HeeseokKoo
LH MUC-PUS Load Factor 24%, -ICN: 59%
Thu May 31, 2007 10:19 pm
I found load factor of LH's newest 3/w MUC-ICN-PUS of last April.
MUC-PUS is only 24%, and MUC-ICN is 59.2% which means 35.2% are for ICN. It is not surprising that more passengers board at ICN. Is it okay for the first month of new route? There were a lot of promotions such as double milege and special fares. Hope this PUS's first european lasts long.
SailorOrion
RE: LH MUC-PUS Load Factor 24%, -ICN: 59%
Thu May 31, 2007 10:25 pm
What is the source of this information?
SailorOrion
HeeseokKoo
Fri Jun 01, 2007 12:32 am
Quoting SailorOrion (Reply 1):
A newspaper in Korea, www.traveltimes.co.kr
jimyvr
Fri Jun 01, 2007 12:34 am
Quoting HeeseokKoo (Thread starter):
I thought the way of calculating this stuff is a bit different?
1000 - 01MAR07 | http://airlineroute.blogspot.com/
airbazar
Fri Jun 01, 2007 12:40 am
Maybe I'm wrong but wouldn't it be the other way around? 24+59= 83% load on MUC-ICN with with 59% getting off in ICN and the remaining 24% continuing on to PUS?
A342
Fri Jun 01, 2007 1:21 am
Quoting Airbazar (Reply 4):
Sounds reasonable, but: you cannot add the load factors for MUC-PUS and MUC-ICN, as until ICN, all pax are on the same aircraft.
But maybe it's the wording: If the original poster meant that on the MUC-ICN leg, 24% of the seats are occupied by pax headed to PUS and 59% of the seats are occupied by pax heading to ICN, then you're right about the 83% load factor on the MUC-ICN leg.
Sorry if I'm nit-picking.  Wink
Exceptions confirm the rule.
jimyvr
Fri Jun 01, 2007 1:24 am
Quoting Jimyvr (Reply 3):
The aircraft configures F8C36Y197, so that's 241 seats
59% overall load factor to Seoul, including those continues to Busan, is about 142 people
So i guess that calculation of splitting percentage is right.
No. Because the figure of 59% includes those who are continue to PUS, but on the MUC - ICN portion. Unless LH calculates differently.
EXAAUADL
Fri Jun 01, 2007 1:36 am
Didnt NW fly to Pusan?
mucflyer
Fri Jun 01, 2007 1:41 am
sorry, but the information given by the newspaper is obviously totaly wrong!
The LH718/719 flight is doing very well from the first day of operation. Clearly more than expected, and we expected of course an high load factor and yield...  Smile))))
cheers
A342
Fri Jun 01, 2007 1:54 am
Quoting MUCFLYER (Reply 8):
Any chance of a frequency increase?
MAH4546
Fri Jun 01, 2007 2:57 am
Quoting EXAAUADL (Reply 7):
They still do. Daily from Tokyo.
a.
SailorOrion
Fri Jun 01, 2007 4:15 pm
Quoting A342 (Reply 9):
Good question. I have no official information, but as LH increases all intercontinental flights to dailies sooner or later we might see that as well. The bigger question to me is: When will PUS get a dedicated service (or will it at all?)?
SailorOrion
Fri Jun 01, 2007 8:38 pm
Quoting SailorOrion (Reply 11):
Currently LH is operating a 3/7 service MUC-ICN-PUS which is running well, so I think LH will first increase into a 7/7 service before thinking of a direct MUC/FRA - PUS flight. But I don't see both an increase or a direct flight happen before LH is taking delivery of the first 380's which will free up 343/346 equipment to do so.
flown: F50,F70,CR1,CR2,CR9,223,E75,E90,143,AR8,AR1,733,735,736,73G,738,
hardiwv
Fri Jun 01, 2007 8:50 pm
Quoting DALCE (Reply 12):
The above load factor information shows the contrary: the operations are NOT running well.
