Quoting DL767captain (Reply 3): just like DL ordering it if they don't really need it it is nice to have just incase. |
Quoting Cricket (Reply 6): BOM-DFW is 14153km! |
Quoting Hodja (Thread starter): SIN-EWR: 15,345 km |
Quoting AA737-823 (Reply 4): The 777-2LR is a heavier, sturdier, longer-range, more capable airplane than the A340-500... but that comes at a cost. |
Quoting AA737-823 (Reply 4): Singapore couldn't even DO SIN-EWR if they had a coach cabin on their aircraft. |
Quoting AA737-823 (Reply 4): Customers have to PAY MORE for a more capable aircraft. That's one reason the 777-2LR is at a competitive disadvantage to the A345... it's a very expensive airplane. |
Quoting Kaneporta1 (Reply 11): Yet another A.net myth. According to the Airbus data the A340-500 has a range with a full pax load of up to 9000nm. |
Quoting Kaneporta1 (Reply 11): Yet another A.net myth. According to the Airbus data the A340-500 has a range with a full pax load of up to 9000nm. SIN-EWR is 8285nm so well within the aircraft's capabilities. The reason SQ chose to outfit those airplanes with a premium economy cabin instead of normal Y, is because nobody would fly for 17 hours trapped in a 31" seat. That, and also save themselves from DVT related suits... |
Quoting AA737-823 (Reply 4): To answer the original question: I think you'll find the reason the 777-2LR is being used on more traditional routes is due to one of its primary strengths... The 777-2LR can fly a longer distance with a FULL LOAD than the A345. Singapore couldn't even DO SIN-EWR if they had a coach cabin on their aircraft. The -2LR CAN do it, however, and will do it profitably. The 777-2LR is a heavier, sturdier, longer-range, more capable airplane than the A340-500... but that comes at a cost |
For all the attention the 777-200LR is getting I'm surprised to learn that so far it's not getting deployed on any actual ULR routes. |
Quoting Kaitak744 (Reply 15): So, on flights longer 5,000nm, the 777-200LR's efficiency overcomes its extra cost |
Quoting MCOflyer (Reply 7): How bout DL's ATL-JNB? |
Quoting Kaneporta1 (Reply 11): Yet another A.net myth. According to the Airbus data the A340-500 has a range with a full pax load of up to 9000nm. SIN-EWR is 8285nm so well within the aircraft's capabilitie |
Quoting Flighty (Reply 17): As I understand it, that is putting a new-build 772ER against a new 772LR, and then ignoring their different purchase prices. In reality, a typical 772ER may be cheaper -- but burn a touch more fuel -- for all journeys than the LR. |
Quoting Kaneporta1 (Reply 11): The reason SQ chose to outfit those airplanes with a premium economy cabin instead of normal Y, is because nobody would fly for 17 hours trapped in a 31" seat. That, and also save themselves from DVT related suits... |
Quoting CanadianNorth (Reply 19): Isn't Air Canada planning some long ones with their new 777-200LRs in the future (YYZ-HKG replacing the A345s, YVR-SYD eliminating the fuel stop in HNL, that sort of thing)? |
Quoting LXA340 (Reply 21): lso don't forget there is no F on this plane as tickets would be too much expensive |
Quoting ConcordeBoy (Reply 23): SQ themselves lamented some of their customer's frustration at the lack of F. |
Quoting Kaitak744 (Reply 20): The 777-200LR is more efficient than the 777-200ER, but it costs more that the 777-200ER. On flights longer than 5,000nm, the fuel you save with the 777-200LR is worth more than the added cost of the aircraft per flight. |
Quoting LXA340 (Reply 21): Quoting Kaneporta1 (Reply 11): The reason SQ chose to outfit those airplanes with a premium economy cabin instead of normal Y, is because nobody would fly for 17 hours trapped in a 31" seat. That, and also save themselves from DVT related suits... That's so true, you can't fly such a long flight in a normal Y cabin. You would've had a qouple of deaths for sure since operations started. |
Quoting Kaitak744 (Reply 15): the 777-200LR gets its extra range through more efficient engines |
Quoting ConcordeBoy (Reply 18): Quoting MCOflyer (Reply 7): How bout DL's ATL-JNB? That segment was flown scheduled-nonstop with A346s and heavily-restricted 744s for years. The return required stops in CPT/SID/FLL however. |
