access-air
Wunala Dreaming Question, Again......
Wed May 31, 2006 2:03 pm
Hello guys,
Specifically V Jet.....
Where will Wunala Dreaming be during the dates of 9 Jun-12 jun 06???
I will be back out in LAX during that tiome and wish to try and get pics of her....Any info would be helpful...
Cheers, Access-Air
Remember, Wherever you go, there you are!!!!
777ER
Head Moderator
RE: Wunala Dreaming Question, Again......
Wed May 31, 2006 3:29 pm
Yikes, your real keen to catch it. Apparantly the weekend is the best time to catch her, mostly Saturday
Head Forum Moderator
[email protected]
Flown: 1900D,S340,Q300,AT72-5/6,DC3,CR2/7,E145,E70/75/90,A319/20/21,A332/3,A359,A380,F100,B717,B733/4/8/9,B742/4,B752/3,B763,B772/3, B789
With: NZ,SJ,QF,JQ,EK,VA,AA,UA,DL,FL,AC,FJ,SQ,TG,PR
access-air
Thu Jun 01, 2006 1:12 am
Its just that I was unable to get any ladning shots of it before and then it was re-routed subbed for another aicraft on an Asian route at the last minute....So I am having faith that it will show up when I am able to get a good shot of it...
Cheers, Access-Air
Slovacek747
Thu Jun 01, 2006 11:16 am
Is there any chance of me getting her on the LAX-SYD route in July? or does she only do lax-mel?
Slovacek747
ZK-NBT
Thu Jun 01, 2006 2:16 pm
Quoting Slovacek747 (Reply 3):
Yes there is a chance, does mainly LAX-SYD/MEL.
777ER
Head Moderator
Thu Jun 01, 2006 4:03 pm
If its A B744ER aircraft then you have a 1/6 chance
[email protected]
777STL
Thu Jun 01, 2006 7:59 pm
I flew QF 108 last August and it was an -ER, the 1030 departure before mine was also an -ER which leads me to believe the -ERs are heavily prevalent on the SYD-LAX-SYD routes.
PHX based
Brendan03
Thu Jun 01, 2006 8:17 pm
Quoting 777STL (Reply 6):
They use the ER's on the Trans-Pacific runs because of the higher payload allowences so they can run a full load without weight restrictions or the need to stop for fuel if running a full load on the -400s
The Standard -400s tend to operate more towards Asia/Europe
Coolier than thou.
SA7700
Fri Jun 02, 2006 5:03 am
She has been to JNB in the past. I went down to SYD onboard Wunala on 1 occasion.
SA7700
When you are doing stuff that nobody has done before, there is no manual – Kevin McCloud (Grand Designs)
polar1
Fri Jun 02, 2006 12:02 pm
Does anyone forsee Wunala going into SFO then continuing on to YVR as part of the seasonal service? If so, I will try NRSA between SFO-YVR to experience. Big grin
Theme planes flown on: N218UA, N425QX, N443SW, N501SW, N610DL, N629SW, N653UA, N784AS, N792AS, N821SK
airnewzealand
Fri Jun 02, 2006 1:40 pm
Just to let you know also...ALL -ER aircraft are AVOD bar Wunala!
access-air
Fri Jun 02, 2006 2:47 pm
Quoting Airnewzealand (Reply 10):
What is AVOD????
Access-Air
Lp0815
Fri Jun 02, 2006 3:02 pm
Audio Video On Demand
Time waits for nobody
ZK-NBT
Fri Jun 02, 2006 3:04 pm
Quoting Access-Air (Reply 11):
What is AVOD????
Audio Video on Demand.
They have 6 ER's, it takes 2 to run a daily SYD/MEL-LAX, MEL-LAX non stop is exclusivly ER's which takes 2 aircraft, then some days the others are all used on SYD-LAX, sometimes they do go to JNB as SA7700 said. Also now with the SFO service they visit there aswell meaning that you won't always have 2 ER's on LAX-SYD daily.
N593HA
Fri Jun 02, 2006 3:07 pm
What is AVOD????
AVOD is short for "Audio and Video on Demand".
AVOD has become a sort standard (even in Y class) on modern laong haul aircraft over the last couple years!
Even NW (often know for low standard on board service) has installed PTV's with AVOD in both WBC and Y on their 332 and 333 aircraft.
N593HA
Next trip: KL+NW to HNL
fly_yhm
Fri Jun 02, 2006 3:08 pm
does she ever go through BNE?
Where will you spend eternity? He,s more real then you think!!!!!
ZK-NBT
Fri Jun 02, 2006 3:24 pm
Quoting Fly_yhm (Reply 15):
Very rarely. Since BNE is a 2 class route.
access-air
Wed Jun 07, 2006 11:32 am
Okay Guys,
Does anyone know how to contact V-Jet....he had the inside poop on the whereabouts of Wunala Dreaming....I really want to photograph it so I ned anyone's help in figuring out just exactly where it is...can you all help???
Access-Air
