Quoting JBo (Reply 1): It puzzles me how 'freaked out' people seem |
Quoting Jorge1812 (Reply 8): The term heavy doesn't mean that the plane has to be heavy. |
Quoting N766UA (Reply 4): The A380 isn't the biggest jet out there. The Antonovs are still bigger, as is the C-5... why would the A380 be special? A heavy is a heavy is a heavy. Sure, it may require more seperation than a 747, but so do the big Antonovs. No big deal. |
Quoting Aero145 (Reply 11): "Uniform-Romeo-eight-two-O-six-O heavy heavy heavy, cleared for landing." |
Quoting WorldXplorer (Reply 2): People made a big deal about it because Airbus stated that the A380 would have the same separation as the 747. It was just another reason for A bashers to jump on the A380 and say "A-ha, I knew that plane sucked!" But really the separation info came at point when Airbus was struggling with PR in general (the A350 in particular). The one bright spot for Airbus at the time was the A380. It was a chance to drag that program down too. Airbus said the initial separation would be decreased. Time will tell. I hope for Airbus sake that it is. If not, their reputation for missing promises will continue. |
Quoting Dw747400 (Reply 10): It may be that smaller aircraft must increase their spacing from it, but that a 747 could use the same spacing as with another 747 (which would be a boost at those congested airports). |
Quoting Wjcandee (Reply 15): It's remarkable to me that folks perceive the spacing issue as some sort of "Airbus Bashing". |
Quoting MesaMXORD (Reply 25): "Whale Jet" sorry had to say it. I personally love the name and the A/C. I dont see why people take it as a bash. |
Quoting MesaMXORD (Reply 25): I thought Airbus did some tests with a 777 and 747 along with the 380 to figure this out awhile ago |
Quoting Corey07850 (Reply 21): The big deal is that there are going to be hundreds of A380's flying into the most congested airports in the most concentrated airspaces. ATC at these facilities don't just have to worry about making a little extra room for the one flight an AN-225 makes into an airport, they will have to worry about it every few aircraft... |
Quoting WorldXplorer (Reply 2): It was just another reason for A bashers to jump on the A380 and say "A-ha, I knew that plane sucked!" |
Quoting Zvezda (Reply 13): then the Airbus bashers wouldn't have the opportunity that Airbus have handed them. |
Quoting Corey07850 (Reply 21): How many an-225's are there flying? One... How many AN-124's are there flying? A handful... How often to C-5's grace civilian airports? Not that often... |
The big deal is that there are going to be hundreds of A380's flying into the most congested airports in the most concentrated airspaces. |
Quoting Corey07850 (Reply 21): there are going to be hundreds of A380's flying |
Quoting 767-332ER (Reply 29): First of all, it's the same issue, why would this a/c require any special regonition when there are aircraft that are bigger and heavier? |
Quoting Dw747400 (Reply 10): Requiring more seperation is a big deal, as a major selling point of the A380 is to allow more flights into slot-restricted or other congested airports |
Quoting BR715-A1-30 (Reply 12): Quoting Aero145 (Reply 11):"Uniform-Romeo-eight-two-O-six-O heavy heavy heavy, cleared for landing." Huh??? |
Quoting Corey07850 (Reply 42): Now, when all is said and done with the regulatory agencies and they conclude that the A380 will indeed require greater separation minima, imagine the headache this will be at places like LHR and LAX that are expected to see A380's all day long. Imagine the delays if a/c following an A380 to land requires 10nm in trail, and every 3rd or 4th plane is an A380... You can see why people are making "a big deal" about it. |
Quoting Corey07850 (Reply 18): The big deal is that there are going to be hundreds of A380's flying into the most congested airports in the most concentrated airspaces. ATC at these facilities don't just have to worry about making a little extra room for the one flight an AN-225 makes into an airport, they will have to worry about it every few aircraft... |
Quoting ShowerOfSparks (Reply 33): As a pilot yourself you should know that the reason for the suffix "heavy" is so that ATC knows to apply extra separation without having to refer to data strips all the time to check a/c types. |
Quoting N766UA (Reply 37): If you're talking about the seperation problem, sure... but it has nothing to do with callsigns. |
Quoting Corey07850 (Reply 34): I'm not saying it should be referred to with the suffix "super heavy" or something |
Quoting MaxQ2351 (Reply 25): The fact remains, they are all STILL BIGGER THAN THE A-380!!! We are not insulting your beloved A-380, we are just pointing out the simple fact that it IS NOT THE BIGGEST AIRCRAFT THERE IS!! |
Quoting MaxQ2351 (Reply 25): Quoting Zvezda (Reply 13): then the Airbus bashers wouldn't have the opportunity that Airbus have handed them. Oh cry me a river........ |
Quoting Slz396 (Reply 30): MORE FLIGHTS??? |
Quoting Dw747400 (Reply 43): Do you even bother to read through the rest of the thread before posting? I already pointed out the AN-124 and C-5 BOTH have lower takeoff weights than the A380. |
Quoting N766UA (Reply 4): A heavy is a heavy is a heavy. |
Quoting Jorge1812 (Reply 44): 44 replies seem to point that out |
Quoting Phelpsie87 (Reply 46): So, in sum...there is no and will be no brand new special callsign for the A380. |
Quoting Jorge1812 (Reply 8): The term heavy doesn't mean that the plane has to be heavy. It's just added to the ATC ID to recognize the plane as one which produces heavy turbulences behind and other, especially smaller planes, have to keep a big distance to avoid problems. That's why the not so heavy 757 is called heavy on ATC. Don't know the exact figures of the A-380 but imagine a plane with lighter weight as the A-380 can produce mor turbulences than the A-380 itself. So no extra heavy or something else to be added to the ATC ID. |
Quoting Jorge1812 (Reply 47): Thats what I said here. |
Quoting Jorge1812 (Reply 47): A shame that this isn't the last senseless thread on the A-380. Maybe I start Will the A-380 get special runways/flightpaths/terminals/airports? soon |
