JetJock22
Old Dulles Tower
Fri Feb 02, 2007 5:43 am
I know that the old Dulles tower was closed this past summer, but is it still there or has it been demolished? If it is still there does anyone know what they plan on doing with it? Dulles just wouldn't be the same without that tower.
malaysia
RE: Old Dulles Tower
Fri Feb 02, 2007 5:53 am
They will turn it into an observation area perhaps, but for what I know, it will never be demolished, its a Historic Landmark.
There Are Those Who Believe That There May Yet Be Other Airlines Who Even Now Fight To Survive Beyond The Heavens
JetJock22
Fri Feb 02, 2007 5:56 am
Quoting Malaysia (Reply 1):
Thats what I was wondering. Glad to hear that.
CV990A
Fri Feb 02, 2007 6:11 am
Rest assured, the old tower is still there.
That would be nice, but unfortunately, if that happens, it won't be for a while as the tower sits above the airside part of the main terminal, so they would have to re-do the security layout of the airport. Dulles used to have an observation deck, but it is closed, and most of it is actually gone thanks to all the construction they are doing there.
Kittens Give Morbo Gas
Adam T.
Fri Feb 02, 2007 7:06 am
I'm not familiar with IAD but do you think they could turn it into maybe a restaraunt or bar like they did with the old tower at LAX?
boswashsprstar
Fri Feb 02, 2007 9:07 am
There is an observation deck of sorts in the Udvar-Hazy Center of the Air and Space Museum, where you can go up in a mock air traffic control tower and look out over the airfield.
Still would be nice if something similar could be done in the tower at the main terminal, though. Once the train system and the new security concourse is done, would the tower find itself located landside?
flyinback
Fri Feb 02, 2007 9:13 am
Actually, the old tower is still in use (or it was as of January 1). The new tower was supposed to be turned over to the FAA this summer, but they had a few problems (such as getting water pressure to the top of the tower). I believe it's pretty much ready to go and the FAA should be up there shortly (if they aren't already).
At any rate, you are correct in the fact that the old tower must remain as is. Because the main terminal is marked as a historic landmark, they cannot change the overall look of it (hence the additions for the rail going on the back of the terminal (and partially underground).
It would be an awesome restaurant or observation deck, but I'm haven't heard of any plans.
WesternDC1010
Fri Feb 02, 2007 9:20 am
Quoting Adam T. (Reply 4):
As far as I know, the old tower at LAX is not a restaurant, nor a bar. According to airchive.com, 'This tower, now used as an administration building, was erected at the opening of the new LAX terminal at the dawn of the Jet Age in 1960. It looks slightly different, with the removal of the louvers over the windows, than it did in its heyday.'
Maybe you're thinking of the Theme Building which has the Encounter Restaurant and Bar. The observation deck above has been closed since 2001.
[r][o][n]
Western DC-10-10
Western Airlines - The Only Way To Fly
remcor
Fri Feb 02, 2007 9:25 am
They should zone it as residential space.
It would make a sweet apartment.
Adam T.
Fri Feb 02, 2007 9:57 am
Quoting WesternDC1010 (Reply 7):
Yeah i'm thinking of the theme building......wasn't it at one point the ATC tower at LAX though? I always forget the old one they used way back.
WesternDC1010
Fri Feb 02, 2007 10:36 am
Quoting Adam T. (Reply 9):
As far as I know, the Theme Building has never been an ATC tower. I believe that the 1960's control tower went on-line before construction of the Theme Building was completed.
Here's a good site that chronicles post cards of the vintage 'Jet-Age LAX.'
LAX.html" target=_blank>http://www.airchive.com/SITE%20PAGES/VIN-LAX.html
[r][o][n]
Western DC-10-10
luketenley
Fri Feb 02, 2007 10:42 am
The old tower sits away from the Encounter theme building. Two seperate buildings. When you drive into the airport, I believe the old tower is one of the first buildings you can see. The new tower sits relatively close to the theme building. Am I right?
Pittsburgh International Airport lover
RDUDDJI
Fri Feb 02, 2007 11:10 am
Quoting Luketenley (Reply 11):
Not sure what the "Theme" building is...but the old Tower is connected to the main terminal. The "new" tower is approximately directly South of the midpoint of the C/D concourse adjacent to the H ramp.
Sometimes we don't realize the good times when we're in them
luketenley
Fri Feb 02, 2007 11:22 am
Quoting RDUDDJI (Reply 12):
The theme building is the Encounter restaurant, the wierd looking building that kinda looks something from the Jetsons.
RDUDDJI
Fri Feb 02, 2007 11:35 am
Quoting Luketenley (Reply 13):
Roooooooger.
United767
Fri Feb 02, 2007 3:32 pm
The old tower is still in use at IAD. Not sure when the new one will be in use.
I wish UA flew mainline to MYR, that way you wouldn't be stuck in a smelly Saturn for 12 hours.
pnqiad
Fri Feb 02, 2007 10:56 pm
Quoting BosWashSprStar (Reply 5):
True, but at $12 parking fee - that is one expensive observation tower. And landings on only one of the runways is comparitively close. The mid-field and terminal are quite far off.
