Quoting Scaredflyer21 (Reply 3): Thanks for the replies. So with this in mind, how long is the training for different carriers. For instance, does Southwest have a shorter training period than say American or United with their more diverse fleets? |
Quoting Aa757first (Reply 1): It's just exit operation, galley features, IFE, etc. Maybe one or two days? |
Quoting Mjlhou (Reply 5): Yes...all F/As flying for a US flag carrier are trained on all of their aircraft, and for one major reason. |
Quoting Mjlhou (Reply 4): all F/As flying for a US flag carrier are trained on all of their aircraft |
Quoting Mjlhou (Reply 5): For AA approx. 4-5 weeks or at least used to be. |
Quoting WNCrew (Reply 9): Quoting Mjlhou (Reply 5):Yes...all F/As flying for a US flag carrier are trained on all of their aircraft, and for one major reason. Actually at AA FA's are not trained on all aircraft as there are seperate FA's for Intl. and domestic. I'm not sure if this is true of any other carrier though. |
Quoting IAirAllie (Reply 11): Quoting Mjlhou (Reply 4):all F/As flying for a US flag carrier are trained on all of their aircraft Not true while it is usually common practice to train the entire FA group on all equipment it is not by any means a universal proceedure. At AA in initial training FA's are not trained on all aircraft. The A300 and 777 are used primarily for international routes. All FA's start out domestic you have to bid for international training spaces and go through approximately two more weeks of training where you are trained on the A300 and 777. Also when they flew the Fokker, only FAs going to a Fokker base got trained on that equipment. It was an additonal day of training. When I worked for ASA only FA's going to a Delta Connection base got trained on the Dornier jet only and FA's going to a United Express base got trained on the CRJ and J41 (some UEX groups also got Dornier training). |
Quoting Mjlhou (Reply 12): I'm not sure how this would make sense as I've seen FAs on reserve be used for flights to and from other bases and for all aircraft. |
Quoting WNCrew (Reply 15):
Quoting Mjlhou (Reply 12):I'm not sure how this would make sense as I've seen FAs on reserve be used for flights to and from other bases and for all aircraft. Yes, you may have seen FA's on Intl RSV being used for Intl trips. The fact still stands, not ALL FA's at AA are trained on all aircraft....the end. Just as IAirAllie pointed out, everyone starts out domestic and then bids Intl. training slots. I just had an AA FA jumpseating on board and she was telling me how since she switched bases to go Intl so she was on her way to learn the 777 and A300. AA is unique on this front, as ALL other Major US carriers have all FA's crosstrained. |
ok...as far as I know they are trained initially on all ac in the fleet at the time of training. I do understand that, for example, if an FA is rather senior and flying international and then AA chose the 738, then that FA would not be required to go back and train on it unless they were to bid a route that the 738 were to fly. For example, in 2001, it was on the international bid packet for ORD-CUN for a while. One of my good friends was then sched for training at DFW after he was awarded this bid. |
Quoting Mjlhou (Reply 19): Again, I do understand how AA works, as I have actually worked for them before. Let me clarify AGAIN. FAs are trained on all aircraft that areIN THE FLEET AT THE TIME OF TRAINING. |
