Quoting Knightsofmalta (Thread starter): Before I get flamed here, don't shoot me I'm only a layman. My question is this: The B. 777-200 is roughly the same size as the A. 340.500 and the B. 777-300 is more or less in the same category as the A. 340-600 if I'm not completely wrong. In comparison, which model preforms better? I don't want to be converted one way or another here, I just want to know if anybody can give me an unbiased comparison of the aircraft's performance, such as which is more fuel efficient etc... |
Quoting Dambuster (Reply 2): To resume, the T7 is a more economical aircraft and as JMO-777 said, the season of HIGH fuel prices brings the preference to the T7, from the investor's point of view, the 773ER is the best option...though none of the above is my opinion, simply economics. |
Quoting VHVXB (Reply 3): how about carrying cargo? Is the B77W able to carry more cargo and pax than the A346? |
Quoting KC135TopBoom (Reply 4): There is one major difference where the A-340 has an advantage over the B-777. All A-340s can fly great circle (the shortest route), any where, at any time. This may (or may not) shorten the distance between almost any city pairs in the world. The B-777 can only fly great on some missions. But, on most missions, it must fly ETOPS, because it is a twin. IIRC, all B-777-200LRs are certified to 240 minutes ETOPS, and some airlines will get certified to 330 minutes, which is getting closeer to great circle routing. |
Quoting VHVXB (Reply 3): Is the B77W able to carry more cargo and pax than the A346? |
Quoting KC135TopBoom (Reply 4): Both carry about the same number of passengers, |
Quoting KC135TopBoom (Reply 4): the B-777 burns about 2/3 the fuel of the A-340. |
Quoting KC135TopBoom (Reply 4): There is one major difference where the A-340 has an advantage over the B-777. All A-340s can fly great circle (the shortest route), any where, at any time |
Quoting KC135TopBoom (Reply 4): all B-777-200LRs are certified to 240 minutes ETOPS |
Quoting Knightsofmalta (Thread starter): In comparison, which model preforms better? |
Quoting Brendows (Reply 6): ETOPS isn't a problem on that many out of the longer range routes, except from over the North Pole, parts of the Pacific and the southern Atlantic and Indian Ocean. |
Quoting Brendows (Reply 6): But the A340 cruises at a lower speed, and may use more time to get to the destination even if if flies the shortest path |
Quoting Brendows (Reply 6): and the shortest path may not be the quickest due to unfavourable winds. |
Quoting Brendows (Reply 6): The 77W burns about 5-9% less fuel than the A346 on longer sectors |
Quoting Brendows (Reply 6): Are you sure about that? I believe they are certified for ETOPS 180, like the rest of the 777s... |
Quoting OldAeroGuy (Reply 7): ETOPS isn't a problem over the North Pole |
Quoting OldAeroGuy (Reply 7): but the rest is correct if you throw in the far South Pacific and the South Pole. |
Quoting Aerohottie (Reply 11): Simply put... the higher costs of acquiring the 777s have to be made up by the savings on fuel. |
Quoting SKY1 (Reply 10): It's true 340's cruises at a lower speed, but the difference is marginally lower. |
Quoting SKY1 (Reply 10): So what? Due to the same argument the alternative (and longer) airway for the 777's could be, also, under "unfavourable" winds. |
Quoting SKY1 (Reply 10): Actually it's daring to give un percentage about how the T7 burns less fuel. It's always a rough estimate. |
Quoting SKY1 (Reply 10): And a T7 is more expensive than its european competition. |
Quoting SKY1 (Reply 10): FAA is allowing up to 207' ETOPS (180 + 15%) |
Quoting KC135TopBoom (Reply 4): Yes, the B-777-300ER can carry more cargo, further, than the A-340-600. Both carry about the same number of passengers, and as already said, the B-777 burns about 2/3 the fuel of the A-340. |
Quoting Brendows (Reply 6): But the A340 cruises at a lower speed, and may use more time to get to the destination even if if flies the shortest path, and the shortest path may not be the quickest due to unfavourable winds. Also, ETOPS isn't a problem on that many out of the longer range routes, except from over the North Pole, parts of the Pacific and the southern Atlantic and Indian Ocean. |
Quoting Trex8 (Reply 9): wbp's previous tables show for a 6000nm flight a 77W burns 39303 USG carrying 123600lb payload, a A346 41344 USG and 117946lb. Even if you make the payload difference up in extra fuel for the A346 its only a 6% difference. Where on earth do you get 30% differences??? |
Quoting FlyDreamliner (Reply 14): Airlines are not passing over the A346 left and right for the 77W for 6%. There is a reason even traditionally airbus airlines are buying 77W. It's well better than six percent on the whole. |
Quoting Aerohottie (Reply 11): Simply put... the higher costs of acquiring the 777's have to be made up by the savings on fuel. As the price of fuel softens this margin is harder to make up... making the A340's more competitive and puts more price pressure on Boeing 777's. |
Quoting Trex8 (Reply 15): don't shoot the messenger, if you have better figures than wbp's to illustrate your point, cough them up for everyone here. wbps figures show 6% better fuel burn and 5% better payload for a comparable length flight. that certainly would be enough difference for many airlines to pick the 77W when most of the airline industry can barely break even these days. |
