Quoting FreequentFlier (Reply 1): |
Quoting OPNLguy (Reply 6): Bottomline is that air travel has become so routine and so "normal" that people have become increasingly intolerant of any deviation from that norm. These same people seem to readily understand why their normal :30 minute crosstown car trip in dry weather will take longer when it's raining, or longer still when there's snow and ice out, but the concept of weather similarly slowing down airline ops seems to beyond comprehension to them. |
Quoting Goldenshield (Reply 8): Throw in high mins captains, MELs, fogged in takeoff alternates (yes, I've had none that were legal before,) flow, thunderstorms, icing, TSA butting their head into things, etc., and you've got it nailed. |
Quoting OPNLguy (Reply 6): Bottomline is that air travel has become so routine and so "normal" that people have become increasingly intolerant of any deviation from that norm. These same people seem to readily understand why their normal :30 minute crosstown car trip in dry weather will take longer when it's raining, or longer still when there's snow and ice out, but the concept of weather similarly slowing down airline ops seems to be beyond comprehension for them. |
Quoting Cadet57 (Thread starter): For instance after that massive blizzard in DEN where people ripping UA and F9 from limb to limb? Sure. But did they then make the cover of Business Week? |
Quoting MasseyBrown (Reply 12): You are seeing how New York-focused US news reporting is. If an event didn't happen in New York, it didn't happen. And if the event DID happen in New York, it is by that very fact much better (or much worse) than anything anywhere else. |
Quoting FreequentFlier (Reply 10): Apparently, acts of God now fall under "airline mismanagement". |
Quoting OPNLguy (Reply 6): For example, take one of the aspects of the jetBlue scenario at JFK, an aircraft stuck on the ramp awaiting an open gate. People assume that the crew that brings an aircraft into a gate is always the ones that push it off the gate, so surely it'd have been a "simple" matter for a crew to push an aircraft off a gate once empty and free up the gate for another waiting aircraft. That's not necessarily the case--crews often make connections between different aircraft as well |
Quoting WJ (Reply 14):
You see, this is an over complicated response to a simple problem. You have a plane at the gate and a plane stuck waiting for a gate. You have three options. |
1) Get a mechanic to brakeride and get the damn plane off the gate. |
2) send a set of stairs and a couple buses to what is gradualy escalating into a serious situation and get these poor people off!(BTW, the plane that was stuck for 9 hours was only several hundred feet from the terminal). |
Or, 3) let them wait. |
You declare in emergency and say, I am either getting a gate or these people are going to be evacuated, |
Quoting OPNLguy (Reply 15): An empty threat. There is no imminent life-or-death threat to passengers involved, only inconvenience. Commanding a passenger evacuation down the slides out into the snowy night only creates more passenger danger. In addition to the usual passenger injuries to be expected (ankle injuries, etc.), you now have dozens of passengers down on the ramp area, risking hypothermia without their coats and shoes (had to remove them for the slides, remember?), and passengers scattering on the ramp and subjecting themselves to slipping on glycol-contaminated surfaces, being run over by ramp equipment, or being ingested into running engines of other aircraft.. Any captain who commanded such an evacuation in these conditions would have to be out of his mind |
Quoting Goldenshield (Reply 13): Anna Nicole Smith didn't die anywhere near New York, and yet, her death pre-empted the local news in MANY stations across the country. |
Quoting MasseyBrown (Reply 18): so they do - overcover things in NY with an emphasis they don't always deserve. |
Quoting OPNLguy (Reply 15): You must not be in the airline biz, or the operational end of the airline biz, as if you were, you'd readily know that things are not always as "simple" as they seem... |
Quoting OPNLguy (Reply 15): Using external stairs (metal) during a rain or especially a snow event is an invitation for a passenger(s) to slip and go ass-over-tea kettle down the stairs and impact the concrete pavement at the bottom, which = lawsuits which = big bucks. |
Quoting Afay1 (Reply 17): Are you kidding me? Airlines such as SAS, Finnair, Aeroflot, Alaska, etc. seem to operate from remote and major airfields in winter using stairs-only and rarely is there any sort of problem. |
