Quoting Ssflyboy25 (Thread starter): |
Quoting FXramper (Reply 3): The remaining a/c will be retired by this fall. |
Quoting ORDZW (Reply 4): So, after a sturdy aircraft is retired from commercial service, it makes sense to stuff them full of cargo! |
![]() Photo © Matthew Wallman | ![]() Photo © Royal S King |
Quoting Ncfc99 (Reply 7): If a 727 is too expensive to operate as a passenger aircraft, why does it make a good freighter? The same goes for MD11, A300 etc.The pax aircraft were all retired in favour of 737, 320, 757 etc. Why do passenger airlines have to have ecconomical aircraft but parcel carriers do not? |
Quoting ORDZW (Reply 4): retired from commercial service |
Quoting Pizzaandplanes (Reply 10): |
Quoting Nosedive (Reply 8): Cheaper to acquire and usually fly less. Freight probably has better revenue, as PAX weight will vary, and you can fill freight to the gills. Plus, boxes don't complain. |
Quoting G5 (Reply 19): .....If it were an issue of fuel, why didn't more airlines (cargo or otherwise) choose to re-engine the 727s..... |
Quoting Ssflyboy25 (Thread starter): Whats the advatage of them in a cargo use |
Quoting Memphis (Reply 5): I predict that FX will have 727s on the property till 2020 |
Quoting Max Q (Reply 12): Fed Ex can afford the fuel! |
Quoting Pikachu (Reply 18): Fedex essentially needs 10% of the world's 757 fleet and what Fedex wants Fedex gets. |
Quoting UPS757 (Reply 20): By Mid-October 2007 - UPS will be out of the 727 business |
Quoting Pikachu (Reply 28): On a 6 hour flight the difference between mach .80 and mach .82 might be 10 minutes. You are wildly overestimating the speed advantage on a domestic flight. |
Quoting FXramper (Reply 25): I read a memo from fleet management. They aren't as economical as they once were. They won't last past Q1 2008. |
Quoting Max Q (Reply 30): Our models had a switchable VMO / MMO selector on the airspeed indicator depending on the zero fuel weight. On the 'A' mode you could indicate nearly 400 knots, and I personally have operated the -200 just under .92 mach it's MMO. |
Quoting Jhooper (Reply 16): I really don't know why FedEx would choose to use aircraft which are more expensive to operate, but it probably affects their bottom line less than it would a pax carrier. There's big money to be made in cargo ops. Think about it this way. Let's say I would be willing to pay $20 to ship a 1 lb package overnight from Tennessee to Texas. You'd made $3600 off 180 lbs of cargo. Few people are willing to pay $3600 to ship themselves (at 180 lbs) the same distance. So can you see just how much more $$$ per pound of cargo you could bring in? |
Quoting Ncfc99 (Reply 7): If a 727 is too expensive to operate as a passenger aircraft, why does it make a good freighter? |
Quoting XT6Wagon (Reply 14): The 727 has very very good short field performance, and as such you can't exactly replace them with 737 at some airports.... |
Quoting Brucek (Reply 21): I have not ever seen a Tay engined 72, but donlt dispute that they exist. |
Quoting Ssflyboy25 (Thread starter): Why Does FedEx Use 727s? |
Quoting Max Q (Reply 12): When time is tight that aircraft can really make up time. |
Quoting Pnwtraveler (Reply 41): I though many airlines stopped using the 727 was noise restrictions. Even with the hush kits. Does anyone know? |
Quoting Viscount724 (Reply 9): One reason is that many freighters only fly 3 or 4 hours a day, especially on domestic routes in the USA, so fuel costs and the added cost of the 3-crew cockpit are smaller factors than for passenger carriers where the aircraft would probably be flying 12 hours a day. |
Quoting Baron52ta (Reply 37): their last miles until the arrival and service proof of 757. |
Quoting G5 (Reply 19): What ever happened to UPS' 727-100s with the Tay engines? |
Quoting BoeingFixer (Reply 47): FDX doesn't have the lift available to retire 95 727-200's by this fall. |
