A342
A380Domestic With A346 Wings + 748i Engines?
Thu Aug 17, 2006 4:27 am
Air Deccan: A380 Perfect Airplane (by Columba Aug 15 2006 in Civil Aviation)
Based on this discussion, I thought the following: If Airbus could combine the A380 fuselage with the A346 wing and slab the engines of the 748i on it, they could produce an A380 which is well adapted to short-range ops.
As the A380 fuselage is wider and the A346 wing smaller, a new central wingbox is needed. Still, wingspan would be below 65m. The A346 wing can support a MTOW of 380 tonnes. Empty, the normal A380 weighs about 280 tonnes. With the A346 wing, maybe the weight will get down to 265 tonnes. Also, Al-Li alloys and a lighter landing gear can be used. The A380 max. payload is about 85 tonnes, leaving 30 tonnes for fuel. This should be enough for domestic flights in Japan or India.
The more powerful engines of the 748i will compensate for the increased drag of the A380 fuselage (compared to the A346). Fuel burn would be significantly less than on the normal A380.
What do you guys think ?
Exceptions confirm the rule.
ksupilot
RE: A380Domestic With A346 Wings + 748i Engines?
Thu Aug 17, 2006 4:36 am
This may be a good idea for areas with a high population density. But then again, wouldn't something like the 787-3 or -8 be better for these areas, still large, but deffinatly less expensive to buy and operate.
So I think if the situation calls for something as large as a A380 on a domestic route, the airlines are more likely to look to the 787 or the A350XWB.
A342
Thu Aug 17, 2006 4:58 am
Quoting KSUpilot (Reply 1):
What capacity would the 783 have in an all-Y layout, at max. seating density ? I guess maybe a little bit more than the 763, which makes about 360-370 seats. The A388 can accommodate 853. As the engines are in the same thrust ballpark, the A38D should have a similar CASM.
The list prices of 2 783s vs. one A38D should be comparable.
gigneil
Thu Aug 17, 2006 5:01 am
I don't believe that there is sufficient market demand for such an aircraft. The 744D and 747SR sold in very low numbers to pretty much only the Japanese market, and they're now flying 772s and 773s on those same routes.
The modifications you suggested would be extremely expensive.
NS
zvezda
Thu Aug 17, 2006 5:03 am
There are neither enough airports nor enough routes to accomodate it.
RichardPrice
Thu Aug 17, 2006 5:08 am
I have no evidence for this, Ive never been able to find anything in print, but when the Airbus Research Labs opened up near me (Bristol, UK) they had on local news an Airbus rep talking about the A380.
One of the throwaway comments he made was that the A380 wing was designed with a two engine version of the A380 in mind for high capacity shorthaul flights, in a similiar way that the A330 wing is an A340-300 wing with the outer engine mounts removed. No other details were discussed, but that stuck in my mind.
Imagine a 700 seater commuter aircraft doing the rounds between Paris, London, Amsterdam.
A342
Thu Aug 17, 2006 5:12 am
Quoting Zvezda (Reply 4):
Regarding the airports, it is shorter than a 773 and the wingspan is comparable to a 744, so where is the problem ?
[Edited 2006-08-16 22:13:29]
787engineer
Thu Aug 17, 2006 5:28 am
Quoting A342 (Thread starter):
Way over simplification. Commercial airplanes are designed largely as a whole, you can't simply put a A346 wing on an A380 fuselage. The wingbox is an issue, but there's also balance issues, and the entire center section and the sections directly forward and aft of the wing will see a significant amount of redesign work. Which brings to mind what's going to happen with the main landing gear? You can make a lighter landing gear but it will likely have to position differently than on the A346 due to the wider fuselage of the A380. The wing will end up having to be redesgined to accomodate the wider stance of the MLG. The A346 wing is designed for fairly long routes, and putting it on an A380 will not make it suitable for short-range flights.
For most domestic flights there are planes leaving all the time (i.e. once every hour or two and usually with 737s/A320s and the occasional widebody at peak hours) so upgrading to 2 787/A350 will be better than having one A380. For international, long distance flights most of the planes leave within a small window of a few hours and increasing capacity can be difficult.
Quoting Gigneil (Reply 3):
Quoting A342 (Reply 6):
Most airports need to be modified to accomodate the width of the A380, not the length or weight. Most taxiways will have to be widened from 100 feet to 150 feet. IIRC the A380's wingspan is about 50 feet longer than the 744s
[Edited 2006-08-16 22:31:08]
A342
Thu Aug 17, 2006 5:32 am
Quoting 787engineer (Reply 7):
I know that, and that's why I mentioned that the wingspan is almost the same as the 744 !
Stitch
Thu Aug 17, 2006 5:37 am
I imagine you wouldn't want to lighten the undercarriage of an A380D since it would be subjected to significantly more landing cycles then her long-haul sisters. Plus more of the structure would probably need to be strengthened, as well, to handle the additional takeoff/landing/pressurization cycles.
If a 787-3 is too small for your needs, the 773A should be a perfect fit and I am sure you can get a good deal from Boeing.  Wink And a 787-3 can service a good deal more airports - and be less of an impact on the infrastructure - then the A380D/747D/773A. Plus frequency would probably be a boon more then capacity to these emerging markets, since traffic will probably ramp up over time.
787engineer
Thu Aug 17, 2006 5:40 am
Quoting A342 (Reply 8):
~50 ft. is a pretty significant difference not to mention on the A380 the engines are further outboard so there's FOD considerations and concerns of blowing up a lot of dirt/dust (erosion).
axio
Thu Aug 17, 2006 5:41 am
Quoting RichardPrice (Reply 5):
I think you'd want minimum 4 airbridges for getting on and off, otherwise you'd spend longer waiting to get off the plane that you'd spend in the air!