Quoting OPNLguy (Reply 15): An empty threat. There is no imminent life-or-death threat to passengers involved, only inconvenience. Commanding a passenger evacuation down the slides out into the snowy night only creates more passenger danger... Any captain who commanded such an evacuation in these conditions would have to be out of his mind. |
Quoting WJ (Reply 20): See, that is where your operational understanding comes into question. Using the slides is an extreme but if there are no stairs around (seams unreasonable but B6 decided not to send one) all you need a bus to get the people back inside. It is absolutly doable. |
Quoting OPNLguy (Reply 22): Please note that NONE of my comments should necessarily be construed as a carte blanche defense of what jetBlue did (or didn't) do. All I've tried to do here is point out some of the numerous variables involved, and how many folks don't understand nor appreciate them. If the solutions to all the problems were all as "simple" as people seem to think, don't you think the airline would have done so? |
Quoting WJ (Reply 14): B6 is getting the same heat that NW got a few years ago after their large scale mess in DTW. According to a NW manager I spoke to recently, NW now has a policy that no plane waits for more than 3 hours. |
Quoting WJ (Reply 25): It is the last resort that I threw out there but that will only come after not being able to get a stair truck out there. |
Quoting WJ (Reply 25): You want to tell me that in the entire JFK field there was not a single set of stairs that could be freed up to an hour to get these people off? |
Quoting WMUPilot (Reply 5): 4) Operations where snarrled for the better part of a week |
Quoting OPNLguy (Reply 27): Given the weather that day, do you think there was an endless supply of stairs? |
Quoting Tango-Bravo (Reply 28): My "take" on the subject of the reason for extended media "piling on" in the aftermath of B6's foibles of 14 Feb is that it is not so much about the manner in which B6 handled the events of that date as the extensive irrops and more than 100 daily cancellations that ensued for nearly a week, long after the storm was no longer a factor. Other airlines, it seems, are able to fully return to normal operations following large-scale irrops due to weather in less than half the time it took for B6 to do so. |
Quoting FreequentFlier (Reply 1): In an age of $50 fares, it seems like no carrier can deliver all the time. |
Quoting OPNLguy (Reply 6): Bottomline is that air travel has become so routine and so "normal" that people have become increasingly intolerant of any deviation from that norm. |
Quoting Fabio777 (Reply 38): So you think the passengers stuck int the airplane for 11 hours on the ground should "just" tolerate the situation since it is only a simple deviation of the norm. |
Quoting Cadet57 (Reply 39): Quoting Fabio777 (Reply 38):So you think the passengers stuck int the airplane for 11 hours on the ground should "just" tolerate the situation since it is only a simple deviation of the norm. What is the difference between this and flying LAX-NRT? You are still stuck with the same situation, well minus the lavs. And there would be food on board as B6 serves food. Stop playing devils advocate. |
Quoting Halls120 (Reply 40): If I'm on a Jet Blue flight to anywhere Jet Blue flies, I don't bring supplies for a 10 hour trip. Because at most, I'm thinking the flight will be 5 hours |
Quoting OPNLguy (Reply 6): It seems pretty clear that jetBlue made some mistakes (although I can't authoritatively say what they were since I don't work for them and wasn't there), but I do agree with you that they are taking more than their share of "blame" in things. |
Quoting Cadet57 (Reply 41): Quoting Halls120 (Reply 40):If I'm on a Jet Blue flight to anywhere Jet Blue flies, I don't bring supplies for a 10 hour trip. Because at most, I'm thinking the flight will be 5 hours Irrigardless. He posed the question saying he only brought enough supplies per TSA standards. So even if you brought the maximum you'd still be shit out of luck after a few hours. So I still fail to see where he is going with this. |
Quoting Halls120 (Reply 43): No one boarding a JetBlue flight plans on being on board for 10 hours. |
Quoting Cadet57 (Reply 44): I think you are missing my point entirely |
Quoting B767300ER (Reply 47): JetBlue must address these problems and appoint people who are willing and able to make decisions. They took a weather problem and failed to address it in a timely and operationally correct manner. They have these problems before, whether its snow or thunder storms in the summer, only now they are in the spotlight and need to take the corrective actions. |
