Quoting AS739X (Reply 2): Possibility of AirTran TOL-LGA? |
Quoting MarkATL (Reply 4): suspect CoExp, DL Conex, or AE will be bellying up to the table for this helping of corporate welfare. |
Quoting TAN FLYR (Reply 5): For Sure..what a waste of tax dollars..makes me sick. It is not as if there are no flights available in a reasonable distance to NYC. This is just local greed to subsidize service that can not exist profitably on it's own merit. ( at most an hour from most anywhere in metro TOL to DTW via either 75/275 or 23/94) The EAS is another example of this for many communites to have "airline service", when reasonable and affordable service is usually an hour or so drive away. Now if it a community say, Pierre, Sd (and I don't know if they are an EAS airport) that is diffferent. |
Quoting BillReid (Reply 7): The TOL SCASD grant application was based upon B6 target. You can assume that they will be looking for B6 to enter and stimulate service. |
Quoting Tys777 (Reply 6): I agree, it is a waste of tax money b ut when they offer it, why not use it? An hour to DTW? more like 1 1/2 minimum |
Quoting BillReid (Reply 10): Unfortunately that site is now closed because the awards have been issued. |
Quoting Tys777 (Reply 3): I don't see that happening, Airtran used to fly TOL back when they were a shell of the airline that they are now. If I remember right, they weren't getting the loads that they wanted due to not have the connections that passengers wanted. I believe the route was TOL-ATL. |
Quoting TAN FLYR (Reply 5): For Sure..what a waste of tax dollars..makes me sick. It is not as if there are no flights available in a reasonable distance to NYC. This is just local greed to subsidize service that can not exist profitably on it's own merit. ( at most an hour from most anywhere in metro TOL to DTW via either 75/275 or 23/94) |
Quoting MarkATL (Reply 9): If there was a market for NYC-TOL non-stop service then their would be a flight. Glass capitol of the world or not, TOL is a low level secondary market. I think the people of Toledo could find better uses for their $$$. The two most populated cooridors into TOL are from the north and the east. you only have to go a few miles north before DTW is not that much farther. To the east CLE isn't that far either. I used to go Port Clinton all the time and didn't mind one bit flying into CLE. |
Quoting Tys777 (Reply 6): An hour to DTW? more like 1 1/2 minimum |
Quoting Ouboy79 (Reply 18): Allegient was pulling 80% loads and TOL was their 4th largest city for the first half of the year. |
Quoting Ouboy79 (Reply 18): I believe the route was TOL-ATL. The loads were actually doing great before they left, but it was all low yeild traffic |
Quoting Flyinryan99 (Reply 15): Fares, fares, fares. It was said up higher that DTW is $183 and TOL is $402. |
Quoting MarkATL (Reply 22): The service will most likely be once a day. Don't look for any carrier to open a new station for this. The only ones going for this pure pork will be an airline that already has an station at TOL. In short, B6 is a loooooooong shot at best. |
Quoting Joeman (Reply 23): Good loads and can't make money in a market that is obviously there. |
Quoting Tys777 (Reply 21): The southern suburbs always took me around 1 1/2 to get to DTW, give or take 10 min |
Quoting MasseyBrown (Reply 17):
So did my family, from Maryland. Didn't you take the Port Clinton oath? ... to keep the place secret? |
There is a market for Las Vegas service, but the nonstop isn't there. Why? Costs are too high. Allegiant was pulling 80% loads and TOL was their 4th largest city for the first half of the year. |
Quoting MarkATL (Reply 26): Bottom line is I see any airport so close to another i.e. TOL to DTW. to be awarded ans EAS grant to be nothing more than pure waste of taxpayer money. The "E" stands for essential. There should be a seperate programe for these vanity requests via the commerce department or someting (if at all). The EAS was inot intended to help keep people from driving an additioal hour. It was intended to help people not drive an additional 4-5 hours. |
Quoting MarkATL (Reply 26): I'm going to be nice and call this comparrison niave. |
Quoting MarkATL (Reply 26): As for Toledo itself, the best thing I can say about is, I had a great time there a couple years ago; but only after I nailed that girl from Holland (OH) at her place on my last night there. |