Quoting DfwRevolution (Reply 16): 4. Boeing no longer imposes outrageous premiums. ... Plus, Boeing implemented production line enhancements which have lowered unit cost. This gives Boeing more discount leverage and/or higher yields. |
Quoting Atnight (Reply 18): from my personal pax stand point.. I would fly a A340 any day over the B777... too bad airlines don't choose for their pax comfort, |
Quoting Areopagus (Reply 20): I don't understand this statement. The 340 has narrower seats than the 777, and its curved sidewalls prevent me from sitting up straight in a window seat. To me, the 340 is a burnt pancake. |
Quoting KC135TopBoom (Reply 4): |
Quoting Brendows (Reply 6): The higher gross weight versions of the A346 can actually carry a marginally larger payload than the 77W can. |
Quoting DfwRevolution (Reply 16): Enhanced variant is dead and almost out of memory. |
Quoting VHVXB (Reply 22): So no airline has placed an order for the HGW version? |
Quoting VHVXB (Reply 22): thanks for the info |
Quoting Atnight (Reply 21): but I prefer the A340, and I was noting that the best thing that the A340 has over the B777 is the quietness... the B777 is very loud, |
Quoting FlyDreamliner (Reply 17): I'm just saying, other routes will have other figures, and there is more to the equation. |
Quoting Trex8 (Reply 25): totally agree, I just couldn't fathom how OAG came up with a 33% fuel burn difference. |
Quoting OldAeroGuy (Reply 26): It wasn't me who said 33%. My value is around 20% fuel burn per passenger advantage to the 773ER based on equivalent seating arrangements. |
Sir, you must be quite tall (or wide) to not be able to sit straight in a window seat of the A340 |
Quoting Atnight (Reply 18): I would fly a A340 any day over the B777... too bad airlines don't choose for their pax comfort, but what makes more money to them |
Quoting Trex8 (Reply 25): I just couldn't fathom how OAG came up with a 33% fuel burn difference. I |
Quoting KC135TopBoom (Reply 29): For the most part, comfort (interior configueration) is mostly the responsibility of the airline. |
Quoting Atnight (Reply 21): (but configurations and layouts change from airline to airline, so is really up to what airline you fly on that makes the difference in that sense).... |
Quoting Areopagus (Reply 28): I recently flew in a 330 behind the wing, not in a window seat, and didn't find it noticeably quieter than the 777 -- until the pilot throttled back for descent. |
Quoting JMO-777 (Reply 1): PS: Try a little search in this forum, there a tons of similar threads. |
Quoting Irobertson (Reply 33): Is there any increased risk in running a dual engine aircraft as opposed to quad when it comes to a catastrophic engine failure in flight, especially on approach or take-off? Just wondering if a 777 lost an engine, it would basically lose 50% of its thrust right? And if an A340 lost an engine, that's only 25%? I mean, I know the situation is potentially unlikely but if it were to happen, would it be harder to fly the 777 with half the thrust and the slew that would need to be offset with a lot of rudder? It would appear the 340 might have *some* advantage here... Or maybe not? |
Quoting Irobertson (Reply 33): Is there any increased risk in running a dual engine aircraft as opposed to quad when it comes to a catastrophic engine failure in flight |
Quoting ChiGB1973 (Reply 34): The BA incident where the 747 ingested volcanic ash also came to mind. |
Quoting Areopagus (Reply 32): Come to think of it, while riding in that A330, I listened to the noise and concluded that it must have less noise coming from the air conditioning outlets. I hope Boeing pays attention to that with the 787. |
Quoting BillReid (Reply 36): White noise is better that people noise, think itt through.. |
Quoting SSTsomeday (Reply 35): It's true that, in general, 4 engined A/C have better climb statistics with a single engine failure, and they are not restricted to any operational ETOPS limitations, so they can fly as long and far as they are able over isolated terrain or water without needing an enroute alternate landing site. |
Quoting BillReid (Reply 36): Boeing actually researched noise level for the 787 and the avg. most pax didn't want a large reduction in noise because an aircraft would start sounding like an over packed restaurant with 400 guests. A great deal of noise is the ventilation system in these newer acft. White noise is better that people noise, think itt through.. |
Quoting Areopagus (Reply 38): I take foam ear plugs along on long flights on which I will need to sleep, because the people noise is irritating even over the aircraft noise. |
Quoting Michi (Reply 41): Two more things to consider: - The A346 is able to fly the L888 airway, which is north of the Himalya mountains. This airway makes the trip from europe towards the southern part of china shorter (~1-2h). That saves a lot of money.... |
Quoting Michi (Reply 41): - You don't have to wait that long to get an A346 compared to the 777. So you can start earning money earlier... |
Quoting SSTsomeday (Reply 42): I ALWAYS wear earplugs, even if I am reading or working. 'Much more relaxing to me. |
Quoting Starlionblue (Reply 44): I wear earplugs or my noise cancellation Solitude headphones. I don't understand how one can fly longhaul without. Seriously, earplugs are like $0.30 for a pair and make a huge difference in terms of fatigue. |
Quoting SSTsomeday (Reply 45): Errr - I make mine out of toilet paper..... costs nothing. I can show you how if you want, but PLEASE don't tell anybody.... |
