falstaff
NWA A319 At STL?
Sun Sep 09, 2007 2:04 am
I just booked a trip DTW-STL and back for the Thanksgiving weekend. The return trip is on a A319.I fly to STL from DTW about once a month or so and it always has been DC-9s and CRJs. I have seen a CRJ-900 at STL and the RJ-85s used to go there to. I have not seen a A319 in STL and this is the first time I have seen that aircraft offered on that route before. Is the A319 new to the STL route or is this something done just for the Holiday weekend?
My mug slaketh over on Falstaff N503
boeing743
RE: NWA A319 At STL?
Sun Sep 09, 2007 4:11 am
it must be lucky as NW make the thanksgiving schedule and guess STL was lucky to get A319. You are correct that STL rarely get them only regional or DC9. Yes sometimes some cities get unpect big mainline during holiday so you should feel lucky to flying on it to STL.
bdl2stl2pvg
Sun Sep 09, 2007 4:22 am
It was my understanding that the reason behind only DC-9 mainline a/c was a gate space issue. If an Airbus is at one NW gate then the other gate can not be used. Also, the first gate, IIRC A-2 can not be used for an Airbus period. I am not sure which days specifically have the 319 scheduled, but if it is a day with a reduced schedule that could make some sense.
boeing743
Sun Sep 09, 2007 4:36 am
Yeah, Terminal A at STL is very small and not have big space for big NW airlines so they only use DC9 because of space at gates area. I guess the A319 come when no another NW aircraft would be there on that time and day so A319 will be able to park at whatever gate at that day easy.
PC12Fan
Sun Sep 09, 2007 5:13 am
Quoting Boeing743 (Reply 1):
Quoting Falstaff (Thread starter):
The jetway at gate A3 is being replaced to serve Airbus aircraft on a permanent basis. Not sure when it is supposed to go into service though.
Just when I think you've said the stupidest thing ever, you keep talkin'!
bdl2stl2pvg
Sun Sep 09, 2007 6:15 am
Quoting PC12Fan (Reply 4):
Does that mean that A-1 will be unusable when an A319/320 is occupying A-3? Do you think that they will be able to use A-1, 3, 5 at the same time?
asqx
Sun Sep 09, 2007 1:14 pm
Quoting BDL2STL2PVG (Reply 5):
I will admit that it has been a few years since I was in the A concourse, but where in the world did they find space to cram in an A1 gate? I flew Northwest out of St. Louis every four or five weeks for about three years and there was almost zero room to the right of A3 to put in another gate.
BHMNONREV
Sun Sep 09, 2007 1:31 pm
Quoting Asqx (Reply 6):
There is not a gate designated A-1 at Lambert, certainly not one with a jetway attached. First gate on the left out of security is A-3, and from what I understood in the past is that the Airbus could not park at this gate due to the limited wing tip clearance. Back in the 80's when NW would regularly fly the 727-200 into STL you would often see this aircraft parked at A-3 and that was very tight. And the A-319/320 has a larger wingspan than the 72S.
Never knew the jetway was an issue in accomodating the Airbus, is the jetway being re-located to make this happen??
atrude777
Sun Sep 09, 2007 2:36 pm
I just noticed that NWA has been using A-10 for quite a while I have seen this 3 days in a row.
Is this permanent or a temp thing?
Alex
falstaff
Sun Sep 09, 2007 10:51 pm
Quoting Atrude777 (Reply 8):
Good Question. I was talking with the gate agents last month when they had two planes at the gate and a third sitting waiting for one to leave. They told me they used to use Delta's gates in a "gentleman's agreement", but they no longer could do that. The Agent said they would like to get a third gate or at least one they could use from time to time if they needed it.
What airline regularly uses A-10? Is it US? If it is I have seen Airbus' there before.
nwa757300
Sun Sep 09, 2007 11:05 pm
When AA left the A concorse, NW was suppose to get a 3rd gate. However, after 9/11/01 all this was put on hold due to budget cut backs. In 2005 when their lease was up they were to negotiate for another gate, but the airport raised all of the fees because AA had cut back so much in STL.