Quoting Ouboy79 (Reply 27): Umm...do you even know what the SCASD program? Or Small Community Air Service Development program. This is for non-EAS markets that need a little help getting going. Such as Akron-Canton, Flint, and the numerous other mid size cities awarded over the years. This would explain why your posts are so negative on this grant, since it appears you think this is an EAS award...which it isn't. I guess (to borrow from your post) ..... |
Quoting MarkATL (Reply 29): Ouch, I'm not even going to defend that then. Sometimes you just gotta admit you're a schmuck. I applaude your clever use using my own words, albeit out of context. |
Quoting Ouboy79 (Reply 27): Umm...do you even know what the SCASD program? Or Small Community Air Service Development program. This is for non-EAS markets that need a little help getting going. Such as Akron-Canton, Flint, Sarasota, and the numerous other mid size cities awarded over the years. This would explain why your posts are so negative on this grant, since it appears you think this is an EAS award...which it isn't. I guess (to borrow from your post) ..... |
Quoting Flyinryan99 (Reply 28):
This is relevant how? |
And please get with it...the award is for the SCASD as mentioned above not EAS |
The market is there, just wait, you'll see. Just need to give it a kick start. |
Quoting TAN FLYR (Reply 31): Well, IMHO..EADS/ SCASD..whatever you want to call it in this case. TOL is not a small community nor should it be considered for EAS considering its' proxsimity to DTW or CLE as far as large metro airports are concerned. This is still a grand waste of tax dollars. Why should the taxws I pay support lower fares for NW Ohio residents/business for travel to NYC? |
Quoting TAN FLYR (Reply 31): Just to throw another factor in, heck if you look at the map of NW Ohio, many potential TOL pax conceivably reside closer to FWA also.( this is using the logic of an hour to 90 min drive to an airport) |
Quoting TAN FLYR (Reply 31): Maybe, we should make a case for folks in Ohio & Michigan to subsidize service from FAT to ORD, so my travels to the Chicago/Great lakes/ North East might be better than a connection in DFW/PHX/DEN/SLC/LAX/SFO ? |
Quoting TAN FLYR (Reply 31): It isn't as if there are no alternatives for TOL pax to get to NYC! This is another government program with great intentions that had enough loopholes in it to be ized and fly a 737 thru. |
Quoting MarkATL (Reply 32): That's your job as a community, not the federal government's job. Most people want the federal government out of local matters. Until that is they think it can benefit them. |
Quoting Ouboy79 (Reply 34):
They found a way to do it with less...400K |
Quoting Ouboy79 (Reply 34): TOL has roughly a 2-3% leakage to FWA...70-80% goes to DTW. |
Quoting MarkATL (Reply 35): I'm still convinced this is more about vanity than actual need. It ain't because of the market. Otherwise an airline would already be flying it. |
Quoting Joeman (Reply 40): Hmmmmn. Looks like the market is there, but why service the market when passengers can have the pleasure of being routed through the likes of DTW (even by just driving) or ATL. Another station to maintain is costly and really, that would chip away at the overly inflated passanger base that keeps DTW and ATL fuctioning at the level their at. Vanity? What if DTW or ATL were to rely on their own O&D. |
Quoting Ouboy79 (Reply 41): Then what would be the point of offering any O&D markets except at the large hub airports? I mean its almost as if people just throw common sense out the window when they post here. Sure ATL, CLE, etc all have the nonstop service. However it seems as though, those from the larger cities feel these smaller ones shouldn't have the service. |
Quoting Joeman (Reply 42):
I support the service. My response was regarding vain large city hub netters that think the world revolves around them |
Quoting MarkATL (Reply 43): However, when the largest airport in the world is also pulling 43% O/D passengers; I hardly think the civic leaders would be beggin' da man for some money to get an air to fly what would other wise be a money loosing route. |
Quoting MarkATL (Reply 44): At 43% O/D Atlant does pull the numbers, enough so that even AA operates p2p service ATL-LGA in comptition to DLs service. I fail to see your point here. |
Quoting Joeman (Reply 45): Toledo have a lousy flight to NYC unless you are already aware of actual TOL-NYC O&D. |
Quoting Flyinryan99 (Reply 15): CO most likely won't go after this especially with them bringing Dash 8s on the TOL-CLE route in the near future. |
