SkyvanMan
DUS Transfer Info
Fri Apr 20, 2007 2:15 pm
I'll be flying LAX-DUS on LTU next month and will be connecting to DUS-CDG on AF and am wondering how the airport is set up. Will I have to go and claim my bag and then check in for Air France? Wwill I have to go in and out of security? What is there to do at the airport? Anyways I'd appreciate answers to all these questions and if anyone is wondering I booked both flights through LTU so they are on the same reference number (for Amadeus).
The 3 best planes of all time: Shorts Skyvan, 330 and 360
Someone83
RE: DUS Transfer Info
Fri Apr 20, 2007 2:32 pm
As you should be able to check your luggage all the way through to CDG would you not have to go and claim your bagage. Don't think you would need to go through security either. But, you would anyway have to go through passport control in DUS, but not in CDG as you enter the EU in DUS.
ACDC8
Fri Apr 20, 2007 4:45 pm
I don't believe that DUS has connecting facilities, so ...
You'll most likely be arriving at Pier C in DUS, once you deplane, you'll go through passport control, once through, continue down the hall to the baggage claim area. If your bags are not checked through (I don't know if LT and AF interline), pick them up here and continue out the doors. There are customs agents at the doors that do random checks. Even if your bags are checked through, you have to exit through the same doors. Also, if you do not have a boarding pass for your AF flight (again, I'm not sure with LT and AF), take the elevator to the departures level, the AF check-in area is located in the central area by the big escalators. Your AF flight will most likely leave from Pier B, where you have to go through another security check.
How much time do you have in DUS? If you have the time, the airport offers you 2 observation decks. The closest one is on the roof of the main terminal, just take the big escalators in the central terminal up to the top, you can't miss it. There is also a small aviation shop there. The other observation (and my favourite) is located at the train station. Just follow the signs to the SkyTrain (located towards the exits between sections C-B and B-A of the terminal). The monorail is free of charge and will take you directly to the airport train station. The cost is 2€ for both observation decks and are good all day.
There are also various restaurants and shops in the terminal. DUS is a great airport, it's really changed since it was rebuilt after the fire in 1996. Enjoy your trip!
Quoting SkyvanMan (Thread starter):
Just out of curiosity, how did you get an AF flight with LT? Most of their cnx flights (at least in the past) were through LH.
EDIT: Just a note on the SkyTrain, sometimes it's not working, so you have to take a shuttle bus to the train station. Just go back down to the arrivals area, go outside and it'll be signed out.
More info:
http://www.duesseldorf-international...x&path=04_infos_service/lageplaene
[Edited 2007-04-20 09:49:24]
[Edited 2007-04-20 09:52:46]
A Grumpy German Is A Sauerkraut
cgnnrw
Fri Apr 20, 2007 8:38 pm
I agree with ACDC8 - DUS is quite easy to navigate. Its a nice airport. Both obrservation decks offer great views. Keep your fingers crossed for good weather.The €2,-- entrance fee also covers the ride on the Skytrain. I never seen anyone controlling tickets on it but one never knows. As far as shopping goes, don't expect too much. The usual offerings of book/newspaper shops, a few clothing stores, an electronic store, pharmacy and of course the inevitable Starbucks  yuck , you'll pass it on your way to the oberservation deck in the main terminal. Enjoy your trip!
A330 man.
jog
Fri Apr 20, 2007 8:42 pm
Quoting ACDC8 (Reply 2):
Although I have not yet seen someone checking it, it is not free of charge. However, a ticket for the observation deck is accepted as a valid ticket. For more details see the mentioned website at http://www.duesseldorf-international...ckpath=04_infos_service/lageplaene
EDIT: Cgnnrw, you were a bit faster but its nice to see that our experiences and information match each other...
[Edited 2007-04-20 13:46:50]
ushermittwoch
Fri Apr 20, 2007 8:49 pm
Well, I think that LTU kinda works together with SkyTeam at the moment since they offer some interline with Delta in the US.
Anyway, DUS is easy to get around. And it also used to be the case that a valid ticket entitles you to a free ride in the SkyTrain, if it is operational.
Where have all the tri-jets gone...
Someone83
Fri Apr 20, 2007 10:42 pm
Yes they do, I've flown via DUS a couple times, either LHR-DUS-OSL or CPH-DUS-VIE and have never had to collect bagage or pass through security (except arriving from CPH, but that was because CPH for 6mth was classified as a "dirty" airport after they failed a security inspection)
ACDC8
Sat Apr 21, 2007 11:56 am
Quoting Jog (Reply 4):
Airline tickets, DB tickets, bus tickets and parking garage tickets are also valid, so more or less, it is free ...  Wink
Quoting Someone83 (Reply 6):
Did you switch piers? If you are flying, as an example with LH all the way through you do not have to do anything, just go straight to the gate as it would be in the same pier, your itineraries also did not require passport control (with the exception of LHR). As far as I know, DUS doesn't have anyway for you to switch piers without going landside.
Just a couple of shots from the observation decks ....
Terminal ....
Photo © Tommy Desmet
Photo © Danny Gans
Train station ....
Photo © Markus Willmann
Photo © Philippe Jeandy
Also, if the aircraft are arriving/departing from the west (RWY 05L/R), I wouldn't even bother with the observation deck at the train station. Most arriving aircraft turn off the runway before and most departing aircraft are already climbing.
Rivet42
Sat Apr 21, 2007 1:48 pm
Did you buy the flights as one ticket, or as two completely separate tickets? If the former, then you'll likely be able to check in at LAX all the way through to CDG. You will still need to go through immigration control, as DUS will be your entry point to the Schengen group of European countries, and your flight to CDG will then be treated as a domestic service (France & Germany are both in 'Schengen', which basically means no border controls between signatory countries).
Whether or not you are checked all the way through to CDG, it's still worth going out beyond customs, so that you can make the most of the roof terrace (assuming you have time). Welcome to a very spotter-friendly airport (as indeed they all are in Germany).
PhiL P
I travel, therefore I am.
