AlitaliaMD11
Delta Getting Rid Of Eyebrows On 737 Fleet?
Sun Jun 17, 2007 4:10 pm
I was at JFK today and caught N384DA and was surprised to see that she did not have any eyebrows:
http://i189.photobucket.com/albums/z189/JFKSpotting16/30dl738jfk.jpg
When did Delta start replacing them and how many of the fleet are without them now?
No Vueling No Party
reins485
RE: Delta Getting Rid Of Eyebrows On 737 Fleet?
Sun Jun 17, 2007 4:20 pm
Found this in another thread.
Quoting NZ1 (Reply 148):
There is an AD/SB that has been put out by Boeing to more closely inspect the eyebrow windows, due to a lot of cracking in the worldwide fleet. One fix is to remove the glass and replace it with a metal plug, which NZ have elected to do. The 1st aircraft should be done sometime over the next month or so.
New Zealand Aviation Thread #4 (by 777ER Apr 25 2007 in Civil Aviation)
So I guess this is the reason, it saves money because of less inspections and would not have to be replaced nearly as often because the windows are more likely to have problems than a piece of metal.
SOBHI51
Sun Jun 17, 2007 4:29 pm
Ok you got me. What is an eyebrow?
BlueSky1976
Quoting Reins485 (Reply 1):
...and the 737 looks much better and more modern without them  Smile  Smile
Tarriffs are taxes. Taxation is theft. You are not entitled to anything.
If it's a Boeing, I'm not going.
JuniorSpotter
Sun Jun 17, 2007 4:35 pm
Quoting SOBHI51 (Reply 2):
Spot the difference:
Eyebrow...
Photo © J. Richmond-Cole
No eyebrow...
Photo © Johannes Ossenberg
I wonder though - wouldn't the plug require some inspection afterward, to see that the seal is okay? I wouldn't want to have one of those popping out in flight...
[Edited 2007-06-17 09:36:53]
If something can go wrong, it will.
DAL767400ER
Sun Jun 17, 2007 9:47 pm
Quoting BlueSky1976 (Reply 3):
IMHO it gives the 737 a much meaner look  Silly .
lincoln
Sun Jun 17, 2007 9:57 pm
Quoting JuniorSpotter (Reply 4):
Some inspection at the regular intervals, yes... But since plugs are installed from the inside of the aircraft, the pressurization helps to hold the plug in place, so the risk of "popping out in flight" is minimal.
Lincoln
