Quoting Ralgha (Reply 3): Maybe the UK is different, but the the pat-downs in the US that you get with the "SSSS" are a joke. |
Quoting 757lgw (Thread starter): so i was also thinking if the ban is still in place do you think i would get away with selotaping it to the inside of my boxers? |
Quoting GeorgiaAME (Reply 2): According to Gatwick's web site, it is still no liquids in carry on, flying into the States. I don't recall if it's the same restrictions out of the UK to other destinations, but you can check their web site. On this side, max of 3oz placed in a clear, zip lock bag that gets screened separately. Yeah, it's a real pain in the butt. The fanatics have won, I'm afraid. We only respond after they have made their moves. |
Quoting 757lgw (Reply 10): i guess that way if i do get caught i can just say i didnt know it was banned |
Quoting 757lgw (Thread starter): Im just wondering if anyone knows if the liquid ban will end anytime soon |
Quoting Phoenixflyer (Reply 5):
Its having terrorists bringing on the components to a small explosive and mixing them on site. These terrorist organizations are not stupid. They know what they are doing and they do their research. |
Quoting AlexPorter (Reply 15): Is it 3 oz total for all liquids, or is it a max of 3 oz per each liquid? |
Quoting Ralgha (Reply 19): Common ingredients are sulferic acid and 50% solution hydrogen peroxide. That stuff is nasty |
Quoting Ralgha (Reply 19): Do you have any idea how unstable these components are while mixing? |
Quoting Phoenixflyer (Reply 21): hydrogen peroxide isnt nasty at all, |
Quoting Phoenixflyer (Reply 21): An easy was to start a fire would be to use water and solid potassium. |
Quoting Ralgha (Reply 3): Things such as gasoline could be taken through security without much problem at all, even when there was a total ban on liquids, and even if you got the "SSSS" on your boarding pass. Maybe the UK is different, but the the pat-downs in the US that you get with the "SSSS" are a joke. |
Quoting ADXMatt (Reply 22): Depends on the airport.... On a recent trip the outbound screeners didn't detect my hairgel but they did on the return. |
Quoting FL370 (Reply 13): the xray machines can tell if you have a liquid in your bag, it shows the shape the bottle or w/e is holding the liquid. it shows as a light grey outline! |
Quoting FutureFO (Reply 1): In the US you can bring a small amount of liquids thru security. no more than 3 oz per liquid item. I am sure the UK is also under a reduced restriction, since the US and the UK seem to play monkey see monkey do all the time with each other. |
Quoting ATCme (Reply 25): Think before opening your mouth. |
Quoting ATCme (Reply 25): and how would they get it onboard without moisture touching it? |
Quoting BayAreaPilot (Reply 29): Anyone who knows anything about chemistry knows the chances of mixing an explosive strong enough to take down a plane on board said plane are essentially zero. |