Can we perhaps expect a suspension of service?
Rgs
vinniewinnie
Fri Jun 01, 2007 8:57 pm
We need sources otherwise the info becomes totally unreliable and basically it will become a slanging match between 2 people both pretending they know better than the other...
HeeseokKoo
Fri Jun 01, 2007 9:16 pm
Quoting VinnieWinnie (Reply 14):
We need sources
I believe the other reliable source will be available soon. I was really curious how it works since it is the first PUS's european route, and also it is the first and the only ICN's night departure european route.
ohsopc
Fri Jun 01, 2007 9:39 pm
hmm slightly off topic but I wish LH still does MUC-BKK... the load factor on those flight were almost full all the time during the winter months... I think they just handed over the flight to TG
airbazar
Fri Jun 01, 2007 11:07 pm
Quoting Ohsopc (Reply 16):
That should explain why they quit  Smile High load factor in Winter usually describes a predominantly leisure destination which equates to low yield or barely profitable operation. Better to leave that to the charters.
hoons90
Sat Jun 02, 2007 12:09 pm
Quoting Hardiwv (Reply 13):
What about the cargo, though? And the loads up front..?
Flown: 2L 7C 9E 9L AA AB AC AF AY AZ BA BR BX B6 CA CO CP CX DL EK EY JL KE KL LA LH LX MQ NW OZ PD RW SQ TG TP TR TS US WG WN WS XE XJ
fly2yyz
Sat Jun 02, 2007 12:25 pm
Anyone know how much of a timeframe LH gives a destination before saying adios?
johnnybgoode
Sun Jun 03, 2007 10:57 pm
no, we can't, as it is simply too early to say whether it will be succesful or not.
Quoting Fly2YYZ (Reply 19):
there are many services which are still not profitable and they haven't been cut, so they give 'em quite some time to develop.
also, the individual performance of one service is not necessarily an indication whether the service is overall successful regarding the entire network (e.g. what it contributes to other destinations in terms of revenue).
additionally, SLF alone can never be an indication whether a service performs well. if yields are high, low load factors can be sustainable, if SLF is low, high yields can make it work.
so a mere analysis of SLF won't give you a clue whether ICN/PUS ex MUC is performing according to expectations.
If only pure sweetness was offered, why's this bitter taste left in my mouth.
Viscount724
Mon Jun 04, 2007 6:17 am
Quoting Johnnybgoode (Reply 20):
And some entire airlines are still not profiable. For example, Qatar Airways has, as far as I know, never been profitable since they started flying 14 years ago, and their CEO has said that they have no plans to become profitable for another 4 or 5 years. It helps to have an oil-rich government as a major investor!
airnewzealand
Mon Jun 04, 2007 10:57 am
Quoting Viscount724 (Reply 21):
WOW!!!! I never knew that regarding Qatar!!! Very interesting indeed!!!!
Avianca
Mon Jun 04, 2007 11:15 am
I asked me from the very beginning, why they didn't start PUS as a dedicated service, as for me the ICN-PUS makes 0 sense, for this they have with Asiana a perfect partner
flydreamliner
Mon Jun 04, 2007 2:01 pm
Yes, but Lufthansa is one of - if not the most profitable airline in the world. They know their stuff. It's very hard for us to know much from that raw and simple data. Maybe a large number of those seats being bought are by high yielding business pax, on full fares, many of which in J class. Then the flight very easily could be profitable. Even if it isn't, perhaps LH has good reason to believe it will become so. The people at LH are some of the very best at what they do around, I haven't seen them make too many mistakes.
"Let the world change you, and you can change the world"
HeeseokKoo
Mon Jun 04, 2007 3:35 pm
Quoting Avianca (Reply 23):
Somehow LH and OZ have not done any co-work for the last several years. They don't do any code-share, although both are in the same alliance. Moreover, OZ's ICN-PUS timing is not good for the LH's flights, and cancel a lot due to lack of aircraft.