Quoting Kaitak744 (Reply 20): So, to sum up, the 777-200LR is more cost effective to operate than the 777-200ER on flights 5,000nm or more. (taking into consideration the added purchase price) |
Quoting Jacobin777 (Reply 2): If AI start their BLR-SFO nonstop flight as they state they will, it will certainly one of the longer -200LR flights at 14031 km.. |
Quoting Flighty (Reply 17): I bet SQ really wishes they got the newer A345 HGW for their EWR-SIN mission. They are really at the edge (in fact beyond the rated range of their aircraft if I recall). |
Quoting LXA340 (Reply 21): It will definetly replace YYZ - HKG and I think YVR - SYD by this fall? They also planed to fly to SYD from LAX from 2008 but I don't know if they will or got the rights for it |
Quoting ConcordeBoy (Reply 23): No, because the A345 couldn't handle the weight and make the distance. |
Quoting XT6Wagon (Reply 31): The HGW versions of the A340NG are terrible. HUGE wieght increases for the level of MTOW growth. Sure it goes a bit farther, but it costs you alot more to do it. |
Quoting DL767captain (Reply 3): What about SYD to LHR? |
Quoting LTU932 (Reply 34): Unless the aircraft gets a drastic range increase or the headwinds disappear, it ain't gonna happen, neither on an A345 or a 77L. |
Quoting RJ111 (Reply 25): Personally, I don't buy that one. On a demanding route for the 772ER the LR will inevitably come out on top, but from what i can see in many situations the LR only offers 7-10 more tons of deadweight and an unnecessary amount of thrust. It would be interesting to see the cut off point. |
Quoting CALPSAFltSkeds (Reply 29): Let's see, CO and lots of other airlines are adding winglets to get 3% or so better fuel consumption with 737 and 757 aircraft. You'd think 772ER operators would be looking like crazy for a retrofit of those ranked wingtips on the 772LR. |
Quoting Iboam (Reply 36): Just curious, but how long (in terms of time) is the SQ EWR-SIN route? I am interested in flying it, and am just wondering how long the actual flight is. I know the LAX-SIN route is about 18+ hours. |
Quoting Kaneporta1 (Reply 33): For the A345 basic version is 372t and HGW is 380t. The empty weight increase is half that, 4t. Calling it huge is a bit of an overstatement. |
Quoting Atmx2000 (Reply 37): The weight is partly for a structure that improves performance, and the engines are signficantly more fuel efficient. |
Quoting CALPSAFltSkeds (Reply 29): t sure would be great to get some stats on the 772LR vs. 772ER performance. These threads have statements, but no real information. I'm just skeptical. |
Quoting XT6Wagon (Reply 31): Quoting Flighty (Reply 17): I bet SQ really wishes they got the newer A345 HGW for their EWR-SIN mission. They are really at the edge (in fact beyond the rated range of their aircraft if I recall). The HGW versions of the A340NG are terrible. HUGE wieght increases for the level of MTOW growth. Sure it goes a bit farther, but it costs you alot more to do it. |
Quoting OldAeroGuy (Reply 40): On most airplanes, an 8t MTOW increase would require a 1t or less OEW increase. The A345IGW OEW increase does seem to be a bit excessive. |
Quoting Jacobin777 (Reply 13): the A345 is weight limited..its a bit too heavy of a plane... |
Quoting WorldTraveler (Reply 38): As for SQ, remember that the 345 came out a couple years before the 777LR. SQ could have opted for the 777LR had it been available at the time. |
Quoting AirNZ (Reply 14): I'm a bit confused here, namely as you stated "To answer the original question". If I could respectfully point out the 'original question' of the topic was concerned with ULR routes with the B777-200LR, yet you have quite deliberately turned it into a battle/competition with the A340-500 and, indeed claiming a competitive disadvantage with regards to cost. (Of course, there always seemingly has to be a competitive disadvantage portrayed somewhere!). The topic/original question was nothing to do with the A340-500.......so why are you supplanting it into the post? Of course, the fact that your information is wrong says a lot anyhow. |
Quoting BHXDTW (Reply 45): Why do airlines like AC and EK have both the A345 and the LR ?? |
Quoting Sebring (Reply 47): I would expect it to either sell or lease out those two planes this year or next. |