[Edited 2006-08-16 22:42:06]
Time for a new viewing deck at AKL!
RichardPrice
Thu Aug 17, 2006 5:43 am
Quoting Axio (Reply 11):
They did it in 78 seconds just the other month, and I know commuters can move faaaaaast  Smile
A342
Thu Aug 17, 2006 5:45 am
Quoting 787engineer (Reply 10):
Again: with the A346's wing, the A380 wingspan is similar to the 744. Not with the original wing, of course !
DAYflyer
Thu Aug 17, 2006 5:51 am
Immagine a 747-400 with 2 GE 90-115B's.........
One Nation Under God
Stitch
Thu Aug 17, 2006 7:25 am
Quoting DAYflyer (Reply 14):
http://www.cardatabase.net/modifiedairlinerphotos/photos/big/00005184.jpg
ebbuk
Thu Aug 17, 2006 7:33 am
You know the plane could take off.
Perfect for to lure Boeing loving Southwest and Ryannair over to the Airbus camp.
Train in the sky using LCC economic model? Cost it up A342, it's got money-maker written all over it
 Smile
MrChips
Thu Aug 17, 2006 9:11 am
I'm sorry, but this idea is so ridiculous that it borders the absurd.
Aircraft are not LEGO sets; you cannot just pull huge components and structures off one and slap them on another...it just doesn't work like that.
It would probably be so expensive to develop this aircraft that it would be cheaper just to design and build one purposefully for the job - and it would probably perform much better as well.
Time...to un-pimp...ze auto!
cobra27
Thu Aug 17, 2006 3:54 pm
It would cost a lot to do it. The current wing is better in my opinion
sk909
Thu Aug 17, 2006 5:42 pm
Quoting RichardPrice (Reply 12):
Yeah baby...  Smile
Well, theoretically, it would be plausible. A A380, with slightly shorter wings and 2 engines. The problem at hand is the max landing weight. So sending the A380 a diet, making it loose 30-50 tonnes, and we have a deal.  Smile
Life's for Living!
Aither
Thu Aug 17, 2006 6:14 pm
A Cessna would be even less expensive to operate.
Never trust the obvious
Robbie86
Thu Aug 17, 2006 7:06 pm
Quoting A342 (Reply 2):
But it has only been approved for 555 pax (I think it was 555).
cobra27
Thu Aug 17, 2006 7:14 pm
The ultimate A380 would be strech - 900 for domestic use. It would pack at least 1100 passenger and the ticket would be really low even at current oil prices
solnabo
Thu Aug 17, 2006 8:03 pm
I can see EasyJet / Ryanair go for the -900 with 1100 pax from Gatwick/Luton to Paris - Rome - Barcelona etc. etc.
OMFG!!!!
Micke//SWE  rotfl
Airbus SAS - Love them both
brendows
Thu Aug 17, 2006 8:07 pm
Quoting Robbie86 (Reply 24):
Wrong, it passed the evac test with 853 pax + 20 crew members on top of that. 555 pax is Airbus' standard seat config for the A380.
Coal
Fri Aug 18, 2006 12:34 am
Quoting MrChips (Reply 17):
Legoguy seems to think differently
Coal
Nxt Flts: SQ SIN-KIX | HD UKB-CTS | NH CTS-NRT | SQ NRT-SIN | AK SIN-DPS-SIN
deputydawghere
Fri Aug 18, 2006 4:23 am
Definitely would not want to be sitting on one of these flights, or should I say standing.
N/A
sk909
Fri Aug 18, 2006 5:15 pm
Quoting Deputydawghere (Reply 26):
Well that's a lot of people. I am glad that I don't have to sit with all those people.
I like jet with 130-170 PAX. That is just perfect.
Life's for Living!
deputydawghere
Sat Aug 19, 2006 4:06 am
Quoting SK909 (Reply 27):
130-170 is a good number. Can you imagine trying to get off a plane in an emergency situation with 853 passengers on board? Airbus is a kick ass company though and I'm sure they've thought that potential situation out thoroughly.
N/A
A342
Sat Aug 19, 2006 4:28 am
Quoting Deputydawghere (Reply 28):
See here:
deputydawghere
Sat Aug 19, 2006 5:40 am
Quoting A342 (Reply 29):
See here:
Maybe you (A342) should read my post about Airbus before your last post, "Airbus is a kick ass company though and I'm sure they've thought that potential situation out thoroughly."
N/A
787engineer
Sat Aug 19, 2006 6:14 am
Quoting SK909 (Reply 19):
I don't think there will be much of a problem with the max landing weight. A smaller short range wing will make the plane a little lighter, and I think A342 is suggesting the plane use 4x GenX engines. The A346 wing though is still designed for "long-range" and won't be very efficient on short hops. The extra weight to strenghten the plane for the increased number of cycles, more pax facilities etc, would probably cancel out most of the savings of the lighter, smaller wing. Just my  twocents
HKGKaiTak
Sat Aug 19, 2006 12:25 pm
What's wrong with Thalys and Eurostar? They already carry this number of pax between those cities at high speed ... and unless you have 15 airbridges it would take forever to get 700 pax on and off an aircraft ...
4 Engines 4 LongHaul
A342
Sun Aug 20, 2006 4:23 am
Quoting Deputydawghere (Reply 30):
I had already read your post when I made mine ! I just wanted to say: They did not only think about the situation, but also successfully verified their thoughts in that case.
deputydawghere
Sun Aug 20, 2006 12:32 pm
Quoting A342 (Reply 33):
Everyone's well aware of Airbus' successful evacuation test, it's old news.
N/A
