cvg2lga
Sept. DL/CVG Flight Cuts
Tue Aug 22, 2006 12:40 pm
K, everyone in my building has thier finger on the panic button waiting for September when DL is supposedly cutting mass flights. Can anyone tell me how many are expected so far? I know that 32 & 42 will go away as they are seasonal as well as AF 383. Any other info around?
Tchau
DA-
They don't call em' emergencies anymore. They call em' Patronies.
MAH4546
RE: Sept. DL/CVG Flight Cuts
Tue Aug 22, 2006 12:42 pm
They are adding a daily flight to Ottawa in September.
a.
sq452
Tue Aug 22, 2006 1:45 pm
Quoting MAH4546 (Reply 1):
Ottawa is Comair I believe, I think he is talking about mainline.
I was checking bookings in December and it looked like they were keeping Air France as you could still book it.
Sad to see that DL is dumping so many Cincy flights. Pretty soon if they keep it up DL's cuts at CVG will start to look like US's cuts at PIT.
SIN > CVG > BOS
N839MH
Tue Aug 22, 2006 1:48 pm
As for the DFW-CVG market...still 4 flights a day...although they
will all be DCI flights since the B737-200's are gone!
Solodude!
MSYtristar
Tue Aug 22, 2006 1:51 pm
CVG-MSY is seeing one additional roundtrip...3x daily DCI (2x ER4, 1x CRJ).
panamair
Tue Aug 22, 2006 2:43 pm
Quoting CVG2LGA (Thread starter):
Both 32 (CVG-FCO) and 42 (CVG-AMS) are still operating daily in both September and October (though October is certainly subject to change). They are currently scheduled to go away starting with the winter schedule in effect from Sun Oct 29.
SESGDL
Tue Aug 22, 2006 2:51 pm
CVG will actually be gaining flights in September. The cuts at CVG are done, which involved ending service to some cities and reducing frequencies across the board. Mainline has been reduced but mostly only to short to mid-range destinations. This September, CVG will retain mainline service to SEA, PDX, SFO, LAX, SNA, SAN, PHX, LAS, HNL, SLC, DEN, ABQ, TPA, SRQ, MCO, JAX, FLL, RSW, RDU, DCA, BWI, EWR, LGA, JFK, BDL, BOS, CMH, PIT, SDF, CUN, LGW, CDG, and FRA. Overall CVG will see around 440 daily flights to 120+ destinations this fall. All of these people saying CVG will be cut are wrong, CVG is going nowhere. It's just not as central a player as ATL, JFK, and SLC will be with DL's expansions in the future.
Jeremy
SLCUT2777
Tue Aug 22, 2006 10:06 pm
Quoting SESGDL (Reply 6):
There are still places out west where there is DL mainline service to like ABQ, whereas SLC is only offered SkyWest CRJ flights to. CVG also has flights to LGW and CVG, something SLC will be very lucky to ever see even though they talk about adding such next summer.
DELTA Air Lines; The Only Way To Fly from Salt Lake City; Let the Western Heritage always be with Delta!
Delta787
Tue Aug 22, 2006 10:15 pm
It looks like mainline flights may be down a bit but thats thanks to the retirement of the 732 fleet. I doubt CVG will be cut again.
Fly Delta!
laxatljfkcvg
Tue Aug 22, 2006 10:21 pm
cvg should not be the only delta hub to cutback. Atl stl should also cutback.
CentPIT
Tue Aug 22, 2006 10:30 pm
Quoting SQ452 (Reply 2):
I think CVG will be seeing a few cuts this coming year! The huge connecting days for cities with low O&D (CVG has lower O&D than PIT) are slowly coming to an end. This is my opinion.
O&D as of 2005-
CVG- (5,508,440)
PIT- (7,096,350)
Info as of June 2006-
CVG is served by 8 passenger carriers with service to 118 non-stop destinations. CVG had an average of 627 daily departures in June 2005 and for June 2006 has an average of 471 daily departures.
PIT is served by 12 passenger carriers with service to 73 non-stop destinations. PIT had an average of 319 daily flights for June 2005. For June 2006 PIT had an average of 280 daily flights.
I don't see CVG as a hub much longer!