NW needs a complete renovation in STL. There was talk of new electronic back boards, counters, seats and carpet but again that was put on hold as well. Not sure if any of this has happened since I've been on leave for a while and haven't been commuting. But, I remember torn seats and stained carpet all over the gate area.
atrude777
Sun Sep 09, 2007 11:10 pm
Quoting Falstaff (Reply 9):
No Airline is assigned A-10.
It was AA's former gates I believe.
Alex
bcoz
Sun Sep 09, 2007 11:43 pm
Quoting Atrude777 (Reply 11):
That's right. IIRC, American had A-10, A-12, and A-14 prior to the merger. I remember leaving on an American F-100 going from STL to ORD from A-14 in May, 1999. I also recall picking up a friend of mine (back when you could go through security without a ticket) on an AA Super 80 in early Jan. 2001 (which I think would have been right before the move).
bcoz
PC12Fan
Mon Sep 10, 2007 12:32 am
Quoting BHMNONREV (Reply 7):
All I know is that the foundation for the old jetway was removed for a new jetway coming in. My sources tell me the primary reason for this was to put in a new jetway so NW could bring in Airbi on a regular basis.
Temp thing while the A3 construction goes on.
Quoting NWA757300 (Reply 10):
That should be part of the upcoming 100+ million dollar renovation.
I believe this is correct as every once in a while, I'll see an airline not normally using A10 utilize it for a diversion or the like. I assume this is handled by the airport.
burnsie28
Mon Sep 10, 2007 2:52 am
NW has in the schedule A319 service to DTW and MSP for Nov 22nd (just used that date for example) here is what the NW STL Service looks like this November.
MSP-STL
NW 3649 Dep: 7:05 Arr: 8:51 CRJ-900
NW 1455 Dep: 10:25 Arr: 12:11 D9S
NW 5672 Dep: 2:20 Arr: 3:55 CRJ-200
NW 1465 Dep: 3:05 Arr: 4:44 D9S
NW 1463 Dep: 4:50 Arr: 6:31 D9S
NW 1461 Dep: 6:52 Arr: 8:35 D9S
NW 1457 Dep: 9:00 Arr: 10:47 A319
DTW-STL
NW 1685 Dep: 6:40a Arr: 7:17a D9S
NW 1687 Dep: 8:50a Arr: 9:43a D95
NW 1681 Dep: 12:00 Arr: 12:45p A319
NW 3799 Dep: 3:10p Arr: 3:54p CRJ-200
NW 1677 Dep: 7:10p Arr: 8:04p D9S
MEM-STL
NW 5911 Dep: 8:40a Arr: 9:47a CRJ-200
NW 5777 Dep: 2:20p Arr: 3:33p CRJ-200
NW 1511 Dep: 6:25p Arr: 7:37p D9S
STL-MEM
NW 202 Dep: 7:37a Arr: 8:50a D9S
NW 5906 Dep: 11:20a Arr: 12:27p CRJ-200
NW 5711 Dep: 5:18p Arr: 6:30p CRJ-200
STL-DTW
NW 1676 Dep: 6:55a Arr: 9:35a D9S
NW 1678 Dep: 8:25a Arr: 10:58a D9S
NW 1680 Dep: 9:55a Arr: 12:38p D95
NW 1682 Dep: 1:40p Arr: 4:16p A319
NW 2929 Dep: 5:05p Arr: 7:44p CRJ-200
STL-MSP
NW 1456 Dep: 6:15a Arr: 7:54a A319
NW 1458 Dep: 8:35a Arr: 10:17a D9S
NW 3648 Dep: 10:25a Arr: 12:13p CRJ-900
NW 1454 Dep: 1:45p Arr: 3:39p D9S
NW 2860 Dep: 4:10p Arr: 5:49p CRJ-200
NW 1462 Dep: 5:30p Arr: 7:22p D9S
NW 1460 Dep: 7:30p Arr: 9:22p D9S
