Quoting Deaphen (Thread starter): Couldnt there be a way that the main fuselage of an aircraft could survive even on an impact at about 250-300 kmph? |
Quoting Cincinnaticj (Reply 9): Deaphen, do you worry as much about automobiles? They are a gillion times more dangerous than commercial airliners............ |
Quoting MrMcCoy (Reply 7): We've all heard the joke "Why can't they build aircraft out of the same stuff they use to make the black box?" Err.. the aircraft would weigh as much as a locomotive perhaps? {Big grin} |
Quoting Cincinnaticj (Reply 9): do you worry as much about automobiles? They are a gillion times more dangerous than commercial airliners............ |
Quoting DeltaDC9 (Reply 11): Unlike cars, they seem to design Airliners to fly 100% of the time and never crash. Is crash performance even a consideration for certification? |
Quoting Deaphen (Thread starter): Anyways, back to my question. Why are most plane crashes concieved to be so fatal? I mean are they made of very fargile material? Couldnt there be a way that the main fuselage of an aircraft could survive even on an impact at about 250-300 kmph? |
Quoting LY4XELD (Reply 18): Wrong. Airplanes ARE designed to "crash" and be surviveable. How do you explain escape slides, emergency doors, etc.? Obviously, the idea is that something COULD happen, so there are ways to evacuate. Other airplane systems are designed to survive certain G loads, etc. on a crash that is not catastrophic to the overall aircraft. |
Quoting United787 (Reply 5): Because they have to be lightweight. If you made it like a car so that it could survive impact, then it wouldn't fly. The skin of an airplane is only as thick as needs to be to fly. |
Quoting Deaphen (Reply 10): But i was specifically referring to the near 100% fatality in plane crashes. |
Quoting Deaphen (Thread starter): a plane crash means total fatality. |
Quoting Litz (Reply 20): And if you don't believe this, just look at the Air France A340 in Toronto. The plane broke. The plane burned. Everyone got out. everyone survived. |
Quoting Bayareapilot (Reply 22): What near 100% fatality rate? There are thousands of examples of non-fatal plane crashes. Go to http://www.ntsb.gov/ntsb/query.asp and see for yourself. As long as the plane impacts the ground in a relatively upright attitude and minimal vertical speed the chances for survival are good. That's why even if the plane is going down the pilots do whatever they can to keep it right side up and fly it all the way to the ground. |
NASA tried a fuel addative to prevent such large blazes during and after a crash, but it failed in a very famous test. |
Quoting DeltaDC9 (Reply 11): NASA tried a fuel addative to prevent such large blazes during and after a crash |
Quoting Deaphen (Reply 28): i honestly have to tell you that most of the times i feel safer in a car than on a plane |
Quoting Ilovenz (Reply 26): I've always wondered what the structural requirements are for commercial airliners these days in terms of the maximum force different parts have to be able to endure? And then, how much greater is this than anything an airliner would experience in typical severe turbulence? These are questions I have serious concerns about. Sam |
Quoting Glareskin (Reply 16): Thank you Deaphen for bringing such a nice and different topic! But I have to say that I disagree with a lot of the reactions above. Yes, the comparison with cars comes to mind. But I don't want to compare the aircraft structure with a regular automobile (not even a Volvo or a fancy German car..) because usually fatal aviation accidents are not caused by two planes crashing. But I'd like to make the comparison with Formula 1. These cars have a so called 'monocoque' which is especially designed to withstand the incredibly forces of a high speed impact. If you see a car crashing into a hard obstacle, all the parts fall off but the cocoon stays intact. The monococque remains intact and due to a special security system the driver mostly sustains minor injuries. This monocoque is some kind of carbon fibre based composite. So my real question is if modern aircraft like the 787 are more rigid in the way that they better keep intact after a 250 mph with water (like today's crash). Anyone having thoughts about that? |
Quoting Deaphen (Reply 28): Mind you that i feel that way only when i am driving. |
Quoting HiFi (Reply 35): Irrational. The pilot flying the plane has had a LOT better training than you driving your car.. |
Quoting Goldenshield (Reply 34): The ASA EMB-120 accident in Carrollton, GA, proves that you could survive a high speed crash from a nearly-uncontrollable descent. Everyone in the cabin, as well as the first officer, lived through the crash; the only fatality was the PIC from blunt force traume (I assume from not having his shoulder straps on—it's not said in the report.) while doing all he could to save his ship and it's occupants from disaster. |
Quoting Deaphen (Reply 40): Can anyone tell me more about the water crash landings and in what situation would an aircraft land in water the way shown in the safety cards onboard? |
Quote: IIRC, there was a post once saying that just the engines touching the water is enough for them to tear off the wings and cause disaster. So then in what situation would a pilot land his commercial aircraft on water. |
Quoting Khobar (Reply 41): there were 9 fatalities |
Quoting OzGuy (Reply 39): I don't know how accurate that figure is. I don't mean to bash your topic but accident statistics seem to prove that, with the exception of the most horrific accidents such as TWA 800 and JAL 123, most accidents are survivable for the majority of people on board. |
Quoting HiFi (Reply 35): Turbulence does not take an aircraft down to the ground, trust me. |
Quoting Deaphen (Reply 40): Thirdly, why are planes equipped only with seat belts which encircle the lower part of the human body. What would be the pro and cons of having shoulder straps like pilots do? Are they more expensive and is this move just a cost cutting gesture? |
Quoting DeltaDC9 (Reply 33): Also, if what you said was true, then crash performance would be a part of certification. I may be wrong, but nothing here so far leads me to believe I am. |
