ERJ145LR
United Domestic 747's
Fri Mar 10, 2006 5:25 am
Hello,
Does anyone know what ual domestic flights are currently or will soon be operated on the 747? I know that there are usually a few out there. I am specifically looking for ones in or out of IAD, but any are welcome. Thankyou!
N1120A
RE: United Domestic 747's
Fri Mar 10, 2006 5:30 am
UA924 on the IAD-LAX run usually switches to a 744 for 2-3 months during the summer.
drerx7
Fri Mar 10, 2006 5:32 am
There is usually a DEN-LAX and/or DENSFO rotation during the summer.
HOUSTON, TEXAS
wrighbrothers
Fri Mar 10, 2006 5:35 am
Don't they do a ORD-LAX run too, as part of a long-haul trip ?
Wrighbrothers
N1120A
Fri Mar 10, 2006 5:38 am
Quoting Wrighbrothers (Reply 3):
Not so much any more. They used to often continue the Australia flights to ORD, but usually LAX-ORD 3-class aircraft are 777s
roseflyer
Fri Mar 10, 2006 5:48 am
Quoting N1120A (Reply 4):
There are also 3-class 767s that often run between ORD and LAX. The 5pm departure from ORD to LAX is usually a widebody.
The 747 flights are definitely pretty rare nowadays. 5-10 years ago there were tons of 747 flights (mostly 742s) flying domestically, but you are lucky to find a single domestic flight now, especially with an emphasis on international routes and with the widebody fleet shrinking due to lease returns.
TWAL1011
Fri Mar 10, 2006 5:51 am
I am scheduled to fly ORD-SFO on April 1st at 5:00PM and the confirmation lists the equipment as a 747-400.
bohica
Fri Mar 10, 2006 6:06 am
Quoting TWAL1011 (Reply 6):
April 1st, huh? hummmmm.........  scratchchin   scratchchin   Big grin  Big grin
N1120A
Fri Mar 10, 2006 6:07 am
Quoting RoseFlyer (Reply 5):
The 5pm is a 3-class 772. The 3pm is a 2-class 763
AADC10
Fri Mar 10, 2006 6:17 am
Quoting N1120A (Reply 1):
UA pulled the 744 off the LAX-IAD route during the middle of last summer, using it only at the beginning and end of the summer travel season. Also, it is usually UA946/947 that is the 744. Most of the year UA946/947 is a 3-class international 763 although somtimes it is an international 772 and during the low season it is a 752.
Manta
Fri Mar 10, 2006 6:48 am
Hmm...it appears that UA256 ORD - DEN is also going to be a 744 on April 1. However, the printed timetable still shows the flights as 777's. Before I go run and buy a ticket to DEN, what are the odds of the plane being switched out from a 744 to a 777?
[Edited 2006-03-09 22:55:02]
