Quoting Warreng24 (Thread starter): Why was the DC-10 designed and certified to require a 3 person cockpit? The DC-9 was developed about 5 years earlier and it had a 2 person cockpit. |
Quoting EMBQA (Reply 1): Why was the DC-10 designed and certified to require a 3 person cockpit? The DC-9 was developed about 5 years earlier and it had a 2 person cockpit. Because the DC-10 is three times larger then the DC-9 and has three times as many systems. |
Quoting TrijetsRMissed (Reply 3): and 737 all had 3 man crews at one time. |
Quoting EMBQA (Reply 4): Quoting TrijetsRMissed (Reply 3): and 737 all had 3 man crews at one time. We have gone around and around on this one. The B737 never had a F/E. For one thing where would you put him..?? On the Co-Pilots lap..?? in the forward lav..?? |
Quoting VEEREF (Reply 7): IIRC wasn't it Ansett that operated 767's that were built with F/E stations to meet local pilot union criteria? |
Quoting TrijetsRMissed (Reply 3): Also 3 person cockpits were not uncommon when the DC-10 was designed. The L-1011, 727, 747, and 737 all had 3 man crews at one time. |
Quoting Charlienorth (Reply 5): My quote function is tango-uniform...but some carriers actually did operate the 737 with a 3rd man,he sat in the fold down jumpseat,at UAL they were nickmaned "social director',the major carriers (UAL and WAL)flew withe this arrangement,the local service companies (PI and Frontier) operated with a crew of two up front...believe it was eliminated in the late 70's or very early 80's |
Quoting TrijetsRMissed (Reply 6): It was designed with a 3 man crew for 737-100. Just because it has long been changed does not mean it never happened. |
Quoting Mav75 (Reply 9): Quoting VEEREF (Reply 7): IIRC wasn't it Ansett that operated 767's that were built with F/E stations to meet local pilot union criteria? Either them or QANTAS. |
Quoting EMBQA (Reply 4): The B737 never had a F/E. |
Quoting Warreng24 (Thread starter): Why was the DC-10 designed and certified to require a 3 person cockpit? |
Quoting Mav75 (Reply 9): All widebodies of the era had the 3 man cockpit. My guess on the reason is that there was not enough automation for the size and complexity of these aircraft to eliminate the need for the F/E. |
Quoting Warreng24 (Thread starter): Why was the DC-10 designed and certified to require a 3 person cockpit? The DC-9 was developed about 5 years earlier and it had a 2 person cockpit |
Quoting Lucky42 (Reply 10):
I know someone who was hired on at UAL as a 737 FE only for a short time before going to the DC-8. |
Quoting EMBQA (Reply 20): Where did he sit...? In the forward lav...?? There is no FE station in the 737 or any place other then the jumpseat to sit. There is no panel to work or tasks for an FE to perform. |
Quoting Higherflyer (Reply 19): IIRC, the FAA had an aircraft weight limit for certifying 2 man vs. 3 man flightdecks. |
Quoting Timz (Reply 22): Didn't UA's 737s have a FE panel, along with the FE? |
Quoting VEEREF (Reply 17): As a crewmember on the DC-10, I can also certainly vouch for the added benefit of a third brain and set of eyeballs up front as well. |
Quoting Wjcandee (Reply 24): While this makes sense intuitively (the "extra set of eyeballs to be scanning the skies"), it also creates a different CRM environment. Most ironically, some of the better-known accidents involving CRM actually occurred with more-than-the-usual-compliment of pilots in the cockpit. |
Quoting Wjcandee (Reply 24): Sometimes, it seems, the CRM environment in which multiple people seem to agree that something is okay tends to drown out that third person's voice of reason...I don't doubt that in high-workload sections of flight, having a 3-man crew is extremely helpful, but I think it turns out that it doesn't necessarily make anything "safer". |
Quoting Wjcandee (Reply 24): Most ironically, some of the better-known accidents involving CRM actually occurred with more-than-the-usual-compliment of pilots in the cockpit. In Eastern 401, the L1011 that flew into the swamp while everyone screwed with a burned-out lightbulb in the gear lights, there were actually FOUR guys in the cockpit, the three mandated and an Eastern pilot jumpseater. |
Quoting Mav75 (Reply 25): It's not always all bad either. A classic example of this is UAL 232 (which, ironically for this thread, happened to be a DC-10) which benefitted from having a DC-10 flight instructor |
