Quoting Avianca (Reply 3): only national or also international? |
Quoting CoolGuy (Reply 4): Any distance on Saturdays? I had no idea about that one. I'll have to see if any airlines take advantage of that. |
Quoting LTU932 (Reply 2):
Why was this perimeter rule introduced in the first place? |
Quoting CoolGuy (Reply 11): What's the deal with the near end of runway 22 at LGA. Is it really on stilts? When was that part added? |
Quoting CoolGuy (Reply 13): From the posts above, it seems that the ends of 22 and 13 have weight restrictions such that certain aircraft cannot land there. I wonder what that weight is. |
Quoting Commavia (Reply 6): Quoting Avianca (Reply 3): only national or also international? Nope, international is allowed to. |
Quoting Commavia (Reply 1): Don't have the actual statute to point you to |
Quoting CoolGuy (Reply 7): DAL |
Quoting CoolGuy (Reply 7): Are there any other rules like this |
Quoting Boeing7E7 (Reply 8): Ironically, the short 7,200' runways effectively limit the airports use anyway making the perimeter rule rather moot. |
Quoting BosWashSprStar (Reply 10): To be clear, international flights are allowed at LGA anytime, if they're within the perimeter, and the flights come from a pre-screened destination. |
Quoting BosWashSprStar (Reply 10): I suppose that theoretically if you could somehow make the customs arrangements work, you could fly a 757 between LGA and Europe on Saturday, but I don't think that's likely. |
Quoting Boeing7E7 (Reply 14): 13/31 Weight bearing capacity: Single wheel: 80000 lbs Double wheel: 170000 lbs Double tandem: 360000 lbs 4/22 Weight bearing capacity: Single wheel: 80000 lbs Double wheel: 170000 lbs Double tandem: 360000 lbs |
Quoting Glareskin (Reply 15): If this is correct I wonder why the US and European legacy airlines aren't flying smaller extended range jets i.e. the 757 to LGA. I guess they could charge higher prices and fill planes every saturdy from London, Amsterdam, Frankfurt etcetera. |
Quoting Glareskin (Reply 15): At least I would pay more to fly directly to this convieniant airport and avoid the JFK or EWR chaos, delays, taxi delays and don't forget the higher taxi fares to the city |
Quoting Glareskin (Reply 15): If this is correct I wonder why the US and European legacy airlines aren't flying smaller extended range jets i.e. the 757 to LGA. I guess they could charge higher prices and fill planes every saturdy from London, Amsterdam, Frankfurt etcetera. There are no FIS facilities at LGA....also I doubt BA or some other European carrier would want to invest the infrustructure at LGA for a once per week flight Or even better: Privat air. This would be perfect in their business model. |
Quoting Tsnamm (Reply 18): ]Because there are no customs facilities... |
Quoting Tsnamm (Reply 18): maybe from Ireland where customs is pre cleared... |
Quoting Tsnamm (Reply 18): but its not Laguardia "Intl." |
Quoting N1120A (Reply 16): Not really. A 757 can fly its max range off those runways, while a 767 could easily make a transcon flight. |
Quoting Steeler83 (Reply 21): Kevin's plane, an AA 767 from ORD, landed at LGA, or at least it looked like it landed at LGA. |
Quoting Steeler83 (Reply 21): I know you can see NYC from EWR, but that is lower Manhattan. |
Quoting N1120A (Reply 16): Compared to the length of flight, LGA isn't much closer to NYC than the other two airports, and it is horrible for public transport. As far as taxi prices go, JFK-NYC is at the very most $20 more each way than LGA and offers the alternative of real public transportation links. |
Quoting EXAAUADL (Reply 17): Not sure there would be much demand for a Saturday flight |
Quoting Glareskin (Reply 23): There is a line at the taxi stand but it is moving quickly. |
Quoting Glareskin (Reply 23): You should check the available flights two EWR and JFK on saturdays and you would see there is demand |
Quoting N1120A (Reply 24): That is the point. JFK and EWR soak up the demand. |
Quoting CoolGuy (Reply 11): When was that part added? |
Quoting N1120A (Reply 24): Same thing with JFK. Further, public transport is practically non-existant at LGA, while it is easily accessible at the other two. |
Quoting N1120A (Reply 22): Yes it did land at LGA, though ORD isn't exactly a transcon. |
Quoting Glareskin (Reply 23): You can see midtown from EWR too. In fact, EWR might provide the best view to Manhattan. |
Quoting N1120A (Reply 16): LGA is fully equipped with an FIS, it just happens to be too small to quickly inspect the passengers from a packed mainline flight. |
Quoting Glareskin (Reply 25): I see what you mean but my point is that if some airline from Europe would offer a flight to LGA it would be more attractive and therefore lucrative for the airline. |
Quoting Tsnamm (Reply 31): customs is dispatched from JFK to inspect flights...CET has no offices at LGA |
Quoting Milesrich (Reply 35):
The runways at LGA were not long enough to operate the 707/720, CV-880, or DC-8. |
