Quoting FlyingDoc (Thread starter): The agent said that ATC calls DL, tells them they must cancel a certain number of flights "because the airport is too backed up" |
Quoting SirOmega (Reply 5): Whats wrong with running flights into 1-2AM? If the crew has hours available, the equipment is there, I'd rather get into my airport late (4-5A) instead of having a flight canceled. |
Quoting SirOmega (Reply 5): Whats wrong with running flights into 1-2AM? If the crew has hours available, the equipment is there, I'd rather get into my airport late (4-5A) instead of having a flight canceled |
Quoting FlyingDoc (Thread starter): The agent said that ATC calls DL, tells them they must cancel a certain number of flights "because the airport is too backed up" and because "it is not DLs fault", |
Quoting SkyexRamper (Reply 9): With this being a total crock is BS. Though it is Delta's fault, if they're operation at ATL wasn't sooo dang big there wouldn't be as many planes there...so it is DAL's fault. |
Quoting Burnsie28 (Reply 10): Actually ATC will call the airlines and ask for help... thus cancelled due to ATC. |
Quoting SkyexRamper (Reply 9): Besides...how many flights can there be at midnight!? This is definately a lack of legal crews so they had to cancel the flight because the crew timed out. So really I'd press DAL for compensation because the airline messed up, not the weather. It was in their control. |
Quoting WJ (Reply 11): But US ATC is antiquated and therefore cannot handle the traffic a more modern system easily would. The lack of upgrades in that field is costing airlines billions in lost revenues and passenger recovery. |
Quoting IPFreely (Reply 3): My guess is you would have been better off renting a car immediately on arrival in ATL and driving to Little Rock? My suggestion for future trips is to fly either WN or NW (thru MEM) to get to LIT. |
Quoting WJ (Reply 7): Crew hours are managed just as closely as aircraft schedules and flexibility is not really the name of the game, productivity is. most flights, especially express, the crews are cutting it close with legality. 2-3 hour delay and you have likely lost them to rest requirements. |
Quoting IPFreely (Reply 8): The problem is that the plane & crew that was flying the 9:30 ATL to LIT flight is probably the same plane and crew that is scheduled for an early morning LIT to ATL flight the next day. If they arrive in LIT at 2am, crew rest rules mean that the next morning's departure will be delayed by several hours. |
Quoting Swiftski (Reply 17): Do ATC not usually cancel weather related flights, by informing airlines that weather is too poor to take off? |
Quoting N2111j (Reply 21): ATC does not cancel flights!!!!!!!!!!!!!!!!!!!!!!!!!! Anyone that says that is lying, plain and simple.The only thing ATC can do is initiate ground delays, enroute spacing programs, etc. Now these delays may affect crew rest and duty times, but only the airline itself can cancel flights. |
Quoting FlyingDoc (Thread starter): I have never heard of air traffic control cancelling flights. Do they? |
Quoting 5mileBob (Reply 23): In over 25 years of doing this job (ATC) I have never heard of ATC telling an airline to cancel flights. I do know that ATC - Flow Control - has asked airlines if they were going to cancel flights and if so, remove their flight plans from the computer system, but to the best of my knowledge, ATC cannot tell an airline to cancel a flight. By the way, two cousins of mine who work for major airlines have been told since day one: "Unless the aircraft is visabily damaged, ALL flight delays and cancellations are DUE to ATC." |
Quoting FlyingDoc (Reply 16): But, if the flight is lost due to rest requirements, that is not ATCs fault and it is the airline's responsibility. They are supposed to provide a crew to fly the plane to it's destination. |
Quoting Bond007 (Reply 26): The truth in the matter is very few are ever delayed "because of ATC". |
Quoting OPNLguy (Reply 24): o disrespect to customer service folks (I was one once), but they don't usually know the specific details of how the airline's flight operations work. The one the OP dealt with may have mis-spoken, having meant to say that the cancellation was due to ATC reasons, and not that ATC themselves cancelled it, the latter not being the case. One wouldn't expect an airline pilot to know how to work a ticket counter position and book/re-book customers, and one shouldn't expect a CSA to know the specifics of what the pilots, local ops, and dispatchers are dealing with. |
Quoting IPFreely (Reply 3): ATC is the entity that actually orders flights cancelled, |
Quoting Burnsie28 (Reply 10): Actually ATC will call the airlines and ask for help... |
Quoting Bridogger6 (Reply 13): ATC is expected to be bad |
Quoting RDUDDJI (Reply 25): Does ATC ask for schedule pulldowns in severe weather...absolutely |