Pittsburgh International: US Airways---160 daily departures! (52 destinations)
DAL767400ER
Tue Aug 22, 2006 10:46 pm
Quoting Laxatljfkcvg (Reply 9):
WTF?!? Why would Delta even spare a micro-second thinking about cutting back ATL, and what does STL have to do with DL at all?
flyinryan99
Tue Aug 22, 2006 10:52 pm
TOL is dropping another one to 4x daily E135s. The route used to be 12x daily back with ACA. DL is not adding JFK nor any to ATL to compensate for the loss of seats to CVG.
CentPIT
Tue Aug 22, 2006 11:21 pm
Quoting DAL767400ER (Reply 11):
I would have to agree here! ATL is Delta's baby!
ATL O&D as of 2005- (26,226,920)
Delta would be stupid to drop any ATL flights.
flyCMH
Tue Aug 22, 2006 11:33 pm
It looks as though Delta has finally finished their September schedule. I'm not exactly sure what cutbacks are scheduled to occur at CVG, but other cities see some changes for the upcoming month. CMH looses frequencies to 3 cities, but as part of the JFK build-up, sees an increase in JFK flying by 2 flights, while a 4th flight is supposed to start in October, presumably in preparation for jetBlue's arrival in CMH:
SLC: 2x E70 ---> 1x E70
DCA: 2x CRJ, 1x ER4 --->1x E70, 1x CRJ
MCO: 1x CRJ, 1x ER3, 2x ER4 ---> 1x CRJ, 1x ER3, 1x ER4
JFK: 1x CRJ ---> 2x CRJ, 1x ERJ (additional CRJ in Nov.)
However, several routings, including DCA as mentioned above, get flights upgraded/added with Embraer 170s:
FLL: 1x ER4 ---> 1x E70
TPA: 2x ER4 ---> 1x E70, 1x ER4
ATL: 2x 738 (3x 738 on Tue/Wed/Fri), 2x M88, 1x ER4 ---> 3x 738, 1x M88, 2x E70, 1x ER4
Looking further into the schedules, it looks like the upgraded 170 routes go back to ERJs in October, except for ATL. I'm wondering if this has to do with Shuttle America's pullback from SLC as Skywest receives more CRJ-900/705s. Along with SLC-CMH being knocked down to 1x daily, it looks as though SLC-IND has been discontinued altogether for the fall schedule. The route is currently operated by Shuttle America.
VgnAtl747
Tue Aug 22, 2006 11:50 pm
What DL needs to do is fix ATL baggage so it's not as pathetic as it is. I open more bag claims for people operating one segment, from ATL to my city, than another other senario. It's pathetic that someone can check in 2 hours before a flight out of ATL and their bag doesn't make the flight.
Work Hard. Fly Right. Continental Airlines
chrisnh
Wed Aug 23, 2006 12:01 am
Is that lone-wolf 737-200 between CVG and PWM (Portland, Maine) gone or going to go?? It's a single circuit each day; odd since most of the secondary New England cities have been reduced to RJs to/from CVG and ATL (except, I think, PVD and BDL).
Chris in NH
Delta787
Wed Aug 23, 2006 12:08 am
Quoting ChrisNH (Reply 16):
Yes its gone. The route is going all RJs.
Fly Delta!
CentPIT
Wed Aug 23, 2006 12:18 am
It is strange to see the mainline RON (B738) returning to Pittsburgh.
FlyPNS1
Wed Aug 23, 2006 12:19 am
While the number of frequencies moving through CVG is holding almost constant, CVG is losing additional capacity. The lost capacity is due to the retirement of the 732's (being replaced by smaller CRJ700's) and the replacement of CRJ's with smaller ER3's. Most of this downgrading has already been occurring over the past few months.
SLCUT2777
Wed Aug 23, 2006 5:52 am
Quoting FlyCMH (Reply 14):
This one really surprised me since the loads were there. I suspect a codeshare with CO or NW was wanted, but not available for a mainline flight as CLE became along with the shortage of mainline equipment. Perhaps NW will pick this one up as they start to build capacity. The retirement of the 733's and 732s impacting this and the desire to explore more opportunities with Shuttle America to maximize the SLC hub. Flying SLC-IND through CVG is a back-tracking pain!
jetlanta
Wed Aug 23, 2006 7:01 am
Quoting FlyPNS1 (Reply 19):
True. But CVG is now performing very strongly and will likely see larger equipment over the course of time, as larger RJ's and smaller mainline aircraft are introduced into the fleet. The 732 retirements hurt pretty bad, but the good news is that the CVG hub has effectively been fixed and could now see some moderate growth into the future.
