6:43 am
I think its better to say most do, a few do not. I think of the 1000 worldwide ERJ's, 75% or more have reverse thrust.
optionscle
Sun Mar 05, 2006 7:01 am
I've been in an AirTran 717 that did it. I was pretty surprised.
captaink
Sun Mar 05, 2006 7:43 am
I have seen B727s, MD80's and Dash8's powerback when i working at GND....
Look Up
TheSorcerer
Sun Mar 05, 2006 7:52 am
Quoting Jsposaune (Reply 12):
Ah very interesting, i was getting my info from a BD pilot, i take it their fleet of ERJs doesn't have R/T. thanks for the info.
Dominic
byronsterk
Sun Mar 05, 2006 8:13 am
ATR-42 from Aer Arann did it in Sligo (EISG, Ireland) I remember...
Helicopters can't fly, there just so ugly the earth repells them...
dc863
Sun Mar 05, 2006 8:15 am
Eastern used to do it with their -9s all the time at ATL.
Hodges
Sun Mar 05, 2006 8:26 am
On a DC9 flight this past summer from DTW to MSP we did a powerback. Once we pushed ourselves back we went right back in due to troubles with the engine. Despite the 30 minute wait, i still liked the powerback and eventual flight on a DC9.
I've heard pilots don't like to do powerbacks because it is a pretty dangerous maneuver for the ground crew, surrounding equipment, and the plane. It takes a lot of coordination between the ramp workers and pilots.
Erik
Beer, helping ugly people have sex since 1862.
Sun Mar 05, 2006 9:56 am
You actually need reversers, which some tail engine planes don't have. Some operators of ERJs chose not to mount reversers for example.
9252fly
Sun Mar 05, 2006 10:12 am
I have to say that watching a Dash 8-300 turboprop reverse(powerback)is a rather strange sight.
srbmod
Sun Mar 05, 2006 10:41 am
Quoting Hodges (Reply 24):
It really does. In the 11 months I worked @ FL, I did at least a few hundred powerbacks and got quite proficient at it. Several of us on the gate I was working at one point actually turned it into a bit of a contest. We'd see who'd get it the closest to the line on the ramp, and I'd usually win. 7 out of 10 times, I have them right on the line after they made the turn after clearing the gate area.
nwab787techops
Sun Mar 05, 2006 10:59 am
Oh yea they can! Did it ever day almost working MX. You can make a quick turn if you open one TR and put power on eng two, weeeeee!!!!!!
 Wow!  Big grin
Sun Mar 05, 2006 11:07 am
Quoting Nwab787techops (Reply 28):
Some can. But there are ERJs without reversers. All depending on the operator.
levg79
Sun Mar 05, 2006 12:02 pm
I wonder which airline was it  wink
Back to the topic, is it true that some airports do not allow powerbacks?
I used to know a former pilot from the Soviet Union and I remember him telling a story that one time Aeroflot crew pulled into the wrong gate at JFK. They were then told that a tug will come to take them to the proper gate but instead pilots did a powerback and taxied to the proper gate themselves. After that, every pilot in the Soviet Union was told that when they fly to the US, powerbacks are not allowed.
I asked him if it was common in the former Soviet Union to do a powerback and he told me that they did it sometimes, but not usually. As an example, he told me that when he was a first officer on the Yak-40 and they taxied to the wrong taxiway, his captain did a powerback to get back. That was not usual because the Yak-40 had one one engine (No. 2) equipped with the trust reverser. He said the pilots in the other aircraft who were landing at that time, looked at them in awe. It must have been a strange sight, seeing Yak-40 driving backwards on the taxiway, away from terminal building.
Leo.
A mile of runway takes you to the world. A mile of highway takes you a mile.
EMBQA
Sun Mar 05, 2006 12:23 pm
Quoting Starlionblue (Reply 29):
Again, Most can... The non-TR aircraft are the far minority of the worldwide ERJ fleet. Most are in Europe, but a few originally operated by European operators have made there way to the US.
[Edited 2006-03-05 04:49:09]
Cubsrule
Sun Mar 05, 2006 12:47 pm
It's done a decent amount at MSP, particularly from low C and D gates (in my experience). I've also done it a couple of times at MEM, always when leaving from gates between B30 and B40 (those may be the only mainline gates where there is room).
Spacepope
Sun Mar 05, 2006 12:57 pm
You can see here:
This one doesn't:
Photo © Darren Wilson
Photo © Kuba Nanowski
tangoecho
Mon Mar 06, 2006 8:13 pm
The only ERJ 135/145 with reversers that fly into ABZ is the Air France (regional).
Stu...
[Edited 2006-03-06 12:15:40]
Contact Aberdeen tower on 118.10 G'day.
goingboeing
Tue Mar 07, 2006 1:36 am
Quoting DFW13L (Reply 5):
I was on a Southwest 737-300 out of OAK that did it.
