Quoting Kaitak744 (Thread starter): Given Southwest's and Ryan Air's quick turn around times, I was wondering (on short flights) if they refuel when they get to all their destinations. For example, can they do the following: load up full fuel at LAX, fly LAX-LAS-LAX with out refueling at LAS. This way, the only have to pay a ground servicing fee once for the two flights. |
Quoting Freshlove1 (Reply 3): You would still have to pay for the ground servicing fees at LAX 2 times and LAS 1 time whether you take fuel or not. |
Quoting Kaitak744 (Reply 5): The reason I said that is because Ryanair has their own air-stairs on their 737s. If they carried enough fuel to leave the airport, and if they park at a remote stand and unload and load pax, they could pay no ground servicing fee. |
Quoting Freshlove1 (Reply 6): Who is unloading the bags? and transporting the pax to the terminal? |
Quoting TristarSteve (Reply 11): Even long haul aircrraft can tanker fuel when required. Last summer there was a problem with our fuel supply at EWR for a week or so. One flight left ARN with a low load of pax, only about half full, and carried round trip fuel ARN-EWR-ARN. A B777-200ER. About 8 hrs each way. |
Quoting CupraIbiza (Reply 9): Not sure about LCCs. But I do know that NZ did this during their rape of AN. For trans tasman flights, NZ would only fill up fuel in Australia and put it all on AN's account. |
Quoting KL577 (Reply 12): The 772 used on this route could have done this without refueling? But would have made this the plane to heavy for landing in LOS? |
Quoting Aidoair (Reply 17): Have a look at this article from Thomsonfly on ''tankering'' http://www.thomsonfly.com/en/company_3902.html . I think this has something to do with the question asked although i don't understand what it is Thomsonfly are actually doing, could any one explain more? Thanks |
Quoting TristarSteve (Reply 18): Basically the price of fuel at Coventry used to be so high that Thomsonfly tankered in fuel from the last stop. What they have done is get the fuel price reduced to make this economically not required. They will refuel at Coventry in the future. Airlines pay a different price for fuel at every airport they fly to. If the price difference is big enough it makes economic sense to tanker fuel around. It is cheaper, but as the article says, it uses fuel and increases emissions. I personally think tankering is bad for the environment and should be discouraged. |
Quoting OPNLguy (Reply 4): Let me show an example for a 737-300... |
Quoting Runga08 (Reply 20): That makes sense. It is why the LAS-DEN-BWI flight would sometimes come in with FOB at DEN and if WX was questionable in BWI, we would only had to add at the most 2.0 or 3.0 more in DEN and still make the 20 minute turn. To fuel the a/c to BWI in DEN when the tanks are bone dry, it would take a lot longer. |
Quoting JetJeanes (Reply 23): Well im sure Airtrans on their atl to lax just might have to refuel.... Speaking of them i thought i saw where they were running 717,s out of dfw to lax.. |
Quoting OPNLguy (Reply 22): If the tankering is for a supply-related issue, you may have to bump some payload to make it work.. |