FlyPNS1
Wed Aug 23, 2006 8:54 am
Quoting Jetlanta (Reply 21):
Maybe, but there's another scenario that may also play out. As DL works to push fares higher (and they will), CVG will continue to take a larger brunt of the fare hikes. This will over time erode CVG's O+D numbers. In order to keep the right mix of O+D versus connecting, DL will further reduce capacity. I don't think it is out of the realm of possibility to see CVG get shrunken down to a MEM/CLE sized hub. In terms of mainline flights, it's just about there already.
In terms of growth using larger RJ's and new mainline, I expect most of that capacity will go to support JFK, ATL and SLC....all of which are more strategically important to DL.
jetlanta
Wed Aug 23, 2006 12:43 pm
Quoting FlyPNS1 (Reply 22):
However, only ATL produces margins like CVG at the moment. Delta cannot continue to fund expansion at JFK and SLC without making sure that ATL and CVG are maximizing profits. At some point, this will mean optimizing the equipment mix at CVG. The Comair situation is causing some uncertainty for the moment, but CVG is too important to Delta right now in terms of actual performance not to get some attention as larger equipment (CR7, CR9, maybe a 100 seater) comes available.
I don't disagree with your observation, but as we head into 2007 and some of this year's big strategic network changes start to settle in, I think that you will see some new attention paid to CVG. 2006 is an investment year so JFK and SLC get lots of love, 2007 will be a p&l performance maximization year, so I think CVG is going to get some more attention as it is delivering now, with much less investment and sub-optimal equipment.
slcdeltarumd11
Fri Aug 25, 2006 12:33 pm
Quoting Jetlanta (Reply 23):
I think deltas planning on CVG to be RJ central. RJs are not much love  Sad Will CVG will become STL????
I believe Delta already has more mainline love to SLC, ATL, and maybe JFK than to CVG. I don't think delta will be showing much love to CVG in 2007. I think all the love will go to ATL, JFK, and SLC.
I think any love from DL will be from the connection carriers not on mainline flights.
From the other posts people estimated delta mainline( i dont feel like counting). I think this is the most accurate info oviously changing when you look seasonal flights etc. etc.
estimates
ATL 600 ish
SLC 95 ish
JFK 65 ish
CVG 60 ish
SESGDL
Fri Aug 25, 2006 2:56 pm
Quoting SlcDeltaRUmd11 (Reply 24):
ATL 600 ish
SLC 95 ish
JFK 65 ish
CVG 60 ish
Yeah, those numbers are about right. Sad knowing that in DL's September 1997 timetable CVG had 220 mainline flights a day, with widebodies on CVG-SEA, PDX, SFO, LAX, SAN, PHX, SLC, DEN, ORD, LGA, BOS, MCO, TPA, FLL, and ATL as well as internationally to LGW, CDG, BRU, FRA, and ZRH. How times have changed.
Jeremy
Ih8b6
Fri Aug 25, 2006 3:08 pm
"Moderate growth" it may be, but it will never be what it was....
Too bad "larger" equipment doesn't mean "mainline"
CVG is and has been RJ central since Delta began slowly quietly pulling back on mainline service since 2000-01 era.
Cut from mainline flying is what it is. Like you said, 220+ a day on mainline in '97 and now in the 80 or so range a day in 06. What a difference 9 years makes!
Over-moderation sucks
2H4
Fri Aug 25, 2006 3:20 pm
Any idea whether CVG - MSN flight frequency or capacity is changing, and if so, to what degree?
2H4
Intentionally Left Blank
skibum9
Sat Aug 26, 2006 4:16 am
Quoting 2H4 (Reply 27):
Yep, I really miss taking that half empty L1011 from CVG to LGA. Those were the days!
Tailwinds!!!
iowaman
Sat Aug 26, 2006 4:36 am
CVG-MSN will go from 2x CR1 to 3x CR1 eff. 06 Sept.
2H4
Sat Aug 26, 2006 4:47 am
Quoting Iowaman (Reply 29):
Thanks, Iowaman.  Smile
2H4
