Quoting Malaysia (Reply 1): They will turn it into an observation area perhaps |
Quoting Adam T. (Reply 4): I'm not familiar with IAD but do you think they could turn it into maybe a restaraunt or bar like they did with the old tower at LAX? |
Quoting WesternDC1010 (Reply 7): Maybe you're thinking of the Theme Building which has the Encounter Restaurant and Bar. The observation deck above has been closed since 2001. |
Quoting Adam T. (Reply 9): Yeah i'm thinking of the theme building......wasn't it at one point the ATC tower at LAX though? I always forget the old one they used way back. |
Quoting Luketenley (Reply 11): The old tower sits away from the Encounter theme building. Two seperate buildings. When you drive into the airport, I believe the old tower is one of the first buildings you can see. The new tower sits relatively close to the theme building. Am I right? |
Quoting RDUDDJI (Reply 12): Not sure what the "Theme" building is |
Quoting Luketenley (Reply 13): The theme building is the Encounter restaurant, the wierd looking building that kinda looks something from the Jetsons. |
Quoting BosWashSprStar (Reply 5): There is an observation deck of sorts in the Udvar-Hazy Center of the Air and Space Museum, where you can go up in a mock air traffic control tower and look out over the airfield. |