Quoting Mav75 (Reply 25): It's not always all bad either. A classic example of this is UAL 232 (which, ironically for this thread, happened to be a DC-10) which benefitted from having a DC-10 flight instructor. Almost every CRM class I've sat through uses that flight as a model of how to do it right. In fact, if I'm right, the concept of CRM as we know it now was created AFTER this accident to help create a safer and more cohesive and effective team up front. |
Quoting EMBQA (Reply 1): Because the DC-10 is three times larger then the DC-9 and has three times as many systems. |
Quoting Mav75 (Reply 25): A classic example of this is UAL 232 |
Quoting C133 (Reply 29): Somehow either Boeing or it's customers floated the idea that the 76 could be safely operated by two pilots |
Quoting N1120A (Reply 31): [the 767] was designed from the start to have 2 crew |
It was designed from the start to have 2 crew |
Quoting Cedarjet (Reply 34):
The 767 was always built as a two-man cockpit. The flight engineer's station for the Ansett -200s was added afterwards, as a customer option. I flew in the jumpseat of an Ansett 767-200 with a flight engineer's panel and everyone in the front office, "flight engineer" included, thought it was a hilarious jape to have a dude with his own little panel of buttons to press, none of which did anything. We laughed our arses off actually, cos I asked him what he did and none of them had an answer! I can attest to it being a very small panel, with very few controls or displays, I do recall four big orange buttons but that was all! Quite surreal. Eventually the panels were ripped out and replaced with the more usual bookshelf. |
Quoting Jetdeltamsy (Reply 28): 727's also carried flight engineers. |
Quoting N1120A (Reply 31): The 767 was designed with the exact same cockpit as the 757 and they hold the same type rating. It was designed from the start to have 2 crew |
if I'm right, the concept of CRM as we know it now was created AFTER this accident [United 232] to help create a safer and more cohesive and effective team up front. |
Quoting Timz (Reply 32): You mean, it was designed from the start to be capable of using 2 crew, right? But three crew was planned as an option? |
Quoting FLY2HMO (Reply 33): Depends how you look at it. Still the really early 767s had a simple FE panel, and a seat for the FE, IIRC. But it was so basic they figured they could just squeeze everything in the overhead panel. |
Quoting Timz (Reply 32): It wasn't until 1982 (?) that that blue-ribbon commission (or whatever it was) ruled that two crew was enough for future widebodies; ALPA had agreed to accept their ruling. |
Quoting Levg79 (Reply 39): Actually, in the 1990s when airlines of the former Soviet Union started operating 767s, they had a 3-man crew. As I recall speaking to one of former SU and later 9Y pilots, the 3rd person was responsible for talking on the radio and calling out altitudes during landing, among some other minor things. |
Quoting Lincoln (Reply 41): In a similar vein, on aircraft that still require flight engineers, are there still crewmembers who are "just" flight engineers? |
Quoting Mav75 (Reply 25): Almost every CRM class I've sat through uses that flight as a model of how to do it right. In fact, if I'm right, the concept of CRM as we know it now was created AFTER this accident to help create a safer and more cohesive and effective team up front. |
Quoting Lincoln (Reply 41): In a similar vein, on aircraft that still require flight engineers, are there still crewmembers who are "just" flight engineers? I seem to remember hearing about airlines using "non-professional" flight engineers which, at least the way I understood it were people who had captain/first officer ratings and would fufill the role of a flight engineer. I.e. of any given three-person crew, any crewmember was qualified to preform any function and the flight engineer on one flight may be a PIC the next day. (I'm doing a poor job of conveying this, but hopefully it makes enough sense) Lincoln |
Quoting Jetstar (Reply 46): When the first airline jets like the B-707 and DC-8’s came into the service the FAA required 3 pilots in the cockpit, so all the professional FE’s had to go and get their FAA commercial pilots licenses, even though they would never actually touch the flight controls of the airplane. |
