Quoting OA260 (Reply 5): is this normal for this type of ''teething problems''??? |
Quoting OA260 (Reply 7): One thing I wanted to know is when a new AC rolls out of the hanger do they do a certain amount of testing before it goes to the airlines and also do the airlines test it a certain amount of cycles before it does its first passenger flights???? |
Quoting Stylo777 (Reply 6): I suppose it is not normal, but take into account that this bird had a very busy week with all the flights between TLS-FRA-JFK-ORD. |
Quoting Ikramerica (Reply 10): The plane isn't suitable for service? |
Quoting OA260 (Reply 12): Well i guess these things happen but when I hear hydraulics problems it makes me curious exactly what it was and is it a problem easily solved or will it be a on going problem. I know its too early to decide but I agree a few flights to the USA and back is not more than what would be expected and it will be getting alot more abuse than that when it enters service . |
Quoting Stylo777 (Reply 11): Don't forget the plane is still in it's test phase so not ready for service |
Quoting FlyLKU (Reply 14): Does anyone know where they are likely to park at IAD? Will they use this as a familiarization mission and park at LH/UA's "C" gates or put it over at Signature where the German Air Force often has their A340? |
Quoting AirUtopia (Reply 3): It departed as usual at 1610 (confirmed by my local correspondent). It surprisingly returned at 1800 and parked and had covers put on the engines (confirmed by my int'l correspondent covering from inside the airport). |
Quoting AirUtopia (Reply 3): Therefore this tells me that the plane 'might' be delayed as COVERS are not normally placed for a few hours. Although it was last seen parked at 10pm local HKG time (10am EST US time Sunday). |
Quoting Stylo777 (Reply 13): to the hydraulic issue I heard that it wasn't a big problem. at first they wanted to fix it with parts of A346, but this didn't solved the problem. |
Quoting OldAeroGuy (Reply 18): It's not exactly in the test phase. |
Quoting OldAeroGuy (Reply 18): The A380 has a joint EASA/FAA Type Certificate. It's not exactly in the test phase. Most airplanes EIS about one month after getting a TC. |
Quoting Glideslope (Reply 22): Perhaps it was just a defective part. Although we really don't know how frequently parts are being replaced during test flights. |
Quoting Sabenapilot (Reply 26): Fortunately airlines can very well distinguish between inherently badly designed planes and planes which occasionally are faced with one off technical glitches (minor ones like we had here -a failed pressure transducer- or more serious and spectacular ones like the T7 engine failure during its demonstration flight on a sales campaign to SAA) and which are known to all planes. |
Quoting Zeke (Reply 20): Quoting OldAeroGuy (Reply 18): It's not exactly in the test phase. The aircraft still has a flight test engineer and test pilots onboard, and is still instrumented for testing. |
Quoting OldAeroGuy (Reply 28): Why? What testing is still being done? |
Quoting Skydogs (Reply 25): As a Signature Employee. I can tell you the GAF has never parked an A340. You may have seen the A310 |
Quoting FlyLKU (Reply 34): I've seen the A310 you are speaking of but I have also seen an A340 with what I thought were the same markings. I have seen it many times and was actually in your facility once joking with the guy about how much I'd like to put the fuel bill on my credit card to get the miles (ten years ago). Also, I'm sure you've seen the RAF's VC10 but I don't recall if they park over on your ramp. |
Quoting OldAeroGuy (Reply 28): However, I do agree with Sabenapilot that this type of occurrence happens in normal line operation. There are a lot parts on a commercial airplane so occasional equipment failures are inevitable. |
Quoting Skydogs (Reply 35): The 340 you speak of was/is HZ-124 until last summer more or less a base tenenat. VC-10's do still come. However, the RAFLO usually gets them routed staight thru to belize instead of stopping at IAD |
Quoting Cricket (Reply 41): Guess what I was on LH8948/AIB203 HKG-HKG. LH and Airbus had organised a two-hour 'experience' flight on the plane. TR coming later (along with a couple of mem cards full of pictures). But yes the plane was supposed to overnight in HKG. |
KongHong |
