707437
Q. 777 Range Performance USA-India Routes
Sun Dec 24, 2006 12:24 pm
Now that the direct USA to India flights on 772ERs have been going on for a while how is the 772ER performing? (American ORD-DEL, Continental EWR-DEL, Delta JFK-BOM).
Have there been many instances of a 772ER having to make a stop to refuel while going in either direction? If so, is this a frequent occurence?
(Facts only! No guesses!)
jetjeanes
RE: Q. 777 Range Performance USA-India Routes
Sun Dec 24, 2006 12:58 pm
I have freinds that fly the ord to del once a month and have not had any problems other than missing connections in ord.. But that has got to be one of the longest flight from the U.s,,,, anyone Know of one longer???
They all have to get up and walk after several hours as their legs nearly fall a sleep
i can see for 80 miles
EWRCOPLAT
Sun Dec 24, 2006 1:23 pm
Quoting JetJeanes (Reply 1):
I know EWR-HKG is longer, and EWR-PEK is close to EWR-DEL in length..The longest US flight is EWR-SIN...I believe...
jetjeanes
Sun Dec 24, 2006 1:57 pm
Jeez thats almost a whole day without a cigerette....
pdxcof9
Sun Dec 24, 2006 1:59 pm
Quoting 707437 (Thread starter):
Yep EWR-SIN on singapore airlines...18 hours there i believe on a A345
Flown:733,4,7,8,752,763,TU3,CRJ,7,EM2,ER3,4,318,19,346,M80,90 Worked:CRJ,7,9,EM2,ER4,733,5,7,8,9,752,3,318,9
pdxcof9
Sun Dec 24, 2006 2:05 pm
18h 40m there 18h 25m back. 9600 miles in length.
707437
Sun Dec 24, 2006 2:16 pm
Well my question is still there for the US-India nonstops. . .
Have there been any refueling stops due to headwinds or any range issue for the 772ER?
In practice, is the 772ER running with a full passenger load on these routes?
So far I have yet to hear of any compatibility issues with the 772 and these routes in terms of range and "marketable" capacity. . .
stirling
Sun Dec 24, 2006 2:30 pm
Quoting JetJeanes (Reply 3):
Gimme a coupla stops thank you.
Delete this User
artsyman
Sun Dec 24, 2006 5:37 pm
Quoting Pdxcof9 (Reply 5):
This is the block time (Gate to Gate). The flight time is less. I flew this earlier this month and flight time was 17hr and about 30 min from EWR-SIN
zvezda
Sun Dec 24, 2006 6:23 pm
Nicotine addicts desiring to feed their addiction on an airliner can get their narcotic of choice in the form of chewing gum or a patch.
panamair
Mon Dec 25, 2006 12:05 am
Quoting 707437 (Reply 6):
I can only speak for the DL JFK-BOM-JFK flights, which are longer than AA and CO's DEL flights. Since the start of operations in November, there have been no refueling stops on the BOM flights in either direction. The eastbound, of course, is not a problem and has been going out with 100% pax. loads consistently; however the westbound I believe has load limitations, especially with 16 hour in-air flight times on some recent days. They have also reduced weight by taking out duty-free carts as well as other non-essential mid-galley catering carts, etc.
jacobin777
Mon Dec 25, 2006 1:47 am
Quoting Stirling (Reply 7):
One stop is fine, but two turns into a hassle....
Personally, it depends on where I'm sitting as to whether or not I need a stop or not....
"Up the Irons!"
mahan
Mon Dec 25, 2006 1:53 am
My family and myself have travelled on AA ORD-DEL several times this year. On the west bound, routinely the flights are load restricted to about 210 passengers max. This makes is harder for non-revs sincethey are ones getting bumped off.
One I even saw loads restricted to 195 pax ... and this flight has a capacity for 245 pax.
Airlines I have flown - IC, 9W, KF, AI, LH, BA, LX, CO, DL, UA, SQ, MH, AA
gearup
Mon Dec 25, 2006 7:04 am
Quoting Mahan (Reply 12):
And to think this used to happen SNN-JFK when Aer Lingus operated B720's on the route! That or a stop in Gander west-bound.
GU
I have no memory of this place.
mk777
Mon Dec 25, 2006 7:21 am
Well maybe AA needs to buy some 772LR's for the route so that they have no load restrictions  Smile
come fly with me
gopal
Mon Dec 25, 2006 10:19 am
Do the 777s used by AA or Delta have the GE engines rated at 92000 lbs of thrust ?
707437
Mon Dec 25, 2006 10:39 am
I think that all 772ERs for this route DL, AA & CO are RR powered. . .
707437
Mon Dec 25, 2006 10:43 am
OOPs CO's are GE90. . .
7of9
CI And SV At IAH This Morning
Mon Dec 25, 2006 10:44 am
Well at CO, before you book a flight on employee reservation, for flights to DEL, PEK and HONG KONG, you are adviced to also seek alternate airline tickets as thes flight are heavily weight restricted due to the enormous amont of fuel they have to carry for the long trip back to the USA, the aircraft might and will/does leave with lots of empty seats.
jacobin777
Mon Dec 25, 2006 12:04 pm
Quoting Gopal (Reply 15):
AA's are all RR Trent 892's...
DL's are RR's Trent 892's also..
DL's new 777-200LR's will be GE-90's (only engine choice)...
"Up the Irons!"
anax
Tue Dec 26, 2006 6:09 pm
Quoting Zvezda (Reply 9):
zvezda , you don't have to be that rude.....
god is a spotter!!!
zvezda
Tue Dec 26, 2006 6:54 pm
Quoting Anax (Reply 20):
I was speaking (well, writing) clinically about a medical problem. No rudeness was intended. I apologize if that wasn't clear.