Quoting ATCT (Reply 30): We have no limitations as to who can and cannot take off in bad weather. The airlines have SOP (Standard Operation Procedures) that limit say the RVR needs to be greater than 3,000ft in order to take off etc. In the middle of a blazing t-storm and granted we havent stopped departures due to airspace congestion...if some idiot wants to take off...I'll give him the current weather wind etc. and clear em. |
Quoting ATCT (Reply 30): Again read above. We do not go "Hey CO Ops, can ya cancel some flights man? Were packed!". |
Quoting ATCT (Reply 34): After he called the tower and talked to the supervisor, he finally found out that some of us upstairs have a small incling of what we're doing. |
Quoting GPIARFF (Reply 33): The question I have relating to whether or not an airline will compensate for a cancellation is if the ATC delay extends out long enough that the flight can't realistically proceede (i.e. crew rest, or later flight segment issues) and this causes the airline to cancel the flight, is this completely outside the airlines ability to have planned for/controlled therefore removing their responsibility to compensate? |
Quoting RDUDDJI (Reply 31): They could have picked their way through them, but whatever |
Quoting WJ (Reply 11): I dont understand if you are trying to be funny here or not... But US ATC is antiquated and therefore cannot handle the traffic a more modern system easily would. The lack of upgrades in that field is costing airlines billions in lost revenues and passenger recovery. |
Quoting P3Orion (Reply 38): And mix with the streams of other enroute traffic? Or, the arrival corridors to the DC metro's? It is not as cut and dry as you think. J6, J48 and J75, in that part of Washington ARTCC's airspace, are very close to each other; weather deviations can and do create havoc with the flow of their sectors. On a side note, it has always amused me that pilots always want to deviate towards their destination. No matter what picture the controller paints for them. |
Quoting IPFreely (Reply 8): The problem is that the plane & crew that was flying the 9:30 ATL to LIT flight is probably the same plane and crew that is scheduled for an early morning LIT to ATL flight the next day. |
Quoting SHUPirate1 (Reply 41): Tell me this...is it possible there could have been a crew on reserve that could fly the ATL-LIT leg, do a stand-up overnight (ie. not a crew rest period), then fly the return LIT-ATL leg and still stay legal from the previous night? Obviously, this is not always the case, but I would have to think that sometimes it would be. |
Quoting IPFreely (Reply 42): Sure. A reserve crew could have flown the plane to LIT then the morning return flight to ATL while the regular crew could have stayed in ATL and met the plane there to resume the next day's schedule. Or the reserve crew could have dead-headed ATL to LIT and flown the next morning's flight(s). So why didn't a reserve crew fly this particular ATL to LIT leg at 2am? Maybe a reserve crew wasn't available (they cost money)...but in reality we have no way of knowing. Those decisions are made by real airline dispatchers, not message board wanna-be's. |
Quoting WJ (Reply 11): But US ATC is antiquated and therefore cannot handle the traffic a more modern system easily would |
Quoting IPFreely (Reply 42): Sure. A reserve crew could have flown the plane to LIT then the morning return flight to ATL while the regular crew could have stayed in ATL and met the plane there to resume the next day's schedule. Or the reserve crew could have dead-headed ATL to LIT and flown the next morning's flight(s). So why didn't a reserve crew fly this particular ATL to LIT leg at 2am? Maybe a reserve crew wasn't available (they cost money)...but in reality we have no way of knowing. Those decisions are made by real airline dispatchers, not message board wanna-be's. The point is that simply "running out of duty time today" is not the only issue in delayed & cancelled flights -- the crew's ability to operate on schedule the following day is also a big factor. |
Quoting SHUPirate1 (Reply 47): IPFreely-I wasn't asking that in any sort of specific scenario, I was just throwing another option out there...regardless, I would bet that, were the reserve crew available, it would cost far less than cancelling the flight, not so much in terms of actual cost, but more in terms of residual costs such as reprotecting the passengers (either on other airlines, costing yourself real money, or on your own airline, preventing you from selling that all-important walk-up fare on a future flight to Little Rock), as well as the obviously-unknown variable known as passenger loyalty (maybe just a couple of passengers per flight, but if those are high-value passengers who, irate with the service that Delta or DCI provided, started booking away, Delta would obviously feel the pocketbook pain). |
